skid Samba Member
Joined: January 16, 2009 Posts: 1329 Location: Vancouver, BC
Posted: Mon Nov 16, 2009 2:44 pm Post subject: |
That looks awesome! _________________ '71 Westfalia |
volksterii Samba Member
Joined: December 01, 2006 Posts: 425 Location: San Diego CA
Posted: Mon Nov 16, 2009 3:20 pm Post subject: |
I really like the colored string. I just did mine with the black it came with. _________________ 71 Westy Hardtop, 1915
2005 Touareg V8 air susp. |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 1227 Location: Edmond Oklahoma
Posted: Mon Nov 16, 2009 5:39 pm Post subject: |
Do you have a link or thread to the skid plate specs and/or blueprints? _________________ James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020 |
MadMax78 Samba Member
Joined: May 26, 2007 Posts: 511 Location: The Netherlands
Posted: Sun Nov 29, 2009 1:05 pm Post subject: |
jmstu76 wrote: |
Do you have a link or thread to the skid plate specs and/or blueprints? |
I emailed them to Everett, he'll put them in the archives soon.
Spent some time on the front axle today. First unboxed a shipment from Just Kampers, they supplied us with all the parts for the front axle and then some. Thanks JK!
We dropped the front axle:
And stripped it down to just the beam
The beam is now sent off to get adjusters welded in. We're going to raise the front a little bit. In the meanwhile we started cleaning and painting some of the old parts. Just did the backing plates and the brake booster. Also cleaned the brake fluid resevoir and pressure switches and installed them on the new master cylinder.
The adjusters should be done next weekend, then we can start painting the axle and get everything checked out and reassembled again.
That's it for now! _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Sun Nov 29, 2009 2:21 pm Post subject: |
MadMax78 wrote: |
The beam is now sent off to get adjusters welded in. We're going to raise the front a little bit. |
So, with the adjusters, you'll be able to change your front ride height? Who is doing the work for you?
BTW, your bus is awesome, can't wait to hear how it handles the trip! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
Posted: Mon Nov 30, 2009 4:32 am Post subject: |
peaceful warrior wrote: |
BTW, your bus is awesome, can't wait to hear how it handles the trip! |
Thanks!
You can raise a bus just the same way as you lower it using the adjusters. They are welded in by a friend from the Dutch T2 owners club. _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Bursch Samba Member
Joined: October 28, 2006 Posts: 448 Location: Netherlands
Posted: Sun Dec 06, 2009 9:23 am Post subject: |
Picked up the beam today, great work by Corne here in the Netherlands.
Adjusters from justkampers.com welded on a '78 Bay beam.
The slit is to indicate the stock setting. This setup allows for a raise or slight drop.
The upper adjuster is opposite to where the securing bolt is on a stock beam. There is no room between the tubes to allow any adjustments to be made once installed (due to shift rod etc running in between the tubes) _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt & EDIS // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply, Busted Bus & Aircooled Technology
2014: New York - Rio de Janeiro - FIFA World Cup -- 28.000km
JMazier Samba Member
Joined: February 20, 2006 Posts: 900 Location: In my garage, Georgetown, Ontario, Canada...
Posted: Sun Dec 06, 2009 7:26 pm Post subject: |
Hey,
Great thread! I look forward to following you on your journey. Can you please explain to me how these adjusters work?
Thanks! _________________ Cheers!
Jérôme
’79 Cali Westy 2.0 F.I.
'74 Honda CB 350 Four
'78 Honda CB 750 K
'12 Golf GTI
'11 Ural Patrol |
timo78 Samba Member
Joined: July 03, 2009 Posts: 931 Location: Overcast and Loving it
Posted: Sun Dec 06, 2009 10:50 pm Post subject: |
Excellent story, I look forward to seeing more of this thread.
Is there an english version of the Oranje Trophy website? Also Did you get the Megasquirt installed, if so were the results positive? _________________ > 78Grµn Westfalia `Donkey`
It may be bigger than you and it may be bigger than me, but it’s not bigger than you AND me; can you dig it? |
Posted: Mon Dec 07, 2009 3:33 am Post subject: |
JMazier wrote: |
Hey,
Thanks! |
The torsion leaves are held in place by a locking block in the center of the beam. The adjuster bolts are attached to this block. By rotating the block you can change the preset tension in the leaves. Thereby raising or lowering your ride.
On stock beams the center block is just locked in one position.
timo78 wrote: |
Excellent story, I look forward to seeing more of this thread. Very Happy
We're still working on an English version of the website, it should be available soon.
The megasquirt isn't installed yet. We'll drop the engine and gearbox sometime soon. We planned to replace the transaxle and at the same time service the engine and get the trigger wheel installed. When it's back in we can start on the wiring harness and see what happens next . We expect the transaxle to be ready for pickup somewhere this week, so as soon as we finish up the front axle we can drop the engine. _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Posted: Wed Dec 09, 2009 5:43 pm Post subject: |
MadMax78 wrote: |
JMazier wrote: |
Hey,
Thanks! |
Thanks! How much of a lift does it give? _________________ Cheers!
Jérôme
'78 Honda CB 750 K
'12 Golf GTI
'11 Ural Patrol |
Bursch Samba Member
Posted: Sun Dec 13, 2009 4:49 pm Post subject: |
Still working on the front beam. Wasn't easy to get those arms in place with the extra tension on the torsion leafs.
Thanks to Evam Classic the rebuilt transaxle arrived to our doorstep.
Overhauled 091 with 5.14 Weddle Racing R/P and Peloquins Limited Slip Differential. Oh, and a fresh powdercoat, but that's hard to miss...
Bleyseng Samba Member
Posted: Sun Dec 13, 2009 10:47 pm Post subject: |
you're gonna love the LSD! cool front beam setup for you guys to travel on those back roads. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Mon Dec 14, 2009 4:54 am Post subject: |
Bleyseng wrote: |
you're gonna love the LSD! cool front beam setup for you guys to travel on those back roads. |
I am wondering why you chose to raise the front end using the adjusters vs. using lift spindles? Is there an advantage of one over another? I ask because I am thinking of a lift and want to know the benefits of each. _________________ Cheers!
Jérôme
'78 Honda CB 750 K
'12 Golf GTI
'11 Ural Patrol |
melville Samba Member
Joined: August 09, 2006 Posts: 1246 Location: Just Outside the Redwood Curtain
Posted: Mon Dec 14, 2009 10:20 am Post subject: |
JMazier wrote: |
Bleyseng wrote: |
I am wondering why you chose to raise the front end using the adjusters vs. using lift spindles? Is there an advantage of one over another? I ask because I am thinking of a lift and want to know the benefits of each. |
Lift spindles are typically welded and often have track width issues. With a torsion adjuster Max can use the stock forged spindles and even if he does break one in Africa he only needs to obtain a stock part to replace it. _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
Posted: Wed Dec 30, 2009 3:19 am Post subject: |
Update!
We resumed work on completing the front axle. Front bearings were in superb shape, so we just repacked them with grease and fitted a new seal.
Everything assembled again
And bolted to the bus
In the meanwhile we dropped the engine and transaxle, it's not as mint looking as two years ago.
We were suspecting an oil leak in the bell housing, either from the engine or transaxle. The leaking oil made the clutch slip sometimes and that resulted in a burned flywheel
Seems like it is indeed the transaxle leaking and not the engine... what do you think?
The oil pump also drizzled some oil, not much, but now the engine is out we can fix this too.
We are also installing a trigger wheel and VR sensor for the Megasquirt FI system.
Future home for the VR sensor
Since the engine bay insulation was starting to look a bit shabby and we read good things here about dynamat, we decided to dynamat the engine bay. First we fitted a layer of Dynamat Xtreme and put a layer of Dyanamat Hoodliner over that.
Dynamat Xtreme:
Hoodliner:
Done! The pic is a little crappy but it proved a bit hard to get a good picture of the reflective material.
This is how the engine is looking now
We're working overtime to finish up the front and rear axle (we're also giving the rear a slight raise). Also the engine needs to be dressed up again and put back with the new transaxle. We have to attend a show next week, so I better get going! _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
yunazz Banned
Joined: November 24, 2009 Posts: 96 Location: Cape Town
Posted: Wed Dec 30, 2009 3:28 am Post subject: |
when do you plan to leave amsterdam?
and when will you arrive in the cape? |
delamaize Samba Member
Joined: December 05, 2008 Posts: 769 Location: Tenino, Wa
Posted: Wed Dec 30, 2009 4:16 am Post subject: |
Let me see if you pass birkenfeld germany, Love to see your bus in person. _________________ Mike "Delamaize"
Starting over again.
ovalteen wrote: |
His non-attention to detail really sets it apart. I see a new trend.......call it " 'tard ride". |
Sled wrote: |
The tard box will live again! |
foxtail1 Samba Member
Joined: February 04, 2008 Posts: 706 Location: graham
Posted: Wed Dec 30, 2009 9:56 am Post subject: |
What a trip you are undertaking. What about the quality of petro on the way? Don't forget extra petro filters _________________ As they say, "You never know until you ask the question."
64 bug
64 bus
59 ghia
71 bus |
Posted: Wed Dec 30, 2009 5:18 pm Post subject: |
yunazz wrote: |
We're departing on April 3rd and we plan to arrive in Johannesburg June 11th. From then on, we'll be following the Dutch soccer games, so we'll be in Durban June 19th and in Cape Town from June 24th.
delamaize wrote: |
Let me see if you pass birkenfeld germany, Love to see your bus in person. |
We'll probably pass Frankfurt on Saturday 3rd of April, somewhere in the afternoon. We're on a pretty tight schedule to get in Trapani for the ferry to Tunisia. So, we don't have time to drop by I'm afraid. You can see us soaring by on the highway though
foxtail1 wrote: |
What a trip you are undertaking. What about the quality of petro on the way? Don't forget extra petro filters |
We'll carry quite a few, quality should be ok'ish. If the octane level is low we can add octane booster to help it a little. We didn't have problems with it when we headed for Beijing, so I guess we should be fine. Besides, we're not the first people venturing through Africa in a T2. _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
