iVolkswagen The Modern-Day Hippie
Joined: October 21, 2008 Posts: 1436 Location: Huntsville, Alabama
Posted: Sat Jul 04, 2009 6:47 pm Post subject: Teardrop Trailer Build |
Well, I have wanted one of these for a while, and have been sketching out and searching here how to make one.. SO, we (my Dad, and Uncle) decided to just go for it.
And here we go.
I knew we had a Type 3 Squareback trailer (we call it the Halfback), so we played around with it and tried to figure out what to do with it.
*No worries. We bought the Halfback the way it was, and bought the Beetle top as it was.
The Bug top was going to be the front..
but the idea got thrown away.
So then we scoured the property for a trailer we could use. .
We found this!
So after playing around with ideas for it (adding a single cab wood slat canopy, a boxed in room-ish thing), we finally decided that it was best to just go ahead with the teardrop idea.
First off, its too high for my car. Second, its 4 lug wheels.
Strip down!
Flipped over to suspension work
Some neat lights.
Suspension..
It needed to be lower.
So, we just reverse the leaves. Which lowers it about 2 inches.
Fitting the 5-lug adapter.
We had some trouble with the adapter because the lugs on the trailer were larger than the holes on the adapter, so we would have to drill out the adapter and such..
Eh, a little better.
Placed some plywood to see how it looks.
Ok so, we got a little ahead of ourselves..
Messing around with Beetle fenders
Can you see the teardrop outline?
If not, I outlined it in Paint.
Notice: We ended up deciding to do a 'body drop' on it so that it will not tower over my slammed car. We dropped it about 8 inches.
Testing the height
Back to the adapter...
Turns out, after a little looking, we found another set of adapters.
Guess what.
They fit! No drilling or welding needed.
Only thing we had to do to these adapters was grinding the inside of it so it will sit flat up against the hub.
Up next:
Cleaning, and painting the frame. Also, making sure the wheels and adapters fit just right. _________________ TJ
\/OLKSWAGEN
- 1963 Beetle - 1987 Cabriolet |
type2vw Samba Member
Joined: March 07, 2002 Posts: 179 Location: Recovering in Summerfield, FL
Posted: Mon Jul 06, 2009 6:05 am Post subject: |
Wow! Looking great. Keep the pics coming. I've wanted to make a VW based tear drop. I wonder if a single cab rear bumper would fit? There are a lot of VW parts that can be used. I look forward to your progress!  _________________ No more VW's. Just a garage full of toys and literature. |
carlos_magnum Samba Member
Posted: Tue Jul 07, 2009 3:47 am Post subject: |
Nice project. Can't wait to see what it looks like.
Keep us posted. |
alex608 Fat Chick T3s Rule
Joined: April 04, 2004 Posts: 291 Location: Rohnert Park, Kalifornien
Posted: Fri Jul 10, 2009 9:46 am Post subject: |
Have you seen the websites for teardrops? Here is one link and dozens can be found with tips and even complete plans. Some of these folks have spent serious time planning where everything goes and using every avaliable square inch for storage.
http://www.teardrops.net/index.html
www.tinytearsteardroptrailers.com/ _________________ Alex Sundberg
'71 FI square...The daily driver
" At times It is better for one to keep his mouth shut and be thought of as a fool...
Than to open his mouth and erase all doubts..." |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2859 Location: San Diego, CA
Posted: Fri Jul 10, 2009 10:27 am Post subject: |
This is my favorite VW trailer hack. Nicely done and plenty of windows:
Posted: Fri Jul 10, 2009 7:54 pm Post subject: |
Anchovy wrote: |
Yeah, lemme get 2 deluxes and I'll be right on that!
Thanks for the links Alex!! Definitely helped with where to get any parts we may need! _________________ TJ
\/OLKSWAGEN
simon34 Samba Member
Joined: December 15, 2008 Posts: 66 Location: Rotorua new zealand
Posted: Thu Jul 16, 2009 9:32 pm Post subject: |
iVolkswagen wrote: |
Anchovy wrote: |
Thanks for the links Alex!! Definitely helped with where to get any parts we may need! |
That trailer is cool got a few brazilian buses i could cut up here to do something similar
nice work on the teardrop keep up the pics  |
Posted: Sat Sep 05, 2009 10:41 pm Post subject: |
Still kickin!
Work on the trailer slowed down, but is now up to full speed again.
So, with the suspension..
We ended up putting the leaves back the way they are supposed to be, for safety. So now, we are going to use 2 inch block spacers to lower it.
Work today:
Putting up the side main support walls.
Underneath:
*hasnt been cleaned/painted yet.
Backside:
Cut out the mock-up walls.
I wanted to keep this thing as VW related as possible.
So, we found out that early Ghia bumpers fit perfectly on the back and give it a nice vintage look.
We are playing with the idea of putting split windows in the back of it. *not real split windows, but split window shapes cut out and using plexi.
Also, if we can find one for cheap, a single-cab roof rack would be nice on top of it.
Hoping to have it done by Circle Yer Wagens, Oct. 8th. _________________ TJ
\/OLKSWAGEN
Posted: Wed Sep 23, 2009 2:58 am Post subject: |
Nice to see the progress of your work. When it is done, I'm sure it will look great. |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2149 Location: Prescott Valley, AZ
Posted: Wed Sep 23, 2009 3:07 am Post subject: |
IVW..I have a fiberglass mold to make the rear split windw section and I know I have several rear split PC windows laying around here. For rubber mounted or as on Monster garage split window drag car, flush mounted?
I would like to donate at lest the PC windows to the project and shipping for free too!
IM me an address and let's talk.
JM _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
metalchomper Samba Member
Joined: June 27, 2005 Posts: 698 Location: Statesville, NC
Posted: Wed Sep 23, 2009 9:01 am Post subject: |
I believe plywood is lighter than OSB as currently shown on the sides. OSB swells when it gets wet. Keep up the good work! _________________ Brett
Devil Dog Dubs
I live vicariously through me
'62 Beetle, "Zombie Mojo"
'68 Manx II "Conundrum"
'72 SB "Luftwaffle", 2270 T4
'75 SB Wizard Rodster "Olympias" (Mrs. Metalchomper's car) |
Posted: Wed Sep 23, 2009 1:42 pm Post subject: |
werksberg wrote: |
JM |
This is why TheSamba community is the best there is.
PM sent.
metalchomper wrote: |
I believe plywood is lighter than OSB as currently shown on the sides. OSB swells when it gets wet. Keep up the good work! |
We will be using plywood. The OSB is just for mock up and dimensions.
Well, project update.
Due to some sicknesses and events, we havent been able to work on it as much. It wont be done by CYW (guess we're takin tents! ).
But come on, what project ever gets done by a deadline?
(productive) Updates to come. _________________ TJ
\/OLKSWAGEN
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17727 Location: Eugene, OR
Posted: Wed Sep 23, 2009 3:00 pm Post subject: |
Make Sure your bed is Long enough or your legs will cramp up trying to sleep in it! BTDT!  _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Sep 23, 2009 6:33 pm Post subject: |
Mike Fisher wrote: |
Make Sure your bed is Long enough or your legs will cramp up trying to sleep in it! BTDT!  |
Yeah we made sure there is enough room. I'm 6' 1'' so it was a tight squeeze.
Got any pics of yours? I would love to see them! _________________ TJ
\/OLKSWAGEN
hot-air Samba Member
Posted: Fri Nov 06, 2009 12:45 am Post subject: |
hey man
what happened to the steam here?
ed |
72KYLE Samba Member
Joined: June 08, 2009 Posts: 394 Location: California
Posted: Fri Nov 06, 2009 1:11 am Post subject: |
this is a really cool one, I'll be watching this if it picks up again  |
Posted: Fri Nov 06, 2009 6:19 am Post subject: |
Hey, all.
Well progress stopped because after going to a few shows and seeing other trailers, we realized ours was going to be way to heavy. So now we are trying to get together better materials. Plus, It getting closer to the holidays, schedules have been busy.
Sorry that this has been all talk, no action.. But nothing is perfect. _________________ TJ
\/OLKSWAGEN
Posted: Fri Nov 06, 2009 9:59 am Post subject: |
Dang, I keep forgetting to send you the rear split PC windows...I hear ya on other life factors!
Juts because others have lighter trailers....slightly heavier but weight in the right places tow better!  _________________ Werksberg Products....Products that work!
Posted: Fri Nov 06, 2009 3:55 pm Post subject: |
You should target less than 500 lbs if you hope to tow it regularly with your VW. Buy a Heilite in the mean time. |
Posted: Fri Nov 06, 2009 6:25 pm Post subject: |
Anchovy wrote: |
The materials we were using would have made it a lot heavier than that.
Also, I plan to tow it using my (slammed) Beetle. So, that plays a factor.
Light enough to be towed by my car, but heavy (and stable) enough to be towed by other 'regular' cars. _________________ TJ
\/OLKSWAGEN
