joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Wed Jul 15, 2009 10:40 am Post subject: Inverters |
I know there's been a lot of talk about the merits (or lack thereof) of wiring an inverter into your dual battery setup, but I decided that I might need the AC power at some point during the trip I'm about to take, so I did some checking and found this one at Radio Shack:
http://www.radioshack.com/product/index.jsp?productId=2194431
350W, a mere $20 until Saturday. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Wed Jul 15, 2009 10:59 am Post subject: |
Should work fine, I have a 300 Watt (600 surge, like the one you linked) one that I got for $20 from a truck stop, charges cameras, laptops, etc... And it will run a stick blender too on lower speed settings so we can have blended soup and smoothies at the campground _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
scobax Samba Member
Joined: July 27, 2007 Posts: 236 Location: Bend, Oregon
Posted: Wed Jul 15, 2009 11:30 am Post subject: |
Joe,
That looks like a pretty good deal, you can't go too terribly wrong for that price. Wiring the inverter to the aux battery is a good way to go, and fairly straight forward to do.
FWIW, here are some unsolicited notes;
While the output wattage is an important factor, so too is output amperage. If you are intending to run anything that might have a heating element, or draws alot of amps, you may want to check the amp draw for each device to see if the inverter will put out enough amperage. It sounds like you are just thinking about basic 110 devices like laptops etc. so you should have plenty of overhead with that 350w unit.
If you are planning to run just a laptop with the inverter, you may find that a more efficient option with regards to battery consumption would be to get a 12v power cable for your laptop. This way, you will use a lot less current while running your computer since computers run on 12vDC already, and to plug one into an inverter consumes more energy by inverting the current to 110AC, then back again via the small inverter placed inline on laptop power cables. That being said, it may be cheaper/easier to buy this $20 inverter than the 12v cable for your laptop (if you can even find one), plus the inverter gives you a new set of options for running/charging other 110 devices.
I mounted my inverter inside of the cabinet under the sink, and ran the cable to the aux. battery from there. I then took a piece of extension cord and plugged it into one of the inverter ports then ran it back to the 110 outlet on the lower cabinet near the bed. Now, one of the outlet ports is powered from the inverter and the other one is wired to shore power. Works like a charm. _________________ 87 Syncro Westy w/ Suby 2.5
RIP: 2.1 WBX. You were a good dog 'ol feller
“The word adventure has gotten overused. For me, when everything goes wrong, that's when adventure starts” -Yvon Chouinard
"It's not expensive, its priceless" -Unknown |
fairweather Samba Member
Joined: August 26, 2007 Posts: 663 Location: Aspen, CO
Posted: Wed Jul 15, 2009 5:57 pm Post subject: |
I've got that very unit. I rarely use it but when I do for a computer and to charge 18v flashlight batteries it does the job. I just plug it into a 12v jack. |
camundson Samba Member
Joined: August 24, 2009 Posts: 5 Location: New York, NY
Posted: Sun Jun 13, 2010 1:14 pm Post subject: 110AC outlet; one from shore power, one from inverter |
scobax wrote: |
I mounted my inverter inside of the cabinet under the sink, and ran the cable to the aux. battery from there. I then took a piece of extension cord and plugged it into one of the inverter ports then ran it back to the 110 outlet on the lower cabinet near the bed. Now, one of the outlet ports is powered from the inverter and the other one is wired to shore power. Works like a charm. |
Hi, just wondering if you could elaborate on both how/where you ran the extension cord back to the 110AC outlet and how you connected one of the ports to the cable from the inverter. This sounds like a great setup, I'd love to run my inverter like this!
Thanks!! |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9800 Location: Mt Lemmon, AZ
Posted: Sun Jun 13, 2010 3:27 pm Post subject: |
fairweather wrote: |
...for a computer and to charge 18v flashlight batteries it does the job. I just plug it into a 12v jack. |
That's what I do too. A 'cigar lighter' plug with a couple of open lugs on the other end does it.
Since my aux battery is under the rear seat the converter just sits next to it and plugs into a lighter socket in the side of the box.
Not the most efficient way (comapred to using 12V when you can) but so handy. |
smokin_dodge Samba Member
Joined: April 06, 2008 Posts: 169 Location: East Texas
Posted: Sun Jun 13, 2010 5:28 pm Post subject: |
Looks to be a good deal
2.9Amps @ 120 volts or
3.18Amps @ 110 volts
volts x amps = watts
should be more than capable to run a laptop and anything smaller - my Beast of a laptop - 2004 toshiba with 2 processors only pulls 1.8amps.
and you can do just about anything technologically with today's laptops |
Volksaholic Samba Member
Joined: December 26, 2005 Posts: 1771 Location: Salt Lake City, Utah, USA
Posted: Sun Jun 13, 2010 9:41 pm Post subject: |
I've got a 300 Watt (not that brand) and a quick connect that I can hook it straight to the battery. That did the job for charging phones, computers, batteries a couple years ago on a trip to CA, but it's not enough for me to run a blender to make margaritas! That's not the end of the world, but it's a fun treat for the kids when camping (non-alcoholic for them, of course).
I'm still in the process of putting my Wolfsburg back on the road, but I grabbed a dead 500 Watt UPS from work and I'm going to wire (or try) its inverter to the car battery. While I'm at it I might see if it's got the oomph to trickle charge the car battery, since it's got the charging circuit for the UPS battery. If I fry it, I'm out nothing. In fact, I've since acquired an 800 Watt with a dead battery... it would be nice to have the reserve power if I need it, but for charging phones and running laptops you don't need much more than 100 Watt.
Paul _________________ 1988 Wolfsburg Edition, 2001 Subaru EJ251 |
