YOGIVW Samba Member
Joined: February 04, 2005 Posts: 263 Location: Olsztyn/POLAND
Posted: Mon Jul 27, 2009 12:22 am Post subject: New 1915 and only 19 MPG |
Brand New 1915 engine in a super beetle convertible, around 550 miles on it, just completed 350miles trip ( 75% cursing, 25% town ) and I got only 19MPG. From what I read at this forum I see some of you get as much as 30MPG out of 1915.
Spec:
Hades Steve Tims StageII 42x37 valves
44IDFs pre jetted by DRD
W120
A1 1 5/8”
Bosch 009 with Pertronix ( set at 30 fully advanced )
Tires 205/55R16
Gearbox – stock AT code with 3,875R&P and 0,93 4th
Oil 10W-30
Any ideas where to look to get better mileage?
Thanks _________________ Pawel
Vw 1303 1979 Black&Beige convertible
VW T4 2001 Caravelle Business 2.8 V6
Westfalia James Cook 2.9TD |
AlteWagen Troll
Posted: Mon Jul 27, 2009 12:43 am Post subject: |
taller rear tires
taller fourth gear (bus .82)
drive with egg under your right foot |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Mon Jul 27, 2009 6:23 am Post subject: |
I have the same cam and carbs and I do my own porting I got about 25mpg, I'm thinking the rings arn't quite seated yet?? you say pre-jetted?? do a plug reading you may be over jetted,I'd get the taller tires to try, and you won't need a .082 4th gear or you'll have overheatng problems,A vert is a heavy bug and that must be a fun to drive with alot more power of a 1915 But, when gas hit $4 a gal up here I built a 1641 w/40 idf's and get 28-32mpg but alot less power but still fun to drive,I hope this helps,Madmike _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Tkisner Samba Member
Posted: Mon Jul 27, 2009 6:53 am Post subject: |
Pre-Jetted means ball park. You need to dial it in now. |
YOGIVW Samba Member
Posted: Mon Jul 27, 2009 8:37 am Post subject: |
Pictures of my NGK plugs from cylinder No 4 ( left) and No 2
probablly not, will do the compression test today
>A vert is a heavy bug and khat must be a fun to drive with alot more power of >a 1915
yes it is fun but I expected littel bit more. I do not know what is wrong, but this engine does not spin to the 6000-6500RPM. It has a power but no a lot more.
Before weekend I will borrow 010 from my friend who got it from Glen, will check what MPG will get. _________________ Pawel
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Mon Jul 27, 2009 8:54 am Post subject: |
Seriously you are barely broke in. What did you have in it before and what MPG were you getting? Driving style and the kind of miles makes a huge difference. With my 1200 and a very light foot on the highway (55-60) I get 32+ easy, but the way I normally drive its more like 28. You might also want to see what a little more advance may do for you as well. In addition, a vac advance distributor is supposed to give better MPGs, but the 010 is a worthwhile experiment. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
YOGIVW Samba Member
Posted: Mon Jul 27, 2009 9:17 am Post subject: |
andk5591 wrote: |
Seriously you are barely broke in. What did you have in it before and what MPG were you getting? Driving style and the kind of miles makes a huge difference. With my 1200 and a very light foot on the highway (55-60) I get 32+ easy, but the way I normally drive its more like 28. You might also want to see what a little more advance may do for you as well. In addition, a vac advance distributor is supposed to give better MPGs, but the 010 is a worthwhile experiment. |
before I had 1600DP with Kadrons and my MPG was around 25.
to be honest my driving style is very far from my gradmom. This weekend I have 250 miles trip so I'll try to drive with right foot lighter and will drive with
010.
And my jets:
60
135
175
>Compression test won't tell if the rings have seated. A leakdown test will.
Max what is the difference? _________________ Pawel
sturgeongeneral Samba Member
Joined: June 23, 2005 Posts: 2460 Location: Sacramento, California
Posted: Mon Jul 27, 2009 9:28 am Post subject: |
I also think you are still in break in mode. In time mpg should improve. I was kinda disapointed when I only get 17 mpg in my 2375 but figure the extra power and fun is worth it. _________________ Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her |
Posted: Mon Jul 27, 2009 9:42 am Post subject: |
YOGIVW wrote: |
Max what is the difference? |
In order for a compression test to help at all with this, I think you would have had to take a reading before starting the engine so you could compare that to a new reading and compensate for any change in cranking speed between the two tests.
The leakdown test is a direct measurement of how fast pressure escapes from the cylinder along with insight as to where it is escaping.
http://www.thesamba.com/vw/forum/viewtopic.php?p=3716307&highlight=differential#3716307
An engine that has not yet been run will leak quite a lot past the rings and very little past the brand new valves. My 1776 read ~50% on all four. Later re-testing showed leakage rate below 5%. To me that indicates seated rings.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
YOGIVW Samba Member
Posted: Mon Jul 27, 2009 10:10 am Post subject: |
Max Welton wrote: |
Max |
thank you for the explanation. Need to buy this tester _________________ Pawel
perrib Samba Member
Joined: September 14, 2004 Posts: 3402 Location: Chandler, Az
Posted: Mon Jul 27, 2009 11:05 am Post subject: |
Letting it break in could help but how and where you drive it matters more. I can get 25 mpg with easy driving at 55 mph on the street and at 65 mph it drops to 23. If I'm pushing it hard off roading the mileage drops fast to 12-15 mpg. Engine is a 2180 with a VZ 30 style cam. |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Mon Jul 27, 2009 1:00 pm Post subject: |
Try some 55 idle jets. You will have to readjust your mixture volume screws. If you have to take them more than 3 turns off the seat to get the highest idle then try 57 idles. Do you know how many turns out you are now? Remember, most of your cruising and in town driving is one the idle jets. _________________ 1965 Beetle sedan
Click to view image |
Posted: Mon Jul 27, 2009 4:24 pm Post subject: |
Before you start messing with your set up, I would just put a few hundred more miles on it. If you are like me witha new engine, you are playing with it a bit. The buggy has a 1776 with decent heads and dual kads. Have a late geared tranny. But I am on it all the time because its so much fun. 25 is a stretch. So - once the novelty of the new engine wears off a little and everything seats better, you'll probably get more like 25. And if you really want to see what it will do, try like hell to cruise at 55....
My regular car is a Subaru WRX - I get 25 on a good day - had to drive 4 hours on an interstate behind my neice who was nursing her minivan home and had to drive 55 the whole way. I got 32 MPG...... But honestly - what fun is that????? _________________ D-Dubya Manx clone - 63 Short pan,1914.
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Mon Jul 27, 2009 5:55 pm Post subject: |
i dont know whats up with alot of guys having horrible gas milage. i got 32mpg with my 1915 from vegas to disneyland 3/4s of a tank non stop.
my buddy with his BIG 2liter and ida's was around 30mpg going UP the grape vine _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
Posted: Mon Jul 27, 2009 6:01 pm Post subject: |
kielbasa wrote: |
my buddy with his BIG 2liter and ida's was around 30mpg going UP the grape vine |
What's up is alot of guys are running way too rich because they never fine tuned their engine. _________________ 1965 Beetle sedan
YOGIVW Samba Member
Posted: Tue Jul 28, 2009 12:05 am Post subject: |
Before my weekend trip the plan is:
- readjust mixture, I think it is too rich
- change 009 for 010
- put little more pressure into tires
- check my odometer with GPS
- cruise all the way 55 – 60 MPH
something else?
If it will not help will try to mess with the jets ( go from 60 to 55 )
Will report after weekend
Thanks for the tips so far _________________ Pawel
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Tue Jul 28, 2009 12:08 am Post subject: |
Try a smaller exhuast 1 1/2. _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
YOGIVW Samba Member
Posted: Tue Jul 28, 2009 12:13 am Post subject: |
splitpile wrote: |
Try a smaller exhuast 1 1/2. |
too expensive for me to try, but thanks _________________ Pawel
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Tue Jul 28, 2009 5:08 am Post subject: |
60 Idle jets are too big, you need change to 55's and you will notice an instant improvment in performance and mileage. It's not good to run a new engine too rich. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
