VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9961 Location: Huntington Beach, CA
Posted: Wed Jun 17, 2020 3:46 pm Post subject: Re: What did you do to your Oval today? |
SurfsUP wrote: |
Mahalo!
Here's a recent one where I finally installed the period correct bumpers that I've been saving in storage for 10 yrs.
Very nice! Your garage looks like mine. Extra transmissions, extra engines, extra everything! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
SurfsUP Samba Member
Joined: June 16, 2007 Posts: 33 Location: Las Vegas, NV
Posted: Thu Jul 02, 2020 5:46 pm Post subject: Re: What did you do to your Oval today? |
Test fitting my new steering wheel that i had sitting around for like 10 yrs.
finster Samba Member
Joined: May 26, 2012 Posts: 7935 Location: north o' the border
Posted: Wed Aug 12, 2020 11:58 am Post subject: Re: What did you do to your Oval today? |
we had some mega thunder storms over edinburgh last night and 3 plus hours of torrential rain. had to spend the day baling 'brown' water out of my oval and sweeping out the garage! luckily the door seals are still good and kept the water out but some got in through the heater pipes (have had to remove the silencer wadding to dry it out)- plus I was able to leave the car in the hot sun all day to dry out
_________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
donny273 Samba Member
Joined: September 08, 2004 Posts: 50 Location: Massachusetts
Posted: Sat Aug 29, 2020 7:35 am Post subject: Re: What did you do to your Oval today? |
trying to figure out battery strap mounting. Anyone have a photo of a stock 56 battery strap setup. Many thanks |
Posted: Sat Aug 29, 2020 8:03 am Post subject: Re: What did you do to your Oval today? |
strap on my 56 looks like this
bolt fixing to rear of battery and welded plate on floor in front of battery that the loop of the strap hooks into.
Posted: Sat Aug 29, 2020 2:00 pm Post subject: Re: What did you do to your Oval today? |
Excellent! I have the strap, just need to make the little piece it clips into. Does the strap bolt into one of the body hold down bolt holes along the back ? Many thanks. |
ernstben Samba Member
Joined: April 30, 2005 Posts: 621 Location: Manchester, Mi
Posted: Sat Aug 29, 2020 6:40 pm Post subject: Re: What did you do to your Oval today? |
donny273 wrote: |
There's a threaded stud for the rear mount. I got that stud and the front mount from WW:
_________________ Ben
'63 Ghia Coupe Project
'59 Panel Project
'56 Ragtop Project |
Posted: Sun Aug 30, 2020 6:12 pm Post subject: Re: What did you do to your Oval today? |
Perfect thanks so much. |
Posted: Fri Oct 02, 2020 4:04 pm Post subject: Re: What did you do to your Oval today? |
Engine in soon for first time for me with this 56 basket case. Can anyone post a pic of the firewall/front engine compartment seal. It is a single lip seal as supplied by WW. I need to know orientation. Thanks |
JoeyJo Samba Member
Joined: November 07, 2020 Posts: 1 Location: Las Vegas
Posted: Sat Nov 07, 2020 7:05 pm Post subject: Re: What did you do to your Oval today? |
I Brought her home today! No pan/No vin tag what year do you guys think she is?
Posted: Sat Nov 07, 2020 7:19 pm Post subject: Re: What did you do to your Oval today? |
JoeyJo wrote: |
55, 56 or 57. The rear wheel well is different than 54s.
The steering wheel is a late model Bug, around 70.
That was a quick look! Good luck! _________________ Jimbo
TDCTDI wrote: |
my56samba Samba Member
Joined: July 01, 2017 Posts: 100 Location: victoria b.c.
Posted: Sun Nov 08, 2020 9:48 am Post subject: Re: What did you do to your Oval today? |
It is not a 55model year as the doors aren't ribbed so a 56 or 57. 56 models started production in August 55. 56 and 57's don't have many differences. On Dec 19th 56 they moved the heater vents back from near the very front of the heater channels back towards the door. your pictures don't show this area but not all 57's are back as production of 57 model year started in Aug 56. Is there a body number stamped in the front apron in-between the upper parts of the white painted 5 and 3 on your car. you can check with the VIN/Chassis numbers listings in the Samba's technical section. Good luck with your new project! _________________ Dec 54 Ragtop Beetle
April 56 Baja Bug
June 56 23 Window Samba |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Posted: Sun Nov 15, 2020 7:48 pm Post subject: Re: What did you do to your Oval today? |
I haven't driven the car since May and today it had no spark. Fortunately, it was an easy fix by cleaning the points and rotor. Now that the weather is getting cooler and the nearly daily rain (and hurricanes and tropical storms, like the one we had a couple days ago) are beginning to subside, I'm looking forward to driving it again I should find out where that wire hanging on the left side of the engine compartment goes
_________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
upwardr Samba Member
Joined: October 23, 2005 Posts: 52 Location: Hamilton, Ontario Canada
Posted: Thu Nov 26, 2020 6:25 pm Post subject: Re: What did you do to your Oval today? |
Jimbo , you stated the wheel wells in a 54 are different than 56 and up.
How so? Looks the same |
aa390392 Samba Member
Posted: Mon Nov 30, 2020 6:41 pm Post subject: Re: What did you do to your Oval today? |
upwardr wrote: |
Jimbo? Yes please enlighten us. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Fri Dec 25, 2020 6:37 pm Post subject: Re: What did you do to your Oval today? |
Christmas day drive Manhattan Beach, El Segundo.
_________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Fri Dec 25, 2020 9:08 pm Post subject: Re: What did you do to your Oval today? |
aa390392 wrote: |
upwardr wrote: |
Jimbo? Yes please enlighten us. |
Here you go. Sorry, I do not check this thread often.
From my time playing with Bugs, this is one key feature I always check for. Even side to side on the same car, as the later inner fender wells are readily available, but the earlier ones are not.
54 and down is smooth, like this.
It changed in 55, somewhere. Not sure when. But here is a 56 for reference.
See that large squared edged intrusion at the inner front. That’s the change. _________________ Jimbo
TDCTDI wrote: |
Posted: Sat Dec 26, 2020 12:01 pm Post subject: Re: What did you do to your Oval today? |
Thanks Jimbo, took me a while to see it in the photos but I get it. My 54 is so bad in this area I would not have noticed.
Will try to make mine into a 54 style. I did receive a used shock tower area with package shelf attached and the shelf is different on my car. They must have changed the stamping sometime after 54 by about 5/8” in the rib stamping. |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1321 Location: Bella Coma Canada
Posted: Sun Jan 03, 2021 6:09 pm Post subject: Re: What did you do to your Oval today? |
Our '57 BlackBerry bug has been hard to start. I had the chance to put it the shop and see what was wrong.
I hooked up a remote starter switch so I could start it while looking at the engine.
Lucky I did
I saw that there was fuel leaking from the accelerator pump cover on the Solex 28 PCI. Spraying on the distributor.
I pulled the cover and lapped it with valve grinding compound . Figure 8's on a plate of glass.
notice the bare section on the inside of the cover.
about 15 minutes worth of lapping did the job.
I put it back together and no leaks. I'll be more careful not tightening the 4 screws too much.
but it still started rough. I have the electronic points replacement and good spark.
so I pulled the cap and found the rotor sat on the distributor shaft pretty sloppy. Somehow the bakelite tang inside of the rotor had snapped off
I found a good used rotor in my parts collection.
big difference starts up much easier
cheers
Hank _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS |
