420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Wed Jul 22, 2009 10:12 pm Post subject: 1776 with dual 40 webers fitting engine compt problems |
i finally got my engine ready to pop in, ive done this over seven times so i know what's up. Well now i know why people cut the damn oil bath air cleaner stand off, flip originality!!, i want clearance!! im about to cut this shit off and call it a day. im installing a , i already beat the shit out of my shroud, and now the stand is going. is there any other way? i tried to bang it up so it would clear. but other than that, any solutions? 69 bus. _________________ once you realize im not impressed we will get along just fine |
59walkthru Samba Member
Posted: Wed Jul 22, 2009 10:18 pm Post subject: |
install the engine without the carbs installed. what is the deal is the fan housing hitting it? i can be done, It has been done. _________________ SGKent wrote:
take a photo of the shaft in the bore so we can see it, and one of your tool. |
Posted: Wed Jul 22, 2009 10:20 pm Post subject: |
sorry, the carb on the right is up against the stand, after looking at the bay/weber gallery pics i see not one with the stand. that shits going if there are no other ways. _________________ once you realize im not impressed we will get along just fine |
Lucas Grams Samba Member
Joined: July 19, 2005 Posts: 399 Location: watsonville
Posted: Wed Jul 22, 2009 10:37 pm Post subject: |
I don't have webers, but kadrons. I beat my stand and also cut the stand support metal. Only enough to move it out of the way. I could put it back should I ever need to. Just below the circular topis a ninety degree pressed piece. Cut 1\4 inch into each side of that 90 to enable the bend towards vertical |
Posted: Wed Jul 22, 2009 11:23 pm Post subject: |
good advise. _________________ once you realize im not impressed we will get along just fine |
Desertbusman Samba Member
Posted: Thu Jul 23, 2009 12:07 am Post subject: |
59walkthru wrote: |
install the engine without the carbs installed. |
And once it's in don't put on the carbs, because you can't.
I ground some welds and cut it at the bottom where it's welded to the frame. So you don't ruin the stand. Every once in a while people are trying to buy stands so they can return their bus to stock. If you totally get it out of there you will be happier. You will want as much room as you can possible get. _________________ 71 Superbug
71 Westy |
aryue Samba Member
Joined: January 16, 2006 Posts: 1027 Location: Austin, TX
Posted: Thu Jul 23, 2009 2:55 am Post subject: |
I'll second Desertbusman on this. If you clean up the base of the stand and look closely, you'll see spot welds. You can either drill out the spot welds or better yet remove them with a torch. The final result is that you'll have one valuable to someone else platform for the stock air filter. _________________ OldandSlow - but still chuggin.
http://www.ph.utexas.edu/~yue/VW/VWBus.html |
WestyPop Samba Member
Joined: February 08, 2005 Posts: 1732 Location: SoCal
Posted: Thu Jul 23, 2009 2:56 am Post subject: |
For the '68 Westy's Kads, the stand got a single cut across the vertical portion, thinking that a couple short pieces of flat strap and a few rivets or bolts could return it to a single 30PICT whenever needed. Having to do the 'factory-re-fit' dance every 2 years for the emissions tests, it worked out just fine. Always passed SMOG, but couldn't wait to get back in the shop to swap the Kads & 009 back on. (Terrible dizzy... haven't been able to get above 26.5 mpg average on trips when fully loaded with camping gear.)
OTOH Desertbusman's grinding & finishing probably looks a whole lot nicer, and this Westy will likely get that treatment as its motive power evolves further from the OG configuration. (SMOG Check tests N/R for <76 vehicles in Kaleefonia now, but the future could change that with just a handful of bribes in Sacramento.) _________________ Never underestimate the power of stupid people in large groups.
______________________________________
J.R.
68 Westy
(+ others) |
aryue Samba Member
Posted: Thu Jul 23, 2009 5:17 am Post subject: |
WestyPop wrote: |
For the '68 Westy's Kads, the stand got a single cut across the vertical portion, thinking that a couple short pieces of flat strap and a few rivets or bolts could return it to a single 30PICT whenever needed. |
That's a good method, too. With age and experience one learns there is a less barbaric modus operandi than bashing away on an offending piece of sheet metal with a hand-held sledge hammer.
Since I live in Texas - I won't comment on the powers that be at the California Air Resources Board. However, if you ever want to know where you can begin cutting your state budget, I'll be happy to offer advice on one state agency that you can cut from the budget.
Best Regards - Andrew in Austin, TX _________________ OldandSlow - but still chuggin.
Posted: Thu Jul 23, 2009 7:27 am Post subject: |
Desertbusman wrote: |
59walkthru wrote: |
I ground some welds and cut it at the bottom where it's welded to the frame. So you don't ruin the stand. Every once in a while people are trying to buy stands so they can return their bus to stock. If you totally get it out of there you will be happier. You will want as much room as you can possible get. |
if this bus is lucky, it may never go back. _________________ once you realize im not impressed we will get along just fine |
Blu67Bug Samba Member
Joined: March 01, 2004 Posts: 1011 Location: 50 Minutes N of the Big Apple
Posted: Thu Jul 23, 2009 8:40 am Post subject: |
Hey 420Goat, If you do manage to remove that Air Cleaner stand without destroying it, please let me know as I'd love to put that in my Bus.
A PO just cut part of the stand out at some point, maybe when he/she removed and replace the original engine with a "universal VW case". Anyway, I've had to run my Bus using an old Beetle Air Cleaner, not bad, but not original. _________________ '67s Rule & '71 Buses Too! |
theizzardking Samba Member
Posted: Thu Jul 23, 2009 10:09 am Post subject: |
not even going to read all the posts, i just cut my shit off after messing with it for so long got pissed and got an angle grinder...story over. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer" |
Posted: Thu Jul 23, 2009 10:45 am Post subject: |
is there anything else i should lookout for when breaking in this motor, of course i cant synch it so i have the screws turned out 2 1/2 under advise of the engine builder. im planning to connect my linkage and set the idle to run at 2k rpm. whatcha think? _________________ once you realize im not impressed we will get along just fine |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Thu Jul 23, 2009 11:01 am Post subject: |
In my 1971 bus I cut the stand off so that I could install the engine with dual kadrons. Here's some pics
These pics were taken after I got rid of the kadrons and went back to original. Notice the non-stock air cleaner.... _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Thu Jul 23, 2009 11:07 am Post subject: |
aeromech wrote: |
These pics were taken after I got rid of the kadrons and went back to original. Notice the non-stock air cleaner.... |
WHATCHA DO WIth the peice? nice pics by the way exactly what i was looking for. our busses are blues brothers. i dont want to lose it that is why i want to fold it down. may look fugly but what if my bus is worth something one day and the stand is the most sought after part? thanks 'Mech. _________________ once you realize im not impressed we will get along just fine |
Posted: Thu Jul 23, 2009 11:15 am Post subject: |
I tossed it. If I were you I would take it out and just hold onto it. If need be it could be welded back into place. BTW, I didn't realize the stand would interfere either until I tried to install the motor. I found out too that it's best to just leave one carb off during installation because otherwise it's too wide to lift into the hole. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Thu Jul 23, 2009 11:21 am Post subject: |
aeromech wrote: |
I tossed it. If I were you I would take it out and just hold onto it. If need be it could be welded back into place. BTW, I didn't realize the stand would interfere either until I tried to install the motor. I found out too that it's best to just leave one carb off during installation because otherwise it's too wide to lift into the hole. |
yeah just getting in the engine bay was pain. way different than installing a singleport. _________________ once you realize im not impressed we will get along just fine |
Posted: Thu Jul 23, 2009 11:30 am Post subject: |
420GOAT wrote: |
... it will get lost if i completely cut it off. |
Me too; that's why I have the air cleaner clamped to it & all the stock intake system & dizzy in an appropriately-labeled box... taped shut & up high on a back shelf in my shop! At least very inconvenient to lose, yet close at hand if the regulatory political winds change. Not to save that stuff is just crazy today, even if only for the 'next owner'. YMMV
420GOAT, it's fairly easy to feel like you'll keep a much-worked-over project vehicle forever, but it's just not practical; haven't had any of my vehicles for over 30 years... until next month! Good luck with yours. _________________ Never underestimate the power of stupid people in large groups.
J.R.
68 Westy
(+ others) |
volksterii Samba Member
Joined: December 01, 2006 Posts: 425 Location: San Diego CA
Posted: Thu Jul 23, 2009 12:04 pm Post subject: |
aeromech wrote: |
That's how I pulled mine out. It almost looks exactly like yours. However, I can get my motor in and out with both 40 dells on with air cleaners and all. It takes a little angling but it gets installed. _________________ 71 Westy Hardtop, 1915
2005 Touareg V8 air susp. |
Posted: Thu Jul 23, 2009 12:09 pm Post subject: |
Yeah, you go in at an angle and then raise the engine before turning it straight to mate with the tranny. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
