Creativemind Samba Member
Joined: June 26, 2006 Posts: 102 Location: Blomingburg, NY
Posted: Mon Aug 10, 2009 2:32 pm Post subject: Whats the proper way to clean the AFM? |
Tencentlife,
What's the proper way to clean and lubricate the AFM?
Is dielectric grease not a good idea to use?
What should be used to clean it and then lubricate it?
Should the case be siliconed when all work is finished?
Robert
NY _________________ 88 Wolfsburg, Automatic Silver Vanagon, 250,500 miles. Rebuilt Engine. 8/09 |
psych-illogical Samba Member
Posted: Mon Aug 10, 2009 5:19 pm Post subject: |
D'oh!! An analog meter?!!! I sure wish I had thought of that. All I had when I was going through my AFM issues a couple of years ago was a digital and the voltage change was anything BUT linear. And I sure as heck couldn't move the flapper slowly enough or smoothly enough to see what was going on. It turned out that swapping out my AFM did cure all my running problems and I'm still as happy as can be 30,000 miles later. _________________ 83 1/2 Westy waterboxer
'57 Beetle-sold
Coupla '81 BMW motorcycles (R80G/S; R100RS)
'96 BMW R1100GS |
tosch1969 Samba Member
Posted: Tue Sep 15, 2009 10:29 pm Post subject: |
This is the first time I have written in. I have been dealing with this loss of power off idle when cold problem for three long years. I tested using the analog multimeter and found no fluctuations whatsoever - even did it with a toothbrush like ten cent just to be scientific . I have changed fuel lines, fuel filter, plugs, tps, cleaned the heck out of the tb, plugs, wires, O2 sensor, coolant temp sensor, tested for vacuum leaks, etc. Called the PO (for pointers about the car and not to b*tch). You name it I did it.
So I test my AFM (slowly - with the thing out just like it says so I can push on the inside of the thing and not on the wiper arm). Just for kicks I test it by pushing on the wiper arm too. No fluctuations in voltage at all. But I am convinced - it must be this darn AFM. So, I take my needlenose (couldn't budge those screws) and gently bend the wiper arm down (figured it couldn't hurt) and test drove.
It's been a week now and the problem of the last three years is gone! It has a (barely perceptible) flat spot just off idle when cold so the arm may need a slight additional bend (or it could be as good as it gets due to that well worn groove in the track) but its like 99% better. Thank you thank you thank you. I appreciated this post so much. It helped me solve my own personal bout of Vanagon Syndrome |
Neptuno Samba Member
Joined: March 23, 2004 Posts: 141 Location: DelCo, PA
Posted: Thu Sep 24, 2009 5:33 am Post subject: |
I have one question about this, Is there a way that someone can post a picture of what a worn out section of the tracks look like?
I am interested in reconazing this if I see it. Also on another tread 10cent mentioned ajustment of the board if this was the case. Did I miss how to do this?
Thanks all!
El t _________________ Lonely Vanagon running up and down Delco
joetiger wrote: |
Also, if you look closely, the drapes in the house match the Vanagon, illustrating outstanding thematic continuity. |
WesternMassRich Samba Member
Joined: August 27, 2008 Posts: 299 Location: Pittsfield, MA
Posted: Thu Sep 24, 2009 5:54 am Post subject: |
What an excellent video !! I feel like testing my AFM just to make sure it does not have any dead spots in the wiper pot. That was very very good. Thanks !
rich _________________ 1987 Synchro, AC, PS, 5 Speed, 7 Pass., 2.1 Digifant. "The Kaiser" |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10077 Location: Abiquiu, NM, USA
Posted: Thu Sep 24, 2009 7:36 am Post subject: |
Good deal guys.
To post pics, there are instructions up on top of the page, under "Gallery", "Add Photo". That lets you set up a photo gallery of your own here from which you can link pics to your thread posts.
I found that didn't work well for me, so the alternative is to set up your own page at one of the free photo-hosting sites, I use Photobucket, but there's Flickr and others. Then you can upload pics to there, and grab a link and paste it into your posts here.
You insert a pic link like this:
[img]URL[/img] _________________ Shop for unique Vanagon accessories at the Vanistan shop:
coral56red Samba Member
Posted: Sun Nov 01, 2009 9:18 pm Post subject: Vanagon AFM |
This is great, particularly the video and explanation by tencentlife. Has anyone compared the quality difference between the Kenneke and GoWesty rebuilt AFMs?
Since these are wear items I figure replacement will at some point be inevitable. |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Mon Nov 02, 2009 6:54 am Post subject: |
Most of the online parts houses send the AFM out to a place called FIC Corp.
That stands for Fuel Injection Corporation and they are located in Livermore, California. The phone number is (925) 371-6551.
The web-site is www.fuelinjectioncorp.com. |
Posted: Mon Nov 02, 2009 10:15 am Post subject: Vanagon AFM |
Thanks, RCB. I'll check them out. |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Sat Nov 07, 2009 1:09 am Post subject: |
ok I wanted to add to this topic. If i hadn't just swapped in a new engine requireing carbs my AFM desperatly needed to be checked for dead spots. I was talking to my friend, an electrical engineer who did some work specifically on desiging wiper arms who said a few interesting things.
1, yes there is a lube, if you spray an electronics cleaner, get a spray electronics lube to follow with. there are seom products that contain both properties, I have forgotten thier names but look them up
2. DO NOT BEND THE ARM. the arm is set to a VERY exacting pressure from thefactory, which you can not dupilcate. think about just how tiny the contact area is between the arm and board. it has a surface area is .001 inches. ok thats an exaggeration, but the differecne between .5lb of force and 2 is the difference between 500 psi and 2000psi scraping the board clean. move the screws, use heat to free the epoxy, as they are all epoxied in.
I thought there was a third but I have forgotten it. once you are done adjusting all this, you will need to recalibrate your AFM of course, so bring it to you local shop or rent an LM-1 or such analyser and have a field day. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
jackstar Samba Member
Joined: February 15, 2008 Posts: 274 Location: Gulf Breeze, Florida
Posted: Tue Jun 08, 2010 3:37 am Post subject: |
After having a couple of looks at the video and then my own AFM, I realized I have a 79 7-pin plug whereas the video shows a 4-pin plug. Can someone tell me where to pug in my red/black leads on the 7-pin plug? Thanks in advance.
Jack |
dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1396 Location: Dartmouth, Nova Scotia
Posted: Sun Jun 20, 2010 3:41 pm Post subject: |
For late bay owners with a 7 pin afm, I did this test here:
http://www.thesamba.com/vw/forum/viewtopic.php?p=4667033#4667033 _________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
Meyer wrote: |
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent? |
keithwwalker Samba Member
Posted: Fri Jun 25, 2010 11:55 pm Post subject: |
This should be a sticky!
Anyway, I am surprised that no one has yet figured out how to put in a modern tps in there to get the signal in and out.
Just wondering, how many degrees is the arc of the wiper from idle to full throttle? Is it an even 90 degrees? |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Sat May 05, 2012 9:04 am Post subject: |
Chris, you know you are my Vanagon hero!
Thank you for all of your great information, experience and advice! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
Posted: Sat May 05, 2012 9:27 am Post subject: |
A nice bottle of Scotch speaks louder than words. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Sat May 05, 2012 9:32 am Post subject: |
tencentlife wrote: |
A nice bottle of Scotch speaks louder than words. |
Ski passes did not hurt either. You drop by and you got it! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
randywebb Samba Member
Posted: Sat May 05, 2012 1:18 pm Post subject: |
speaking of the the box being sealed up tight, how do you reassemble the thing?
is a bead of 'regular' silicone seal adequate? _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Thu May 10, 2012 12:13 pm Post subject: |
randywebb wrote: |
is a bead of 'regular' silicone seal adequate? |
Speaking of assembling, what is the proper way to remove the plastic cover with damaging it? I cut under the lip to get at the sealer, but it still will not pop off.
HELP! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9797 Location: Mt Lemmon, AZ
Posted: Thu May 10, 2012 2:04 pm Post subject: |
The cover can be stubborn if never removed before -- the sealant may also be inside the lip, an area where you cannot get at with your Xacto knife. If you can raise it just a tiny bit to get a very thing screwdriver or other wedge under the lid you can begin to work it loose. Once it starts to let go you're pretty much home free but you have to overcome that initial grip & stretch property of the sealant.
I use a lot less sealant on the reseal though you want it sealed enough to keep dust out. |
