SGKent Samba Member
Posted: Fri Jun 26, 2009 11:42 pm Post subject: Heater cable assembly order - UPDATED PHOTOS |
I posted on this a while back and didn't get an answer. Can't locate that thread so thought I would ask again another way. 1977 bus heater cable question
There is a rubber boot at the back where the plastic fits to the tube. Anyone know of a source. Right now am using electricians tape.
There is a white small nylon / plastic piece that slides over the cable inside this area. The pictorials show it on the bellows side of the arrow but when it came apart it was on the tube side with the hat facing away from the tube and the small end stuck into the tube. Which is correct, the pictorial or the way it was?
The front end is exposed to moisture. Is there supposed to be a boot at this end? If yes can someone show me a part number or where to get it? Electricians tape? Silicone sealer to keep moisture out?
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Joined: January 01, 2007 Posts: 16865 Location: sticksville, ct.
Posted: Sat Jun 27, 2009 6:19 am Post subject: |
no idea on the plastic doo dad, but you need these boots for the front of the bus. they are the ones in the bottom middle of the screen, but when you click on them, it shows a pic of something different but at any rate, you need the ones that look like them. kind of like horn wire boots, but different
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211711630C
edit: this is a better pic of them
http://www2.cip1.com/ProductDetails.asp?ProductCode=C16%2D113%2D411 _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Sat Jun 27, 2009 10:12 am Post subject: |
thanks for answering the part about those boots. I'll get a set. Now someone to answer the other 2 parts of the question........ _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Jun 27, 2009 11:00 am Post subject: |
i am parting out a 69 bus. let me look at the heater plastic things and see if i have them. don't know if they will work, but i will get some pix anyway _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sat Jun 27, 2009 11:14 am Post subject: |
dont know if its the same animal, but here are some pix
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Sat Jun 27, 2009 1:39 pm Post subject: |
the late ones are two pieces but they serve the same function. There is a black plastic piece the fits on the tube and a small nipple with a slot that fits on the cable. The question is whether that nipple fits inside the tube or whether it fits inside the rubber bellows. Tell me, on your white plastic part from the 1969 - is the end with the arrow on the tube side or the cable end side?
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jun 27, 2009 3:48 pm Post subject: |
The end the arrow is pointing to is on the tube side (pointing to front) on my unmolested 78. The rubber boot goes on the tapered end. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
Posted: Sat Jun 27, 2009 4:51 pm Post subject: |
Does anyone make the plastic part or the bellows? _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
SGKent Samba Member
Posted: Sat Jun 27, 2009 5:16 pm Post subject: |
Ok. I took some photos
In the first one is how it came apart however PO has been in there before.
In the second shot, is how Vagcat etc pictorial shows it but the parts don't seem to fit as well and I don't know which way the hat fits on the smallest part.
I haven't a clue which is correct.
A
B
Posted: Sat Jun 27, 2009 7:21 pm Post subject: |
see where the rusty groove is on my plastic doo dad? that clipped to the frame. my best guess is, the metal tube that slides into it may be off at install from the factory, thus the multiple grooves. i would say put your clip in the position where it best fits, keeping the metal tube snug in the holder welded to the frame. sorry i can't really help too much _________________
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Sat Jun 27, 2009 11:10 pm Post subject: |
here is the update. I discovered that the arms that hold the black plastic part were not allowing it to go all the way onto the tube so there was a gap. That allowed the cable barbs to get trapped. I did some fitting and was able to get the cables to move smoothly. Used the beetle rubber parts on the front of the tube under the driver to seal that area so both the front and back are sealed. Used electricians tape to take the place of the rubber boot on the back between the plastic and tube since that part is likely never to be found new or repro. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Greg in GA Samba Member
Posted: Thu Oct 18, 2012 1:35 pm Post subject: |
I know this thread is old but I'm needing a picture of the rear cable assembly. I'm missng everything except the cable and the tube back there. _________________ 1969 Beetle
1974 Westy 1800cc FI conversion, L62H
Need a really good mechanic for your VW bus? Consider making an appointment with Colin (Amskeptic) next time he passes thru your area. |
Desertbusman Samba Member
Posted: Thu Oct 18, 2012 5:47 pm Post subject: |
Sorry, I don't have any pictures of the cable.
But regarding the DEAD pictures It would be great if people would do what Everett asks-
Quote: |
When posting photos, PLEASE consider posting the photos in the Samba Gallery instead of just posting links to some picture hosting site.
If you post it elsewhere, the photos often become "dead links" after a certain period of time, which ruins the thread where you posted the photos. If you post them in the Samba Gallery they are here forever. Not only that, but in the Gallery users can search for photos so much easier than they can in the forums. It's worth it. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=6 _________________ 71 Superbug
71 Westy |
Posted: Thu Oct 18, 2012 5:52 pm Post subject: |
^X2^ Dead links suck.
Greg, tell us more about which rear cable and what else you need to see, there's more than one on some models and in different spots. Maybe even some pics of what you have now (in the Samba gallery of course ). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Oct 21, 2012 12:54 pm Post subject: |
Here is the heater end I'm working on, I know about the boot, but I've seen a small plastic piece i'm missing as well. Any thoughts?
Posted: Mon Oct 22, 2012 5:38 am Post subject: |
Any idea on what's missing?
EDIT: on the picture above _________________ 1969 Beetle
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Mon Oct 22, 2012 5:50 am Post subject: |
For me, the whole picture is missing. _________________ '76 Deluxe Campmobile |
Posted: Mon Oct 22, 2012 7:15 am Post subject: |
Perhaps send SGK a PM and see if he can repair his pics, you are missing the plastic clip that snaps into the holder on the body as well as the boot and small nylon sleeve that pushes into the end. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Mon Oct 22, 2012 8:10 am Post subject: |
busdaddy wrote: |
Perhaps send SGK a PM and see if he can repair his pics, you are missing the plastic clip that snaps into the holder on the body as well as the boot and small nylon sleeve that pushes into the end. |
Server is permanently off. I can't edit old posts and Everett hasn't gotten back to me yet whether he can take the photos from me on a DVD in the same file structure and write a scrip that will change Kentcomputer.com to whatever structure he puts the photos in. sorry. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Oct 22, 2012 8:48 am Post subject: |
Dang, is there a source for these pieces other than a donor?
busdaddy wrote: |
