What did you do to your Oval today?
Page: Previous  1, 2, 3 ... 50, 51, 52 ... 56, 57, 58  Next
AngieB
AngieB is offline
PostPosted: Mon Feb 27, 2017 11:20 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
i purchased! Smile
Headliner
Headliner is offline
PostPosted: Fri Mar 17, 2017 7:53 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Mounted up a really old pie Crust Continental GERMAN MADE tire.
Put in a tube and mounted it to a really nice restored smoothy rim.
(thanks preacher)
EVfun
EVfun is offline
PostPosted: Wed Mar 29, 2017 6:09 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
I swapped out the 019 distributor for the stock one in my '57 Bug. Took about 20 minutes including installing condenser and setting the points. Then I had to warm up the car for the final timing setting (always looking for an excuse to drive it.) That brings up a question...
Is the vacuum on the stock 28PCI carb manifold vacuum instead of just above the throttle blade? I installed and timed (with a timing light) the rebuilt distributor without the vacuum. Then I replaced the vacuum line. The idle speed and advance shot up. A quick crack of the throttle would pull the timing back near the mark briefly before it started rising with rpm, so everything seems to be working correctly.
Wildthings wrote:
Headliner
PostPosted: Thu Apr 06, 2017 7:35 pm    Post subject: Vintage shift know from the 50s Reply with quote
Found this shift knob in an Antique shop!
Had to modify and sacrifice another shifter for the bushing
but made this one work.
Works well and looks killer
vwnut1
vwnut1 is offline
PostPosted: Sat May 27, 2017 5:51 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Decided to repaint my 80's billet aluminum running boards.
Back to black
1957 VW Oval Resto Mod
kev_par
kev_par is offline
PostPosted: Wed Jun 14, 2017 8:54 am    Post subject: Re: What did you do to your Oval today? Reply with quote
Drove it to work today. Very Happy
mandraks
mandraks is offline
PostPosted: Wed Jun 21, 2017 1:52 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
i finally got my bulb holders for my original paint L35 metal blue heart tail light.
regards
Uli
55type1
55type1 is offline
PostPosted: Wed Jul 12, 2017 9:44 am    Post subject: Re: What did you do to your Oval today? Reply with quote
Picked it up at CN Rail's partner company Livingston in Toronto, ON and drove it home! Looking forward to exploring this side of the country Very Happy [/img]
JoblessPunk
JoblessPunk is offline
PostPosted: Sun Aug 06, 2017 2:56 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
I'm the third owner of my beetle and the story is that the original owner requested a Dehne fuel gauge installed by the dealership. Due to age it broke and was removed for repairs but was lost/sold away. So this weekend I fixed that putting a Denhe fuel gauge back in the dash. Wink
Removed the broken Dehne sending unit and replaced it with a refurbished one:
I also mounted the missing gauge back into the dash. From the looks of it, I think the faceplate is a reproduction from Brezelwerks:
Headliner
PostPosted: Sat Aug 19, 2017 5:13 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Finally got my long travel ball joints Installed,
Built my beam and installed in the car.
It's just a mock up right now.
I will fine tune it once the rest is together.
By The way-This 56 is sitting on a 71 pan.
Hence the ball joint beam 👍👍👍✌️
Second Air Force
Second Air Force is offline
PostPosted: Sun Aug 20, 2017 2:30 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
We brought our October '55 Standard home.
boxkiteflyer
boxkiteflyer is offline
PostPosted: Sun Sep 10, 2017 7:04 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Put disc conversion on front. Put in dual circuit master cylinder. Ran new brake lines. Cleaned and painted steering box and tie rods. Just need to finish rear brake plates with new slave cylinders and hardware.
BulliBill
BulliBill is offline
PostPosted: Mon Oct 23, 2017 7:47 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Hi there,
In looking at your photo of the turnsignal housing, it looks like the "heart" lens is sticking through the metal housing too far. You might be missing the weatherstripping seal between the "heart" lens and the metal housing which will draw the lens lower into the housing and weatherproof it at the same time. Someone sells them, I think it was Brezelwerks...
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
Bob Loblaw
Bob Loblaw is offline
PostPosted: Tue Oct 24, 2017 1:19 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
JoblessPunk wrote:
I'm digging the overlay tach on the speedo. Cool.
sent from a phone using poor grammar and spelling
Da TOW'D
Da TOW'D is offline
PostPosted: Wed Oct 25, 2017 9:00 am    Post subject: Re: What did you do to your Oval today? Reply with quote
This weekend I had my '57 oval up on the hoist.
Makes it easy to change the plugs and set the valves.
New fuel filter next to the transaxle.
I gave the front end a grease job then noticed
tire rubbing
What should I do to correct the rubbing problem?- both sides
cheers
Hank
'57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS
EVfun
EVfun is offline
PostPosted: Wed Oct 25, 2017 12:42 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
tire rubbing
cheers
Hank
Very common on king and link pin Bugs. The steering stops are the forward bolts holding each front backing plate on the spindle. First, you should inspect the front suspension for signs of damage or excess wear. In many cases the cause is just wider than stock wheels. Then to eliminate the problem you need to install a slightly longer front backing plate bolts. Don't get carried away as you could excessively limit steering.
Wildthings wrote:
Da TOW'D
Da TOW'D is offline
PostPosted: Wed Oct 25, 2017 1:06 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
Thanks
I was wondering if the "66 rims were the problem
cheers
Hank
'58 SC Ruf
'62 type 3 Notch
and NUTS
Da TOW'D
Da TOW'D is offline
PostPosted: Wed Oct 25, 2017 8:06 pm    Post subject: Re: What did you do to your Oval today? Reply with quote
any idea on the thread size on the front backing plate mounting bolts?
Hank
'58 SC Ruf
'62 type 3 Notch
and NUTS
nvmipis1
nvmipis1 is offline
PostPosted: Sun Nov 26, 2017 2:15 am    Post subject: Re: What did you do to your Oval today? Reply with quote
Detailed the engine! And car 😊
paf
paf is offline
PostPosted: Mon Nov 27, 2017 1:22 am    Post subject: Re: What did you do to your Oval today? Reply with quote
Shocked What a beautiful car...
Fred
Euro '58 L334 bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=657333
Page 51 of 58
