wythac Samba Member
Posted: Sun Aug 02, 2009 9:09 pm Post subject: suggestions for fuel shutoff valve |
I have a 3" lift so I have some room to put a fuel shutoff valve under the stock tank in the front my buggy. Struck out at a hardware store and two auto parts stores looking for what I wanted. Next stop will be a plumbing/heating shop, hoping I can find something for a furnace that is small enough to work. Any suggestions? |
Mongo63 Samba Member
Joined: February 15, 2007 Posts: 1358 Location: prison city, IL
Posted: Sun Aug 02, 2009 9:11 pm Post subject: Re: suggestions for fuel shutoff valve |
wythac wrote: |
Motorcycle aftermarket vendors... What tank are you using? I have one I could send you. You have a PM. _________________ Southside Buggistas VW & kit car club
www.southsidebuggistas.com
Mongo only pawn in game of life...
mharney wrote: |
Behold the true power of the extractor! Mongo has it right! |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Dale M. Samba Member
Posted: Sun Aug 02, 2009 10:18 pm Post subject: |
Why not get early fuel selector like on pre 60's bugs... Connects to existing fitting on tank gives you a main, reserve and off position....
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-209-021-F
tbirdscott Samba Member
Joined: June 11, 2009 Posts: 74 Location: Willow River B.C.
Posted: Mon Aug 03, 2009 11:29 am Post subject: |
You could pick up a snowmobile fuel shut off valve from polaris or skidoo dealers. plumbs inline, can be bolted through a piece of sheet metal, just an on/off ball valve.
If you can fit a stock type valve with reserve that'd be best though.
Scott |
wythac Samba Member
Posted: Mon Aug 03, 2009 11:32 am Post subject: |
Thanks guys. I had thought the old reserve taps used a different style bung on the bottom of the tank, but my local air cooled guru confirms that they are the same. He adds that the were standard equipment on Bugs in Europe long after they were no longer available in the US, so they will definitely fit later model tanks like mine. |
hcallaway Samba Member
Joined: September 06, 2008 Posts: 333 Location: Richmond VA
SPEEDYBUGGY Samba Member
Joined: September 19, 2005 Posts: 52 Location: Manassas,Va
wythac Samba Member
Posted: Mon Aug 03, 2009 4:13 pm Post subject: |
I have a brass 1/4" gate valve which would do the trick except it would just hang and I didn't like that.
I think I will do a combination of hardware here that will give me some flexibility for disassembly and service. I'll get the OEM one up front for ease of removal of the fuel tank and for seasonal shut downs where I would like to blow the lines clear.
I'll mount the gate valve in the rear between where it comes out of the tunnel and where it enters the engine tin. That will make for an easy disconnect point for removing the engine. I've always hated crawling under my bugs and shoving a screw in the fuel line while the fuel runs down my arm.
Some redundant theft protection too...i doubt a car thief would think there were TWO fuel valves. |
mikemck Samba Member
Posted: Mon Aug 03, 2009 8:00 pm Post subject: |
I used a Briggs & Stratton fuel shut-off valve I got from a lawnmower parts place.
It was very easy to splice into the rubber fuel line. |
wythac Samba Member
Posted: Tue Aug 04, 2009 6:19 am Post subject: |
All great ideas, thanks. |
uhcrandy Samba Member
Posted: Tue Aug 04, 2009 11:57 am Post subject: |
Why do you need a shut-off? At first it seemed like a good idea, then I got thinking "when would I need/use this?" Might be good for theft deterant although. |
wythac Samba Member
Posted: Tue Aug 04, 2009 12:53 pm Post subject: |
UH,
Here's the cliff's notes from one of my posts above;
Component isolation for removal/repair/storage (tank, lines, engine).
Theft prevention (they will only get as far as two float bowls will get them.)
Oh, yeah, and one more reason: No such thing as overdoing excess. I work for the Department of Redundancy Dept Dept. |
sturgeongeneral Samba Member
Joined: June 23, 2005 Posts: 2460 Location: Sacramento, California
Posted: Tue Aug 04, 2009 7:07 pm Post subject: |
I have been looking for a 12v shuttoff valve myself. Would make a good anitheft devise with a hidden power switch for it. _________________ Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her |
Mrav8tr Samba Member
Joined: March 18, 2009 Posts: 187 Location: La Quinta, Ca
CrashedAgain Samba Member
Joined: June 06, 2007 Posts: 328 Location: Saskatchewan Canada
Posted: Wed Aug 05, 2009 3:49 pm Post subject: |
Mine is standard hardware store fittings but I had to re-thread the tank fitting to 1/8" pipe thread. Didn't have a servicaeable stock fitting anyway.
Used only as a maintenance shut off...could be used as an anti-theft by making an extension handle into the passenger compartment but then I got thinking I would probably not really use it anyway. |
