1200 rebuild / upgrade
BYeaton
BYeaton is offline
PostPosted: Thu Jul 23, 2009 6:04 pm    Post subject: 1200 rebuild / upgrade Reply with quote
Hey everyone. I have a 65' bug with a stock 1200 motor that I have recently had problems with and need to rebuild. I was debating for some time now to build a mild motor starting fresh with a 1600 case, but now I'm back to basics and I'm thinking I'll do the big bore kit with some rockers and a 30pict.
My question now is where to find a good set-up for the big bore 83 kit? I know you can find pistons and cylinders or rings or whatever else individually in the classifieds, but is there anywhere I can find a full setup?
All help is appreciated here so thanks in advance. The only other things to do are add some single port 1300 heads correct? but those are rare and expensive to find? Anything else let me know I'll use all the help I can get while I go through this motor.
Cheers
andk5591
andk5591 is offline
PostPosted: Fri Jul 24, 2009 4:15 pm    Post subject: Reply with quote
Hang loose - Andy (Glutamodo) should be chiming in any time now.......He knows 1200s really well.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
BYeaton
BYeaton is offline
PostPosted: Sun Jul 26, 2009 1:17 pm    Post subject: Reply with quote
anyone . . . I'm looking to get started on this asap
Howard Sanson
Howard Sanson is offline
PostPosted: Mon Jul 27, 2009 8:52 pm    Post subject: 120040hp rebuild Reply with quote
Shocked The 83s mm big bores are the way but stagger the rings cuz manle p/s have 2.0 1st and 2nd rings. Shim the barrels, a good valve job 009 dist and 30pict stock clean w/ pep cant loose at 275 per gallon of gas ?
John Moxon Premium Member
John Moxon is offline
PostPosted: Tue Jul 28, 2009 12:40 am    Post subject: Reply with quote
Here's some good reading that will throw all the options your way: http://www.thesamba.com/vw/forum/viewtopic.php?t=157657
If you want to asks further question as you no doubt will...post in that topic.
John.
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Vintage Speed All times are Mountain Standard Time/Pacific Daylight Savings Time
