71/72KGER Samba Member
Posted: Tue Jul 14, 2009 11:03 pm Post subject: Transmission Nose Bug to Thing |
I just bought a 73 Thing it needs a trans and engine I have the engine I am looking at a trans and the guy thinks it ma have come out of a Thing the part # is 113 301 103k AT 30 104 from what I understand the nose on the Thing and Bug are diferent and not interchangable.
How can you tell the diference and where can I buy a Thing trans nose?
Thanks 71/72Kger |
yellow73kubel Samba Member
Joined: August 17, 2008 Posts: 789 Location: Columbia, SC
Posted: Wed Jul 15, 2009 7:26 am Post subject: |
An AT transmission code means that is from a Super or Cab 8/72 or later, not an AV code Thing transmission. Gear ratios should be the same, except for a 3.875 final drive rather than 4.125 (more torque for a Thing).
As for the nose cone, I can't really help much there. I haven't stumbled across any for sale, but haven't looked for them, so.. |
SilverThing Samba Member
Posted: Wed Jul 15, 2009 8:21 am Post subject: |
Nose cones are commonly available in the classifieds. Someone more knowledgeable should chime in, but I believe that the nose cones that Things use are the same as 73 and later beetles. |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Wed Jul 15, 2009 9:57 am Post subject: |
Things use the nose cone AND mounts from the 1972 and earlier Beetle. One would think they used the 73 up as the years match, but they don't. The late Beetle mounts are VERY soft. So any way, a quick search through the gallery and I found....
.... A pic of an early (pre 73) nose cone, note the TWO mount holes on the left, the nose cone is being held sideways, the mount holes are bellow the shift rod.
I could not quickly find a late nose cone, but is has THREE mount holes in a triangle configuration.
The nose cones are interchangeable AND are available NEW. If you'd like PM me for details.
Eric _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
Bruce Samba Member
Posted: Thu Jul 16, 2009 10:31 pm Post subject: |
yellow73kubel wrote: |
An AT transmission code means that is from a Super or Cab 8/72 or later,.. |
Also came in Standard Beetles with IRS and a 1600. _________________
SHawkins87 Samba Member
Joined: January 07, 2009 Posts: 16 Location: Georgetown, KY
Posted: Fri Jul 17, 2009 7:31 am Post subject: |
I just swapped out the transmission in my 74 Thing with a rebuilt one that was in a 72 Beetle. I had to transfer the drive flanges from the Thing to the Beetle transmission. Everything else just bolted right up. I didn't even have to adjust the shifter! |
