New Cables Too Long - What did I do wrong?
pthornton4
pthornton4 is offline
PostPosted: Mon Jun 29, 2009 5:25 pm    Post subject: New Cables Too Long - What did I do wrong? Reply with quote
Help! I can't figure out what I did wrong. I put new hand brake cables in my 1967 Ghia. After I adjusted the rear brakes, guided the wire through the guide tube, the under the pully part of the lever and up to the double bolts, I have to max out the threads just to get the brakes to catch, and even then it is not too good.
Am I missing something here that might have forgotten? the cables were about the same length as the old ones. I have the later model VW, so I should need the longer cable (as opposed to the pre 66 cables).
Any ideas would be much appreciated.
Thanks.
Peter
smisk
smisk is offline
PostPosted: Mon Jun 29, 2009 5:40 pm    Post subject: Reply with quote
Did your parking brake work normally before you replaced the cable? Did you replace the brake shoes?
'66 Bug
'70 Ghia
pthornton4
PostPosted: Mon Jun 29, 2009 8:14 pm    Post subject: Parking Brake Cables too Long Reply with quote
Yes, they did work, but they appeared to have stretched out quit a bit and had maxed out the length of the threads, even though there was plenty of brake pad left.
Ghiaddict
Ghiaddict is offline
PostPosted: Mon Jun 29, 2009 8:33 pm    Post subject: Reply with quote
Are you certain you got the correct cables for
your model year (1967)? The length changed several
times during Ghia production.
For 1967: #113 609 721 L
1779mm or 70" length
Karmann Ghia & Beetle parts available.
Convertible tops installed.
pthornton4
PostPosted: Thu Jul 09, 2009 9:37 am    Post subject: How can I tell what the part number is on a brake cable? Reply with quote
IE - where on the cable should I look for the part number?
Ghiaddict
PostPosted: Thu Jul 09, 2009 9:52 am    Post subject: Reply with quote
Probably no part number on the cable itself.
Maybe on the bag they were packed in?
It's a good practice to compare any cable length
new vs. original before installing the replacement.
That advice might not be good for you now, but
live and learn. d'oh!
Corwin
Corwin is offline
PostPosted: Thu Jul 09, 2009 12:51 pm    Post subject: Reply with quote
You bought the wrong cable? Wink
pthornton4
PostPosted: Sat Jul 11, 2009 6:38 am    Post subject: Reply with quote
I hope not. I special ordered the part from a long time VW parts place here in Down Town Raleigh NC. They are very good. Unfortunately, the cables came without packaging, so I had to take their word on the part number.
I compared lengths before I put the new ones on. They looked close, but it is hard to tell with all the crimps in the line.
Usually if it is a debate between the guy at the parts place that knows every VW part number by heart and the shade tree mechanic, it is usually the shade tree mechanics mistake.
I am going to order a new set on line and put them in. Lets see what happens. It is a pretty simple repair. I can't see where I messed up (especially too long).
Gary
Person of Interest
Gary is offline
PostPosted: Sat Jul 11, 2009 6:44 am    Post subject: Reply with quote
If you can get an accurate measurement of the pair that is too long you can at least sell them here and recoup part of your loss.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
pthornton4
PostPosted: Sun Jul 26, 2009 3:50 pm    Post subject: Put in new cables today- right size Reply with quote
You guys were right. I put in new cables today and low and behold, I now have a hand brake! I guess I need to make as stop at the parts store. Wish I still had that receipt.
Thanks for your help!
Peter
Ghiaddict
PostPosted: Sun Jul 26, 2009 6:05 pm    Post subject: Reply with quote
No problemo!
Good to hear that you got it done
now and that everything is OK. Cool
