WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Sat Aug 08, 2015 11:44 pm Post subject: |
insyncro wrote: |
So other than Swepco, what products are offering equal protection...for Vanagon trans/diffs??? |
I opted to use Lubrication Engineers tranny fluid in one of my syncros due to strong recommendations from a well known local syncroist who had been using it for years in his syncro fleet running with subie 2.5L's and SVX's, and he's a expert syncro off-roader (meaning challenging to his trannies).
I know it's been mentioned before in past tranny lube discussions but don't recall where nor do I really have any info on specs and suitable application other than the tranny (mine) with that seems to be doing well. Perhaps one of you tranny gearheads can comment on it's merits or demerits as I'm not up on the latest trends. |
insyncro Banned
Posted: Sun Aug 09, 2015 3:24 am Post subject: |
WestyBob wrote: |
insyncro wrote: |
Thanks, I'll look into it. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Sun Aug 09, 2015 12:14 pm Post subject: |
Lubrication Engineers 9919 is one of the few synthetics I've recommended in the past. A fair number of Porsche shops now use 9919 for street and 9920 for track. Some of my high performance VW friends use LE's dino trans lubes, which are probably on par with Swepco.
Lubrication Engineers website also has some great articles about synthetic vs dino oils, explaining how the public was sold on using anything labeled "synthetic" .. worthwhile reading. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
insyncro Banned
Posted: Sun Aug 09, 2015 12:18 pm Post subject: |
And thank you Gears, didn't know they had dinos.
Sweet, gotta check it out. |
Merian Samba Member
Posted: Sun Aug 09, 2015 12:38 pm Post subject: |
gears wrote: |
Concept #1 .. There is no “perfect” oil.
VW technical bulletin from 1973:
“The composition of a transmission oil has a varying effect on the service life of different parts of the transmission. For example, oils which increase the life of synchromesh units have the opposite effect on the ring and pinion. The selection of the correct transmission oil is, therefore, always a compromise between requirements which are often in complete opposition.”
This is interesting for those of use with only a diff. (A/T Vans).
Thoughts on the best product for the diff.? |
Vanagon Nut Samba Member
Posted: Wed Dec 30, 2015 8:05 pm Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
Just to report back in.
Ran Lucas synthetic and mineral. Shifting got so bad, especially when colder or when bus sat a while, I could barely get it in 2nd. After driving a while tranny typically shifted ok but not really smooth.
Just swapped in Redline MT90. Right after it went in, engine off not run, noticed an immediate improvement in shifting. Before, it was hard to run through the gears engine off. It also now shifts MUCH better. Hopefully it will shift well tomorrow. It's been colder here lately.
I may try Brad Penn "Classic" GL4 next change. This has been discussed ad nauseam but GL4, not GL5 "ok for GL4" seems to make the big difference. _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
zak99B5 Samba Member
Joined: December 21, 2014 Posts: 471 Location: Albany, NY
Posted: Wed Dec 30, 2015 8:23 pm Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
Vanagon Nut, I had used the Lucas GL-5 (before I knew better) in my MkIV GTi and also experienced poor shifting. Going back to GL-4 fixed it right away. _________________ 1991 Tintop GL Manual tranny, EJ22 |
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Wed Mar 02, 2016 9:43 am Post subject: BG Ultraguard PN750 |
hmm. well, i just bought some on this https://www.bgprod.com/catalog/drive-line/bg-ultra-guard-full-synthetic-gear-lubricant/ from a local service centre. $40 per quart! so, $160 for an transaxle oil change!?!
wtf!
i was going to buy 8 bottles to have an extra change on hand, but i walked out with 4 still feeling stung.
_________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
Surfy Murphy Samba Member
Joined: September 05, 2013 Posts: 139 Location: Brooklyn, New York
Posted: Wed Mar 02, 2016 9:50 am Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
I've been having a hard time shifting into 2nd from first, mostly when the van is cold ever since replacing my shifter and redoing the linkage bushings. Ive since then replaced the shifter with a bigshot but 2nd is still a little grindy and stiff going in. This is with a 2.5 subie.
I just switched from redline to royal purple 75w90. It made a small difference in shifting, but not much so I'm back to double clutching 2nd. My next guess is to bleed the clutch and see if that helps.
One thing worth noting... The trans had about 15k miles and the old fluid came out full of metal. Im pretty gentle with my shifting, and I'm wondering if royal purple was a good idea or if I should be switching out to swepco 210. Thoughts?
I already have a trans sitting at AA for an eventual rebuild but I want to see if I can make this one last as long as possible. _________________ 1987 Orly Blue Sunroof Syncro, EJ25 |
Posted: Thu May 19, 2016 5:05 pm Post subject: Re: BG Ultraguard PN750 |
That is the soup that German Transaxle is requiring these days. Paid a lot of bucks for some and when I filled the box with it the shifting went to $hit. Only left it in there for a couple of thousand miles before going back to a dino GL-4 oil. The tranny shifts better now with the GL-4, but not as well as it did before I tried the Ultra Guard.
That was an awful lot of moola for something that just got recycled in short order, hope you have better luck with it. |
Brunswicken Samba Member
Joined: March 29, 2011 Posts: 32 Location: QC, Canada
Posted: Sat Jul 09, 2016 5:25 am Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
Anyone use this Valvoline synchromesh compatible oil?
not sure what the viscosity rating is yet, but is recommended for use in GL4 transmissions.
Posted: Sat Jul 09, 2016 6:59 am Post subject: Re: BG Ultraguard PN750 |
Wildthings wrote: |
yeah, it is still going and my shifting is ok but not particularly smooth. smooth like cold butter, perhaps?... _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
Posted: Sat Jul 09, 2016 7:10 am Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
Brunswicken wrote: |
read through the oil nerd thread over here, and it sounds inconclusive, but maybe ok, but maybe too thin. http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3066666 _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Sat Jul 09, 2016 7:51 am Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
I switched Redline to Mobil Delvac 75-90 synthetic and I am very happy with it. Nice smooth shifting, behaves the same hot or cold. I never had any issues with Redline, but with all this speculation, I thought I would try something else. I initially tried the Amsoil GL4 synthetic and it felt terrible (didn't seem to handle heat well). |
westiedriver Samba Member
Posted: Sun Jul 10, 2016 5:03 pm Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
Got my oil changed at the dealer, they put in 3 liters of 070 something can't remember all the numbers. They were 1 liter VW bottles and grey in color with no API or oil weigh looked like water. Anybody know if this is good stuff . Gears are working good with my 2.5 subaru |
Posted: Sun Jul 10, 2016 5:31 pm Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
westiedriver wrote: |
Sorry the adage "garbage in, garbage out" applies here. If you want a useful answer you need to find out exactly what oil was used. |
Posted: Sun Jul 10, 2016 6:06 pm Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
The dealer doesn't know, they looked in their computer and they had 3 bottles of it in stock for standard 4 speed. No I.D. on bottle, mostly German instruction. Will try to find out more info. |
Posted: Wed Jul 13, 2016 4:47 am Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
Got more info, I got VW G 070 726 A2 put 3 liters in and the gears shift like butter.
Mike |
Franklinstower Samba Member
Posted: Wed Jul 13, 2016 9:23 am Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
Mike |
That's A3 / A4 gear oil I run in my jetta TDI. I think it is a 5/30 weight. I don't know if it has EP properties or hypoid rating....And most likely a GL5 oil. Typical Dealer, they just put in whats on the shelf.... _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
Posted: Wed Jul 13, 2016 10:09 am Post subject: Re: Red Line MT90 Getting a Bad Rap? Conflicting Opinions |
Hope not, this is A2 anybody know what weigh it is? |
