Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Thu Aug 13, 2009 8:39 am Post subject: 20 mile engine; is this a rod knock? |
I hope you guys can help me diagnose an engine sound. First, the details:
1915cc
L5 heads (ported, 40 x 35)
Engle 120/1.25/solid shafts
Scat SLR NON-Lubealobe
8.7:1 CR
40 Dells
1.5" A1 Sidewinder
Full flow and deep sump - Brad Penn break-in 30W
AC.N SVDA w/ Computronix set to 32 total
All parts are new
Full tin, flaps and thermostat
I built it
I'm out in the garage yesterday trying to sync the carbs with the snail gauge. Linkage is disconnected on both sides. The engine is idling happily at about 1100 and responding to the changes I'm making on the throttle stop screws. I dial it down to about 800, but it stumbles, so I'm on the way up. It starts to run slower and slower as I dial it up, like it's starving for fuel. A quick blip on the throttles brings it back up. Then I hear it....knockknockknockknockknockknockknock...and then I shut it off. It was rhythmic and started soft and slowly got louder. After sitting about 5 minutes, I restarted it, it still knocked, and I shut it down right away.
Head temp was just over 250 on my compensated Aircraft Spruce gauge and I had about 20psi of oil pressure. Oil temp was just over 120, probably not even warmed up yet. This engine has about 20 miles on it which was a few trips around the block after I broke it in and a trip to the grocery store. I haven't dug into it yet, but I'm hoping a rocker shaft just came loose. Could I have thrown a rod or spun a bearing at 800 rpm? Was that too slow to push oil around? Shattered a lifter?
I'll be pulling the valve covers off tonight when I get home, but does this sound familiar to any of you? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Thu Aug 13, 2009 8:41 am Post subject: |
Try pulling a spark plug wire and see if the sound lessens. That should be the cylinder in question.
I hope it's something simple. _________________ Glenn
Member #1009
#BlueSquare |
Ellis' Bug Samba Member
Joined: November 15, 2006 Posts: 650 Location: Phoenix
Posted: Thu Aug 13, 2009 8:55 am Post subject: |
When that happened to me, it was a rocker coming apart. Quick fix but it sure makes you panic for a while. |
sturgeongeneral Samba Member
Joined: June 23, 2005 Posts: 2460 Location: Sacramento, California
Posted: Thu Aug 13, 2009 9:06 am Post subject: |
I hope it is a rocker shaft or something simple like that. I hate to hear stories of anything worse.... _________________ Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her |
Sigurd Samba Member
Posted: Thu Aug 13, 2009 10:22 am Post subject: |
Yeah, especially because this thing has been heated up only about 5 times since I broke it in. Glenn, I thought that the plug wire test was only for electrical or fuel delivery problems. Do that work for mechanical things too? |
Glenn Mr. 010
Posted: Thu Aug 13, 2009 11:03 am Post subject: |
Sigurd wrote: |
If it's a rod knock removing the wire will lessen the load on the piston and lessen the sound. _________________ Glenn
Member #1009
#BlueSquare |
thetravman Samba Member
Joined: February 16, 2006 Posts: 508 Location: Pounding out center main . . .
Posted: Thu Aug 13, 2009 11:18 am Post subject: |
That's interesting. My engine when it was on the first few times that I started it, the rockers on BOTH heads popped loose from the rocker blocks and they were tightened fine. I tightened them up and never had a problem again. _________________ Have your car serviced at your local aircooled repair shop today.
/=O=\ good ole swing axles |
Sigurd Samba Member
Posted: Thu Aug 13, 2009 11:37 am Post subject: |
Duhh. No fire, no pressure on the piston.
Thanks for the help. I hope it's something simple and non-destructive. Or at least quickly repairable. |
a-train Samba Member
Joined: October 11, 2003 Posts: 702 Location: Issaquah via Parkland, WA
Posted: Thu Aug 13, 2009 11:41 am Post subject: |
could have sucked a washer or nut down one of the carbs.....it's happened to me before. just a thought. _________________ I like VWs |
Marv [UK] Samba Member
Posted: Thu Aug 13, 2009 12:56 pm Post subject: |
could potentially be a loose flywheel |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6027 Location: CONGERS, N.Y.
Sigurd Samba Member
Posted: Thu Aug 13, 2009 6:42 pm Post subject: |
#3 intake is stuck open. Looks like I'm pulling it tomorrow.
Glenn Mr. 010
Posted: Thu Aug 13, 2009 6:46 pm Post subject: |
Sigurd wrote: |
#3 intake is stuck open. Looks like I'm pulling it tomorrow. |
Could be worse... maybe just fix the head. _________________ Glenn
Member #1009
#BlueSquare |
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6264 Location: Chickengeorge's Neighbor
Posted: Thu Aug 13, 2009 7:42 pm Post subject: |
I wonder if you can see a foreign object in there via the intake port. |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1852 Location: Grass Pants, Orygun
Posted: Thu Aug 13, 2009 8:03 pm Post subject: |
Sigurd wrote: |
It looks pretty dry in there. _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2020lbs with driver
7.76 @ 89.55mph 1/8 mile
12.34 and 108.10 mph 1/4 mile |
The Noof Samba Member
Posted: Thu Aug 13, 2009 8:21 pm Post subject: |
stealth67vw wrote: |
Sigurd wrote: |
It looks pretty dry in there. |
X2...drier than Mother Theresa. |
Jimmy111 Samba Member
Joined: October 05, 2006 Posts: 2643 Location: Wyoming
Posted: Thu Aug 13, 2009 8:48 pm Post subject: |
Bent a valve..
Not good... |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Aug 13, 2009 9:01 pm Post subject: |
Guessin' there was no clay involved in this build? _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Thu Aug 13, 2009 11:19 pm Post subject: |
ouch that blows _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
Posted: Fri Aug 14, 2009 12:58 am Post subject: |
miniman82 wrote: |
Guessin' there was no clay involved in this build? |
I'll have to pick up some clay for my next build. But a valve must be bent. Why else other than a piston collision with the valve. _________________ Have your car serviced at your local aircooled repair shop today.
