1959 or 1960 VIN help
Thndr1
Thndr1 is offline
PostPosted: Tue Jul 21, 2009 8:00 am    Post subject: 1959 or 1960 VIN help Reply with quote
Hello all,
I am having difficulty finding the correct year for my convertible.
VIN 2577***
http://www.inerd.it/index.php?option=com_content&task=view&id=21&Itemid=32 says it September 1959
Samba chart says July 1959
http://www.lightner.net/ybdb/serno.html says 1960
I have the service manual for 1958 to 1960. I find that most things match the 1959 model... ie. manual choke (disconnected) and 2 seperate fuse blocks under hood. Maybe it is a 1959 on a 1960 frame??? Any help would be appreciated.
thanks
Thndr1
gt1953
gt1953 is offline
PostPosted: Tue Jul 21, 2009 1:15 pm    Post subject: Reply with quote
you think one of them is correct.
72 type 1
72 Squareback
AlteWagen
Troll
AlteWagen is offline
PostPosted: Tue Jul 21, 2009 1:29 pm    Post subject: Reply with quote
The 59 and 60 models are very similar, the only differences that are obvious are the door handles (59 icepick) and the rear snubber on the shock horn (60 has the snubber stop), the steering wheel can be changed but the 59 has the off set batwing and the 60 has the later dish type. Most 60s ive seen already have the one year only front trans mount modified to the later type.
Just by what youve posted, if it is a July 59 and later it is a 60 model year vert. Judging by your pic it is a 60.
Thndr1
Thndr1 is offline
PostPosted: Tue Jul 21, 2009 3:06 pm    Post subject: Reply with quote
the problem is the 2 fuse blocks. i only see diagrams for '59. all the 1960 i see is the single
AlteWagen
Troll
PostPosted: Tue Jul 21, 2009 3:55 pm    Post subject: Reply with quote
I had the same problem on my august 59 (60 model year). I had to order a new harness and when I looked at the diagrams they did not match what I had. I ended up ordering the 59 harness and it worked fine. It seems there is some run over on parts from the factory sometimes and they use up parts they already have from the previous year until they run out, then start with the new stuff.
BTW does the pan match the body tag? What about the snubber and front trans mount? the mount is the definite way to tell.
PostPosted: Tue Jul 21, 2009 5:01 pm    Post subject: Re: 1959 or 1960 VIN help Reply with quote
Thndr1 wrote:
Hello all,
VIN 2577***
The charts on this site also say September, 1959 for 2577xxx. This is the 1960 model year so everything is in line with a 1960 Convertible.
Thndr1
Thndr1 is offline
PostPosted: Tue Jul 21, 2009 5:05 pm    Post subject: Reply with quote
i know about the tag under the rear seat but on the body itself where is that one? i am used to the vin tag in the window
kafer60
kafer60 is offline
PostPosted: Thu Jul 23, 2009 10:51 am    Post subject: vin tag Reply with quote
Your vin tag should be behind the spare tire beside the brake fluid resrvoir.
Thndr1
Thndr1 is offline
PostPosted: Thu Jul 23, 2009 1:17 pm    Post subject: Reply with quote
i have a tag but there is no number that matches. the longest number is 1100. nothing 7 digits
Found it. The numbers match the pan, thanks
