Ghia Nut Samba Member
Joined: December 23, 2003 Posts: 1565 Location: B'ham Alabama
Posted: Tue Jun 30, 2009 2:04 pm Post subject: Clutch Chatter |
I think I may be experiencing some "clutch chatter". When I start off (engine warming up) doesnt seem to be a problem, theres a smooth engagement. But after its warmed up, when I start off in first I get som shaking in the engine (not backfiring) it feels like Im going over tiny indentions in the pavement and it rattles a bit. I only get this in first gear starting off, all other gears its smooth sailing. Is this clutch chatter and how do I get rid of it? _________________ '59 typ1 rajay turbo
'72 Ghia rajay 1641 dual 36DRLAs, 1 3/8" SS merged header and fat boy
78" GL Vert with ej22t swap
This will likely change tomorrow to something else. |
Ghiaddict Samba Member
Joined: November 20, 2002 Posts: 2632 Location: Now in Honea Path, SC
Posted: Tue Jun 30, 2009 2:29 pm Post subject: |
Yes, that sounds like clutch chatter.
Step One: adjust the clutch pedal free-play to spec.
Step Two: inspect and/or adjust the bowden tube.
If no cure, you'll probably need to remove the clutch.
Inspect the disc and mating surfaces for
wear, slippage or oil contamination.
Replace and/or repair as needed. _________________ ****************************
Karmann Ghia & Beetle parts available.
Convertible tops installed. |
SurfDestin Samba Member
Posted: Sat Aug 08, 2020 2:23 pm Post subject: Re: Clutch Chatter |
New to Ghia this week. I have this issue being described shakes something awful taking off. Mounts seem good.
Looking at this photo of mine, can anyone say if this looks like the proper amount of bend in the Bowden Tube?
rcooled Samba Member
Joined: September 20, 2008 Posts: 2507 Location: Santa Cruz, CA
Posted: Sat Aug 08, 2020 2:40 pm Post subject: Re: Clutch Chatter |
SurfDestin wrote: |
Looking at this photo of mine, can anyone say if this looks like the proper amount of bend in the Bowden Tube? |
Looks about right...should be about 3/4" to 1" sag. Oil on the clutch disc is a common cause of clutch chatter when everything is adjusted properly and mounts are good. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Sat Aug 29, 2020 6:14 am Post subject: Re: Clutch Chatter |
I'm new to Air-Cooled Engines. Where would you suspect oil might come from if that is the issue. Main bearing assuming it has one, or from transmission side. Asking so I know what to look for once I tear it down. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Sat Aug 29, 2020 9:57 am Post subject: Re: Clutch Chatter |
SurfDestin wrote: |
There are really only two (well three actually) sources of oil in the bell housing that can get on the clutch.
1) Leaky FRONT main engine seal allowing engine oil to get past and foul clutch disc.
2) Leaky transmission input shaft seal allowing gear oil to get past and foul clutch disc.
3) If you really smoked your throwout bearing and caused the grease inside to liquify it can and will come out and fling around oil in there. But the bearing would be noisy AF if this was the case.
#1 is usually pretty easy to spot without pulling the engine, as it will drip out onto the ground from the seam where the engine and transmission mate. You will notice there is a little cutout there in the engine case to allow any oil to drip out. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sun Aug 30, 2020 5:53 am Post subject: Re: Clutch Chatter |
Been there, done that...replace the front mount. Looks can be deceiving. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
