scott s Samba Member
Joined: January 04, 2005 Posts: 1122 Location: Rock Hell, SC
Posted: Mon Jun 29, 2009 4:47 am Post subject: |
That's a great attitude to have. Consider removing the T3 cool tins, too.
With the stock heads and a smaller exhaust collector, you should have a nice little combo.
What about a sump? You can get 1.5 qt. sumps pretty cheap.
One of these days, down the road, throw a set of dual Kads or ICT's on it for a few more ponies. _________________ Nothing screams "poor workmanship" like wrinkles in the duct tape. |
perrib Samba Member
Joined: September 14, 2004 Posts: 3402 Location: Chandler, Az
Posted: Mon Jun 29, 2009 7:50 am Post subject: |
Even 1600 cc with stock heads it won't be stock performance with the C25 cam. The difference is like driving with the carb only opening up to 3/4 throttle or full throttle. See if they will trade heads and a little money for a set of HD springs. You can also sell/ trade your crank and get a 74 mm stroke crank. A 74 mm from CB is only $179.00 Barrel spacers are around $10.00. With a 1699 and the C 25 cam it will be easy accelerating into traffic and cruising down the highway. If your speedo is inoperative you might even get a ticket for speeding. |
mightymouse Samba Member
Posted: Wed Dec 09, 2009 4:58 pm Post subject: |
Did you ever get this thing running? just toss the teflon buttons and the T3 cool tin. all else is fine. 8.9 to 1 CR is good with that cam, id have gone a tad higher with 9- 9.5 to 1.
Also would get some good dual carbs. baby dells or 36 drla's or 40 idfs. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
nsracing Samba Member
Posted: Wed Dec 09, 2009 6:45 pm Post subject: |
Max Welton wrote: |
Was there a question in there somewhere?
Max |
For crying out loud. Crank that thing already. If you did your work properly, she will be fine and then some.
If you build it like a race motor, it better perform like a race motor. Otherwise, what is the point? |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
