adriaan pienaar Samba Member
Joined: February 17, 2003 Posts: 692 Location: Sedgefield, South Africa
Posted: Fri Mar 26, 2010 9:51 am Post subject: |
I started with the installation of the 914 rev counter in the dash today. These pics are a bit graphic, but there is no other way to do it since I am not prepared to buy a 115mm hole saw that I will only use once (Not even Volkspares use a hole saw for the turn key buggies they build for customers.)
Masking tape was put on the dash, the rev counter was measured, and a perfect circle the size of the rev counter was drawn (by compass, not by hand! ) on the masking tape. I then drilled small holes on the inside of the circle, all around
The small pieces of fibreglass inbetween the holes were then cut away, leaving a gaping hole in the dash with rather rugged edges
I then cleaned the rugged edges with the Dremel, till the surface was smooth (and the circle true) again. The gauge is a perfect fit!
_________________ Please say Hi to us at
www.aircooledvwsa.co.za &
http://hotwheelsclubza.freeforums.org |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Mar 26, 2010 9:57 am Post subject: |
A "Rotozip" tool is wonderful for cutting circles like that. The come with a circle cutting attachment. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Wed Mar 31, 2010 8:06 am Post subject: |
Slowly but surely things are starting to get together, and today I 'dry-fitted' the bonnet, roll cage and headlights on HW2. Unfortunately it started raining and I had to move it back into the garage before I could take more pics..
tanner_122 Samba Member
Posted: Sun Jun 06, 2010 8:40 pm Post subject: |
any updates man? _________________ 91 jeep Cherokee "TANK" |
Posted: Tue Jul 27, 2010 9:37 am Post subject: |
Quick Update 27/07/2010
Today was pleasant and warm here in Jhb, and it almost felt like summer is on its way. I came home a little bit earlier than usual, and decided to start cutting the floorboards from the aluminium plate. This is the rough cut results, they still need to be trimmed slightly to fit inside the chassis:
The garage where HW2 is being stored was used by some builders who did work on the premises, and in spite of the fact that the buggy was covered, is was still a bit dusty, so HW2 got its first official WASH today, albeit with the body off the chassis
I trial-fitted the tail light housings, after spending about an hour to trim the edges of the metal, so that it fits the contours of the bodyshell perfectly. If all goes well, they will be chromed like those that were on HW1
LouisB Samba Member
Joined: August 16, 2004 Posts: 1027 Location: Tallahassee, FL
Posted: Tue Jul 27, 2010 10:57 am Post subject: |
Looking really good.
--louis _________________ Louis Brooks
'67 Manx II
Old people at weddings always poke me and say "Your next." So, I started doing the same to them at funerals. |
Posted: Thu Jul 29, 2010 6:28 am Post subject: |
Went to fetch the roll cage yesterday on the roof of the Squareback, after I had some changes done to it... got a few funny looks from fellow road users
Posted: Sat Aug 14, 2010 8:46 am Post subject: |
Update 14 August 2010
The aluminium floors are rivited in, and I am happy with the result - however I am not very fond of the 'chequered plate look', so the entire floor and transmission tunnel will be carpeted later.
As I put the body and roll cage back, I covered HW2 with a tarpaulin for the dust (there are still construction workers busy upstairs). I noticed a little orange Ladybird on the back of the cover - checking out the scene - wonder if it was the spirit of HW1?
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sat Aug 14, 2010 11:23 am Post subject: |
After seeing the wreck photos, all I have to say is that you are a brave man. not many would have got back in the saddle. looking good!!! _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Ruska B1 Samba Member
Joined: July 30, 2007 Posts: 257 Location: Netherlands
Posted: Sat Aug 14, 2010 2:12 pm Post subject: |
Looks good Adriaan.
Gert _________________ Gert
'68 Meyers Manx
'71 US Opel GT |
Posted: Sat Nov 06, 2010 6:35 am Post subject: |
A lot of time has past since my previous post, but in the meanwhile I've been busy with a few small things on HW2 - not really important enough to post here, but still neccessary to complete the project. At this stage I need to have the roll cage powder coated first, then I can carry on with the final assembly.
Got the front steel wheels back - not 100% happy with the work done on them, but they have to do for now. For now - a 'mock-up' pic I took this morning of HW2 to get an idea of what it will (hopefully) look like in the end..
After the pic was taken., I spent another 3 hours re-adjusting the rear torsion bars - as you can see in the pic the suspension was WAY too low in the back
manxbuggy Samba Member
Joined: August 29, 2006 Posts: 131 Location: Seattle, Wa
Posted: Sat Nov 06, 2010 7:54 am Post subject: |
adriaan pienaar wrote: |
That is a beautiful buggy! I like the retro smoothy steel wheels, but I’m also a big fan of the big and little Empi Sport Stars.
Will you be driving the buggy this summer? |
LouisB Samba Member
Posted: Sat Nov 06, 2010 8:54 am Post subject: |
Looking good man. What size tubing did you use for your cage. I like the looks of it.
Thanks,
'67 Manx II
Gone Blue Samba Member
Joined: August 24, 2010 Posts: 84 Location: SE Michigan
Posted: Mon Nov 08, 2010 10:55 am Post subject: |
Ditto on the steel smoothy wheels, they look just right on your buggy. I too also like the Sportstars. What size rims and tires are you showing here? Thanks, G.B. _________________ Buggy Project underway.
60's Nostalgia Manx clone body
65' Beetle for donor
1600 Dual Port B Series motor |
Posted: Thu Dec 09, 2010 6:52 am Post subject: |
Thursday, 9 December 2010 - FIRST TEST DRIVE!!
This afternoon (we are in a GMT+2 time zone) was the biggest highlight of the HW2 project so far - I took it for it's first test drive Please don't get me wrong - the buggy is still VERY FAR from being finished (yet another target date - Dec '10 holidays - not made ), but I actually drove it for the first time today for a few kilometers (and about 2 plastic Coke bottles of petrol ) here in Kensington South, Johannesburg. For the first time HW2 has left the garage under its own power, and it was quite an adventure, I must add, trying to avoid the MetroCops with a vehicle with no identification plates or disc, no windscreen, super smooth rear tyres (temporay, btw), no wipers, no functioning lights, dodgy brakes and backfiring like the machine guns of a Mitsubishi Zero during the Pearl Harbour attack (OK, only till I sorted the timing out ) Almost lost the front wheel (forgot to fasten the wheel nuts ) but I guess that happens to all of us some time or other...
I am quite impressed with the buggy's pullaway, accomplished by the two Solex carbs but the brakes are still not right, might even have to change the (Golf) master cylinder.
Still have to have the roll cage powder coated, windscreen fitted, seats & rails sorted out, rear wheels painted, BF Goodrich's fitted, wiper motor sorted out, complete the wiring.... actually it is still a loooooong list The chroming of the tail light housings and Ghia license plate cover also has to wait for a while.
Took these pics at Rhodes Park, got back home seconds before it started raining. Thanks once again to all for their support so far!
The only functional light at the moment - the reverse light!
Last edited by adriaan pienaar on Thu Dec 09, 2010 7:14 am; edited 1 time in total |
LouisB Samba Member
Posted: Thu Dec 09, 2010 6:57 am Post subject: |
looks sharp. I bet that was a blast to drive it for the first time.
'67 Manx II
Posted: Thu Dec 09, 2010 6:59 am Post subject: |
LouisB wrote: |
Thanks,
--louis |
Thanks, Louis - only saw this now. The roll cage is sold by Volkspares South Africa with the Lolette kit, the diameter of the front roll bar (windscreen frame) and 'T'-pieces is 38mm, and the rear roll bar is 64mm.
Gone Blue wrote: |
Ditto on the steel smoothy wheels, they look just right on your buggy. I too also like the Sportstars. What size rims and tires are you showing here? Thanks, G.B. |
Thanks G_B - the front wheels are slightly wider rims with 165R15 tyres (standard Beetle, and the rear wheels are wider rims on 245/75R15 (normal ATV) tyres. _________________ Please say Hi to us at
Posted: Thu Dec 09, 2010 7:49 am Post subject: |
That’s a handsome buggy! Congratulations on reaching the ‘first drive’ milestone!
What exhaust system is that?
Rob |
Posted: Thu Dec 09, 2010 11:11 am Post subject: |
Thanks, Rob The exhaust is a fairly common (in SA, at least) stainless steel 4-into-1 Buggy/Baja type with universal aftermarket VW J-pipes. I'm not very fond of the J-pipes passing underneath the cylinder heads, but I fitted slightly modified 36Hp heater box outers over them, and I am quite pleased with the effect in the end (the heater box outers also protect the pushrod tubes.)
I had the exhaust ceramic coated silver, it only appears white in the pic due to bad light in the overcast sky. _________________ Please say Hi to us at
