Batt. and Oxy. light on until 2 1/2 rpms over,lights go away
kimichihotdog
kimichihotdog is offline
PostPosted: Wed Jul 22, 2009 7:39 pm    Post subject: Batt. and Oxy. light on until 2 1/2 rpms over,lights go away Reply with quote
Batt. and Oxy. light on until I rev. to 2 1/2 rpms then it goes away.
Maybe wiring?
Any idea's?
Bruce Wayne
Bruce Wayne is offline
PostPosted: Wed Jul 22, 2009 7:44 pm    Post subject: Reply with quote
mine is the same. I think it takes up to 2500-2800 rpm's for the alternator to start charging the battery. or does it have something to do with the voltage reg? someone with more knowledge of these things should have a better answer.
vern-the-van
vern-the-van is offline
PostPosted: Wed Jul 22, 2009 9:17 pm    Post subject: Reply with quote
Not sure if this info is that useful to you but...
I am in an 81 cal. air cooled, and when I first start the engine my battery light will stay on until I gently touch the accelerator (to get to maybe 950rpm). After that the battery light goes out and stays out.
The age-old question. Are you grounds good and clean?
kevinbassplayer
kevinbassplayer is offline
PostPosted: Wed Jul 22, 2009 11:03 pm    Post subject: Reply with quote
Seems to be real common, same deal in my 87'
jackbombay
jackbombay is offline
PostPosted: Thu Jul 23, 2009 4:21 am    Post subject: Reply with quote
Thats what I've read a few times before, and when the light is on the battery is not being charged, quite a few 80's VWs do this..
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
tortuga
tortuga is offline
PostPosted: Thu Jul 23, 2009 5:46 am    Post subject: Reply with quote
My '85 does it too . . .
1985 Westfalia 1.9 WBX
Turk.380 Premium Member
Turk.380 is offline
PostPosted: Thu Jul 23, 2009 6:52 am    Post subject: Reply with quote
it's nothing more serious than the fact that alternators need to be spun at a minmum RPM to "excite the field" and get it charging. once the field is excited the RPMs can drop off some and it will continue to charge.
sometimes when we start our engines, it revs up enough in the startup onit's own to get the alternator going... other times when we start it's a nice gentle start and it's not spun up enough to get that field going.
or at least that's what I learned in my first year of the Sally Struthers Engineerin' skool! Yesterday I couldn't even spell enjineer, now I are one! Shocked
Brian W
St. Louis, MO
'64 SO-33 Hatch Top Westy | '87 Syncro Westy: Subaru EZ30D powered | 2002 VW Winnebago Vista
ValleyHappy
ValleyHappy is offline
PostPosted: Thu Jul 23, 2009 7:06 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=282982&highlight=
See Dogpilots reply to the same ? awhile ago.
09 Suzuki SX-4 Crossover
mightyart
mightyart is offline
PostPosted: Thu Jul 23, 2009 7:15 am    Post subject: Reply with quote
How many of you have an aux battery relay?
McVanagon
McVanagon is offline
PostPosted: Thu Jul 23, 2009 7:18 am    Post subject: Reply with quote
I have had my '85 for 17 years, and it has never flickered at low rpms.
I picked up my '87 two years ago, and it just started doing it earlier this year. It's charging, but just off idle it flickers.
I now read that it's somewhat normal, but it still drives be up the @#$&ing wall.
'69 Mike
'85 GL
'87 Wolfsburg Hardtop
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
Bruce Wayne
PostPosted: Thu Jul 23, 2009 8:38 am    Post subject: Reply with quote
I have the GW aux. battery kit.
McVanagon
PostPosted: Thu Jul 23, 2009 8:43 am    Post subject: Reply with quote
Yandina here.
'69 Mike
'85 GL
ValleyHappy
PostPosted: Thu Jul 23, 2009 8:48 am    Post subject: Reply with quote
I do not have an aux. battery relay, but I have not looked at the alt. regulator as Dogpilot mentioned to see if it solved this issue. Looks like a pretty inexpensive 'try'....if yours is replaceable.
kimichihotdog
PostPosted: Thu Jul 23, 2009 10:57 am    Post subject: Reply with quote
Ok guys, tried troubleshooting the wiring and it's correct. Changed alternator within a month ago with a regulator. Also, batt. only 1 year old but I drained that batt. 4 times and recharged it. I'm going to try to recharge the batt. again and have it fully charged to see if the light will go away.
We'll see Shocked
tortuga
tortuga is offline
PostPosted: Thu Jul 23, 2009 11:19 am    Post subject: Reply with quote
I have the old Gowesty kit (with the relays, not an isolator).
When I blip the throttle to get the batt light off I can here the relay under the seat click "on" at the same time as the light going off. FYI.
kimichihotdog
PostPosted: Fri Jul 24, 2009 8:54 am    Post subject: Reply with quote
Got the results and it didn't work. Well, I guess I'll have to trace the wiring again to the alternator. Crying or Very sad
kimichihotdog
PostPosted: Fri Jul 24, 2009 12:47 pm    Post subject: Reply with quote
IT'S Fixed!
Bad regulator.
The wire that holds the brushes in the alternator ripped.
So, I just fixed it.
Very Happy Very Happy Very Happy Very Happy
kimichihotdog
PostPosted: Tue Jul 28, 2009 12:57 pm    Post subject: Reply with quote
Back again and lights are off. Smile
Now, batt. can't crank Sad, has voltage.
Recharging.
Thinking I may need a new batt.
May not have enough cranking amps.
You think.
ValleyHappy
PostPosted: Tue Jul 28, 2009 1:05 pm    Post subject: Reply with quote
I have had a similar experience when a not so old battery just couldn't hold a charge. I don't know if it was just dropped in a strange way at some point or if it was just a factory defect. I replaced it with the same battery model and it has not been an issue since. Good luck.
