gasket around front turn signals?
bread geek
bread geek is offline
PostPosted: Sat Aug 22, 2009 5:08 pm    Post subject: lens Reply with quote
just a sugg.after i had mine painted i replaced all the ext.screws with stainless just for kicks.can't wait to the the pics
Franklinstower
Franklinstower is offline
PostPosted: Sat Aug 22, 2009 12:58 pm    Post subject: Reply with quote
no moisture issues, just lens to new paint issues....It is like a brand new baby with the new paint!
Pictures will be up soon.
Paul
'89 Westy - EJ25/22 Frank 4.44 5mt
tangstadt
tangstadt is offline
PostPosted: Sat Aug 22, 2009 12:54 pm    Post subject: Reply with quote
nope, but you can make one if you like I used a thin bead of permatex around mine because they were fogging. They're not sealed to the rear, so moisture will still be able to get out (or in), but it solved my problem. I would say if you're not having moisture trouble, just screw em back on and hope for the best.
Franklinstower
PostPosted: Sat Aug 22, 2009 12:52 pm    Post subject: gasket around front turn signals? Reply with quote
I am assembling my '89 westy after paint - is there supposed to be a gasket between the turn signal housing and body? I don't remeber one, but it seems strange just to sitting flush against the new paint without a gasket of some sort.
Thanks,
Paul
