* SOLVED * Engine cranks, but don't turn over. (+ video)
NCdad
NCdad is offline
PostPosted: Sat Jul 18, 2009 4:12 pm    Post subject: * SOLVED * Engine cranks, but don't turn over. (+ video) Reply with quote
OK, my wife was driving home and engine sputtered and died... she pulled over and called me...
Got it home, and just needing to see if I am going in the right direction
Here is what's going on...
Here is what I have done so far...
    Checked Gas... Guage Shows just over 1/2 tank... added some more to be sure...
    Checked fuel filter no debris in it...
    Checked Battery w/ Multimeter ... reads 13.5
    Made sure all connections from Coil are snug and connected
    Checked Coil terminal w/ multimeter where red wire goes to auto choke...
    Reads 12.8
    Green wire from coil to Distributor - no reading... Is this right?
    Checked plug wires to see if there is spark... YES, I got spark.
Checked the Fuel Pump
* No fuel from Pump to Carb ( bowl was empty too )
took, carb off... and cleaned all jets / needles
EDITED TO ADD:
** mnussbau's eye caught that the pin at the base of the pump has backed itself out. ( thanks again )
Peened it back in.
finished cleaning everything, new gaskets for Carb...
installed and sprayed a little starter fluid in the carb,
she fired over and died...
sprayed a little more and she fired and ran....
adjusted the volume control and the idle richness screws...
Hope this helps others in the future if you have problems.
ROBERT
My VWs & Projects - | - German Invasion VW Show - Sept 7, 2024 Shelby, NC
Randy in Maine
Randy in Maine is offline
PostPosted: Sat Jul 18, 2009 4:13 pm    Post subject: Reply with quote
Put that dwell meter on the green points wire and see what it says.
NCdad
NCdad is offline
PostPosted: Sat Jul 18, 2009 4:21 pm    Post subject: Reply with quote
not sure I really understand ...
this is what I am using... actually first time using it also.
OK....
Looks like your refering to this...
https://www.thesamba.com/vw/gallery/pix/558459.jpg
I don't have one of those... so I guess I get an excuse to but a new item.
ROBERT
MrUnix
MrUnix is offline
PostPosted: Sat Jul 18, 2009 5:08 pm    Post subject: Reply with quote
Smile
Best $1.99 meter around! I got a few of them.. keep one in each car.
As for your problem, since you have spark, it's most likely a fuel related problem. See if a squirt of starter fluid in the carb gets it to kick over.
Cheers,
Brad
NCdad
NCdad is offline
PostPosted: Sat Jul 18, 2009 5:28 pm    Post subject: Reply with quote
yea, my wife was thinking of me one day... LOL
I guess I can now put a value on that... j/k
I do keep it in glove box though...
I called around to FLAPS store and everyone has to order it... guess I will have it tomorrow. Sears closed at 6pm WTH?
ROBERT
NCdad
NCdad is offline
PostPosted: Sat Jul 18, 2009 6:03 pm    Post subject: Reply with quote
Alright, after trying to find a Dwell meter around here with no luck at the FLAPS...
I went out and sprayed some starter fluid in the carb.
it fired over for a few secs then sputtered out...
pulled the hose from the fuel pump to the carb and used the 21mm wrench to turn the gen. and nothing happened.
so that is where I am at...
Closer view:
ROBERT
Fattie
I'd roll it
Fattie is offline
PostPosted: Sat Jul 18, 2009 6:52 pm    Post subject: Reply with quote
fuel pump may have bunked out...have someone crank her over while your holding the line into a container...if you get fuel to that point....check the needle/seat valve...may be stuck shut....next... carb jet/jets may be clogged and just need a good cleaning
check your oil..is the level high..smell like fuel ?
the fuel pump diaphragm may have gave...thats a common issue with the mech. fuel pump
Donate and help me get another aircooled dub to share with you guys www.paypal.me/WhosCare
Scott H
Samba Luddite
Scott H is offline
PostPosted: Sat Jul 18, 2009 6:58 pm    Post subject: Reply with quote
Did you pull the top off the carb to see if there was any fuel in the bowl?
Scott
oc92 wrote:
I like the soul of an old car to be visible...
NCdad
NCdad is offline
PostPosted: Sat Jul 18, 2009 7:02 pm    Post subject: Reply with quote
No, have to do it tomorrow... the sun went down and no garage no more... Crying or Very sad
ROBERT
DonnieDarko
DonnieDarko is offline
Don't mean to steal your topic - but if your fuel pump is bad, do you always have gas in your oil or can you have a bad fuel pump and no gas in your oil?
1974 Volkswagen Super Beetle - Daily Driver/Rolling Project Beater - Stock w/ GT Style Exhaust
1972 Volkswagen Bus - Project
1970 Volkswagen Standard Beetle - Baja Project
I pick cheap and reliable.
NCdad
NCdad is offline
PostPosted: Sun Jul 19, 2009 3:47 pm    Post subject: Reply with quote
No fuel when trying to crank it over.
Oil level is between the marks on the stick... no smell of fuel.
Yes, no fuel in the bowl.
Update:
So I have the Fuel Pump off, as well as the Carb.
Is a rebuild difficult?
What do you use to clean it up? I SEARCHED but didn't see anything on specific clean up procedures...
Am I right to think its the Fuel Pump needs a rebuild?
ROBERT
NCdad
NCdad is offline
PostPosted: Sun Jul 19, 2009 3:57 pm    Post subject: Reply with quote
Is this the correct rebuild kit?
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D111%2D198%2D555
1600 DP
ROBERT
Fattie
I'd roll it
Fattie is offline
PostPosted: Sun Jul 19, 2009 6:09 pm    Post subject: Reply with quote
you can pickup a carb. rebuild kit at your loacal FLAPS
for cleaning..humm... maybe some carb. cleaner ? Wink
NCdad
NCdad is offline
PostPosted: Sun Jul 19, 2009 6:14 pm    Post subject: Reply with quote
LOL can you use that on the fuel pump...
I am talking about grime and grease on the outside...
ROBERT
mnussbau
mnussbau is offline
PostPosted: Sun Jul 19, 2009 6:47 pm    Post subject: Reply with quote
NCdad wrote:
Closer view:
Hard to tell but it looks like the pin at the base of the pump has backed itself out. If so it won't pump anything. Take a closer look. The rebuild kit you linked to includes a new pin and c-clips.
Mike
Sold my sedan
Parts...
connella08
connella08 is offline
PostPosted: Sun Jul 19, 2009 7:20 pm    Post subject: Reply with quote
didnt see that until you mention it and that looks to be the exact problem. look around on the top of the case for the pin that goes to to pump.
Scott H
Samba Luddite
Scott H is offline
PostPosted: Sun Jul 19, 2009 7:27 pm    Post subject: Reply with quote
I've never rebuilt a fuel pump but have rebuilt several carbs. It's very easy and straight forward. The rebuild kit should come with an instruction sheet. Just be sure to have access to compressed air so you can blow the passages and jets out well.
Scott
Rob Timmons
Rob Timmons is offline
PostPosted: Sun Jul 19, 2009 8:05 pm    Post subject: Reply with quote
When you do rebuild the pump there is a special way to do it. The lever that the pump rod engages (that pivits on your missing pin) has to be depressed before bolting the diaframe together. This sets a certain amount of load on the pump. I'm not sure of amount check a Bentle manual.
freeonthree
freeonthree is offline
PostPosted: Sun Jul 19, 2009 8:40 pm    Post subject: Reply with quote
It would be easier to just loosen the bowl plug on the left side of the float bowl.
Before you replace the fuel pump, make sure you don't have a bad hose between the pump and the tank, sucking air instead of gas.
Run a hose from the pump inlet and stick into a can of gas, then see if it pumps. If it does, look for a bad fuel line to the tank, or to the pump inlet.
Happiness is a VW Trike...
Until it rains, then it's a shower chair.
NCdad
NCdad is offline
PostPosted: Sun Jul 19, 2009 10:04 pm    Post subject: Reply with quote
I took the Fuel pump of and snapped a couple closer pics, are you refering to the hole in the middle area?
And the other side...
ROBERT
