Show off your engine bay! - Post your pics!!
Page: Previous  1, 2, 3 ... 63, 64, 65, 66  Next
dubsteez79
dubsteez79 is offline
PostPosted: Mon Jul 22, 2019 7:45 am    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
flat4olsen
flat4olsen is offline
PostPosted: Mon Jul 22, 2019 8:37 am    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
Type 1 1968, Lotusweiss. 2109 oxyboxer engine
Early Bay 1970, Montana Red. Under construction
baz76
baz76 is offline
PostPosted: Mon Jul 22, 2019 9:07 am    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
manoteal
manoteal is offline
PostPosted: Sat Aug 17, 2019 4:39 pm    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
1969 bug with 1973 block, Stock Dual-port with heads/valves done by friend who has machine shop- guides replaced and seats/valves ground to spec.
34 PICT-3 rebuilt by Keifernet with rebushed throttle shaft and riveted plate hole. This one was on my Super beetle before I crashed that car in 2012.
AirCooledNet SVDA Distributor with Pertronix I from 2010- Still like new!
Stock Muffler with original German heater boxes.
VW Paradise (now Paradise Motorsports) of San Marcos bottom end- fixed spun bearing on #1 and polished and put in new Silverline bearings on crank/rods.
Replaced terrible cheap flywheel with good German one from Interstate Auto in Lake Elsinore.
Blue Coil (Brazil) painted black for ‘stealth’.
Got original air cleaner for 1973 from classifieds here.
Valve on vacuum line to air cleaner thermostat is to shut off hot air to carb on hot days (thermostat flap works but stays closed- hot air- all the time due to stuck thermostat). I leave it open to warm up the car and then shut it off after the motor is hot. On cool days or night driving I just leave it open (Preheat on).
Uses ‘waste air’ gauge under cylinders for temperature sensing. Dipstick sender bent and put through grommet in rear tin hole and under #2 cylinder.
Has Flaps and thermostat for proper warm up.
With stock ‘69 unvented engine cover- I use 3” modified ‘tennis ball trick’ for cooling.
Runs like a top with 27MPG average City/Hwy at 60 MPH on freeway.
Comments welcomed.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Aug 17, 2019 5:02 pm    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
Tim Donahoe
Tim Donahoe is offline
Looking good. The only thing I’d change is getting a new air-cleaner thermostat. I believe Rock Auto still sells them for the Rabbit, which is the same as on our later Bugs.
Tim
Let's do the Time Warp again!
Richard O'Brien
RailBoy
RailBoy is offline
PostPosted: Sat Aug 17, 2019 5:06 pm    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
Check out the Carbs, not many doing that, maybe not until now! lol... RB
[quote="slalombuggy"]
smitty24 wrote:
"HELP, I ported my own heads and now have fire coming out my ass" .
Shocked
sb001
sb001 is offline
PostPosted: Sat Aug 17, 2019 5:08 pm    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
1969 autostick sedan, owned since new
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Mr. 010
Glenn is offline
PostPosted: Sat Aug 17, 2019 5:10 pm    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
Glenn
manoteal
manoteal is offline
PostPosted: Sat Aug 17, 2019 5:10 pm    Post subject: Engine bay Reply with quote
Thermostat on order.
Bought all new hoses and wires and plugs-
Ready to go soon with upgrades!
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Aug 17, 2019 9:21 pm    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
Bill
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
calvinater
calvinater is offline
PostPosted: Sun Aug 18, 2019 3:01 am    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
Tim
Got a part number for that?
"War...War Never Changes"
"three is the magic number"
manoteal
manoteal is offline
PostPosted: Sun Aug 18, 2019 3:58 am    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
Rock Auto-VW 038129828=$86.29 Gr
“ VW 035129630B= $98.79 Bl
AutoZone SU8153=$71.99 Gr
“ SU8654=$137.99 Bl
O’Reilly. ATS35=$64.99 Gr
Express OEM PARTS 035-129-630B =$84.23 Bl
“. 038-129-828= $78.87 Gr
(Has Lock plate and gasket too
Plate 113-129-830= $3.57
Gasket. 113-129-832=$1.67
Parts Vortex. 035-129-630B=$82.52 Bl
“. 038-129-828=$78.20 Gr
Clip and gasket same numbers and approx same prices here.
The two last ones are genuine VW shops so have clips and gasket if needed
Amazon has the thermostats, too. Try same numbers.
Gr= green body with plastic hose connectors.
Bl= black body ( like stock) and one brass and one plastic connector.
The O’Reilly one is the best value and same as the other Green ones.
On AutoZone and O’Reilly they say they will not work for 1973/74, but they do.
Hope this helps.
sb001
sb001 is offline
PostPosted: Sun Aug 18, 2019 4:01 am    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
Calvinater, try a google search for VW part number 113 129 828.
1600 SP engine
sb001
sb001 is offline
PostPosted: Sun Aug 18, 2019 4:30 am    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
“ SU8654=$137.99 Bl
Hope this helps.
Wow.
1600 SP engine
manoteal
manoteal is offline
PostPosted: Sun Aug 18, 2019 9:32 am    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
After reading all the links for all the parts and looking up all the vendors, I thought I would ‘share the wealth ‘ of what I found.
Enjoy!
Mark
Very Happy
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sun Aug 18, 2019 12:36 pm    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
1600 DP driven hard put away wet often. Very Happy
Life is short make it count
PostPosted: Sun Aug 18, 2019 12:48 pm    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
manoteal
manoteal is offline
PostPosted: Sun Aug 18, 2019 3:17 pm    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
What’s the difference between the green and black vacuum hoses?
The reason I ask is that the nipple on the intake manifold below the carburetor is larger than the nipple on the thermostat in air cleaner and I find it hard to get a ‘best fit’ on both.
Also, I have noticed that sometimes the black hose is conductive and sparks can be ‘grounded’ though its high carbon content?
Anyone else notice this and resort to rubber hose between air cleaner and manifold connection?
Thanks
1969 bug with original Riviera wheels- daily driver.
'73 1600 DP- AD case
Solex 34 PICT-3 Carb by Keifernet
Bosch 034 SVDA dizzy by ACN
(1990 Buick for parts runs)
Xevin
Xevin is offline
PostPosted: Sun Aug 18, 2019 4:27 pm    Post subject: Re: Show off your engine bay! - Post your pics!! Reply with quote
Not sure why VW used green hose. I was told by the boys at Avery’s Air-cooled that originally 73-74 bugs came with 2 green vacuum hoses Think
So that’s what I run.
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
Abscate wrote:
I dont hate anyone on the Samba - except for Xevin - who brought me cold coffee in the morning.
Page 64 of 66
