EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Fri Jun 26, 2009 9:06 am Post subject: |
velvetgreen wrote: |
would be interest in an SKU/picture or whatever of the "finger" that Home Depot sells.. |
1" ones from Home Depot (I think) that match pretty well
3/4" ones from Ace Hardware that I used. Also matched well but I had to bend it outward just a small amount:
The one thing that is a bummer is they both have writing on top.
Make sure you prime or blast them before paint because straight black paint won't stick very well to the plating used.
FWIW Wolfsburg West also carrier the clamp you are looking for but as of last week they were out of stock |
Unfortunately they've been out of stock for years. _________________ How to Post Photos
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Nov 29, 2018 8:08 pm Post subject: Re: Correct Optional 1500cc Bus Tin Help Please |
Has anyone found an exact date/chassi number the bus switched from left hand side to right hand side pre-heat tube? Thought it happened right around the start of 1966 model year AUG65. _________________ In Stereo, Where Available! |
Clara Samba Member
Posted: Fri Nov 30, 2018 10:21 am Post subject: Re: Correct Optional 1500cc Bus Tin Help Please |
Eric&Barb wrote: |
Has anyone found an exact date/chassi number the bus switched from left hand side to right hand side pre-heat tube? Thought it happened right around the start of 1966 model year AUG65. |
good question
It was May 1966 they went to the pre-heat from the heater box.
Posted: Fri Nov 30, 2018 10:39 am Post subject: Re: Correct Optional 1500cc Bus Tin Help Please |
Clara wrote: |
It was May 1966 they went to the pre-heat from the heater box. |
Not that change. Before that the pre-heat for the carb moved from the LH side to the RH side. Here is a good image of this in the AUG65 OM:
