nybugguy Samba Member
Joined: September 21, 2008 Posts: 117 Location: Upstate New York
Posted: Wed Jul 29, 2009 3:04 pm Post subject: In need of a replacement dash... |
I have recently been finishing up a 1960 spatz on a 74 bug chassis.When I bought the tub it came with everything except a dash. My question is are the original dashes plastic or fiberglass and which is better, my buddy that owns a fabricating shop near me said he would like to build me a polished aluminum dash.Can't decide what to do or where to find one to see what they look like.Anyone have any pics or threads to some dashes I could look at? Thanks Everyone! nybugguy.. |
tinnocker Samba Member
Joined: July 24, 2008 Posts: 439 Location: Jasper Georgia
Posted: Wed Jul 29, 2009 3:23 pm Post subject: |
I had a custom satin aluminum dash in a Jeep CJ-7 and it was real easy to scratch. I didn't have a problem with sun glare but I have read where some buggies with polished dashes it was a problem. Their are replacement dashes but I don't know who sells them. I am sure others will chime in with more info. |
Herbthe1eyedworm Samba Member
Joined: December 29, 2006 Posts: 60 Location: Kanona New York
Posted: Wed Jul 29, 2009 3:33 pm Post subject: |
My dash was fabed at a shop then I had to cut to fit [img] [/img] [img][/img] _________________ Goin to hell in a bucket...At least i'm enjoyin the ride!!!!! |
Posted: Wed Jul 29, 2009 4:03 pm Post subject: |
Nice lookin dash.....I see you have the same steering column that I have so what are you doing for turn signals? I was going to fabricate some kind of stub to mount a universal switch to. Any ideas? |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Wed Jul 29, 2009 5:52 pm Post subject: |
I installed a fiberglass replacement dash from the Manx Club (Meyers Manx). It only took a couple hours to glass it to my hood in place of the original ABS dash.
After:
Before:
_________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
chris_parks Samba Member
Posted: Wed Jul 29, 2009 5:53 pm Post subject: |
Coolest idea I heard of was a motorcycle switch on the shifter. |
Posted: Wed Jul 29, 2009 7:12 pm Post subject: |
chris_parks wrote: |
I like the horn in the steering wheel where it's supposed to be. In an emergency you have no time to reach for a horn button on the shifter. As I said before, you don't get too many chances when you are driving a buggy. _________________ Jerry...
RIP Morgan
My photos
Posted: Wed Jul 29, 2009 8:00 pm Post subject: |
As far as the horn being on the shifter or on the steering wheel, it is all what you get used to. I had a hard time learning to dim the lights when the dimmer switch was moved from the floor to the turn signal switch on modern cars. What is the difference in the time to move your hand to the center of the wheel versus moving to the shifter switch or to a dash switch? Milliseconds? |
Mongo63 Samba Member
Joined: February 15, 2007 Posts: 1358 Location: prison city, IL
Posted: Wed Jul 29, 2009 8:07 pm Post subject: |
_________________ Southside Buggistas VW & kit car club
www.southsidebuggistas.com
Mongo only pawn in game of life...
mharney wrote: |
Behold the true power of the extractor! Mongo has it right! |
Posted: Thu Jul 30, 2009 6:55 am Post subject: |
tinnocker wrote: |
If the only car you drove was the buggy you might get used to it, eventually. but seeing that the majority of your time is spent in a conventional car with the horn in the steering wheel, I guarantee you in an emergency situation you will be pounding on the steering wheel for the horn. Milliseconds may be all it takes to avoid an collision.
I'm sure the auto makers have spent billions to determine the best location for things like horn buttons and the fact that they haven't moved it since the early 1900's says something. _________________ Jerry...
RIP Morgan
My photos
Posted: Fri Jul 31, 2009 2:13 pm Post subject: |
nybugguy wrote: |
I used a 3 way toggel switch with a extention on the toggel mounted on the dash _________________ Goin to hell in a bucket...At least i'm enjoyin the ride!!!!! |
Rbake Samba Member
Joined: October 10, 2004 Posts: 112 Location: Central Texas
Posted: Fri Jul 31, 2009 3:04 pm Post subject: |
My dash looked like this:
I cut out the center and made this because my knee would hit the old one:
I centered a start button above the speedo and also used the motorcycle switch to keep the dash clean:
Hawaii50 Samba Member
Joined: February 16, 2009 Posts: 49 Location: On your computer screen!
Posted: Fri Jul 31, 2009 8:11 pm Post subject: |
I am wondering….using the motorcycle switch, does the self canceling for the turn signals work on a buggy? Or do you have to manually cancel the turn signal? How about using the accessories? Normally, one just turns the key one or two clicks to use the radio if they want without actually starting the vehicle. |
Rbake Samba Member
Posted: Sat Aug 01, 2009 6:13 pm Post subject: |
the motorcycle switch does not self cancel, I really wanted my wiring as simple as possible and my dash as clean as possible so I didn't even mount turn signal lights on my dash, Instead I bought a no load flasher for led lights that has a loud beeper built in. You can easily hear it and it's an anouying reminder that your signals are on.
A horn could still be wired into the steering wheel in conjuction with the one on the motorcycle switch since all the horn wire does is ground out to fire the horn. |
hcallaway Samba Member
Joined: September 06, 2008 Posts: 333 Location: Richmond VA
Posted: Sat Aug 01, 2009 7:36 pm Post subject: Clean up the dash using two buttons for both Turn Signals. |
This module lets you use two momentary buttons for left and right turn signals, push both buttons for emergency flashers and it runs your parking lights (if you want them 24/7). The module also ties into your brake lights and integrates them into the tail lights. It will let you run LED and other lights without a load equalizer? Here is the info:
Engineered for the custom builder, or to retrofit motorcycles not equipped with self-canceling turn signals.
Designed for use with individual momentary type turn signal switches mounted on the left and right handle bars. This unit will not work on bikes that have the left and right turn signal switch built into one unit that you must push to cancel.
Features:
Three Turn Signal Timing Modes - self canceling.+ Hazard Mode - non-self canceling.
Non-Load Dependent Flash Duration - flash time constant whether using incandescent or LED lighting.
Dependable Solid-state electronic components.
Weather Proof - potted with soft cell technology to prevent wire chaffing and damage.
Specification:
Voltage: 12 VDC, Negative Ground.
Max Load Capacity: 6 amps per left or right channel.
One of the turn signal buttons does not have the dust cover installed. Black button is horn. Left hole is ignition switch and right hole is the light switch with a high beam indicator.
_________________ Share site with additional pictures.
http://berriennostalgiadunebuggy.shutterfly.com/
http://s83.photobucket.com/albums/j289/hcallaway/berrien%20dune%20buggy/ |
66 Shorty Samba Member
Joined: May 10, 2007 Posts: 916 Location: Rhode Island
Posted: Mon Aug 03, 2009 8:24 am Post subject: |
This is a stock one that was posted on the thread for my Buggy... Hope it helps!
Mine is ABS as far as I can tell. _________________ ~X-Man~
'60's Spatz Buggy body on '74 Chassis (Budget Build)
'69 Bug (Baja-to-be partial daily)
'10 Silverado (My daily) |
