IRS reduction hubs
Page: 1, 2, 3, 4  Next
bevelhead
bevelhead is offline
PostPosted: Tue Aug 25, 2009 5:28 pm    Post subject: IRS reduction hubs Reply with quote
Hi i was hoping someone could help me with info on the buses fitted with reduction hubs and the irs sliding half shafts. What country and time period were they made and were the spring plates and pivot arm unique or hybrid split/bay setup, any help would be greatly appreciated, i am trying to source a set of these for a project but they seem very thin on the ground and bugger all info about them, Confused cheers Aaron
Oldfart
Oldfart is offline
PostPosted: Tue Aug 25, 2009 10:00 pm    Post subject: Reply with quote
Talk to Mr Muller
bevelhead
PostPosted: Wed Aug 26, 2009 5:08 am    Post subject: Reply with quote
of kombi rescue?
cdennisg
cdennisg is offline
PostPosted: Wed Aug 26, 2009 9:03 am    Post subject: Reply with quote
If someone makes IRS hubs to attach to reduction boxes, I would like to know, too. I have never heard of this, but I had considered making some.
nothing
Mr. Electric Wizard
Mr. Electric Wizard is offline
PostPosted: Wed Aug 26, 2009 9:06 am    Post subject: Reply with quote
I guess I don't understand what your talking about?
IRS axles inside of the swing axle tubes connected to an IRS transaxle?
I'm curious.
"Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper
sled
sled is offline
PostPosted: Wed Aug 26, 2009 9:44 am    Post subject: Reply with quote
he's talking about baywindow bus suspension, but with reduction boxes at the wheel.
I did not know there were any factory buses that came equipped with this?
I will most likely be building this kind of suspension within the next year, ive wanted to for a long time.
drive your split.
spliteric
spliteric is offline
PostPosted: Wed Aug 26, 2009 10:15 am    Post subject: Reply with quote
Brazilian Bay/Split hybrids came out with this setup around 1976.They are basically 15 window splits with a baywindow nose and the big bay window taillights.Quite a few of these were sold here in South Africa in RHD format.
It uses a beetle type gearbox with IRS sideplates, driveshafts with universal joints, not CV joints, with a splined sliding section in the middle of the shaft and reduction box hubs at the wheels similar to the 64 to 67 split buses.A very odd setup that only the brazilians could come up with.
Hope this helps.
sled
sled is offline
PostPosted: Wed Aug 26, 2009 10:16 am    Post subject: Reply with quote
pictures?
drive your split.
spliteric
PostPosted: Wed Aug 26, 2009 10:23 am    Post subject: Reply with quote
Sorry Sled, I don't have any, I'll try and make some tomorrow, I am going to a local scrapyard that has a few of these buses, I'll have a look.
Otherwise maybe Fig has some?
Cheers, Eric
my65vert
my65vert is offline
PostPosted: Wed Aug 26, 2009 11:14 am    Post subject: Reply with quote
My 74 brasilian bus has an IRS center section but has swing axles and redux boxes.
OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment.
Mr. Electric Wizard
PostPosted: Wed Aug 26, 2009 11:18 am    Post subject: Reply with quote
Hope this helps.
Damn that sounds cool!
Cool
~ Cullen Hightower
Last edited by Mr. Electric Wizard on Wed Aug 26, 2009 11:19 am; edited 1 time in total
sled
sled is offline
care to share how the axles/axle tubes join the transmission?
drive your split.
my65vert
my65vert is offline
PostPosted: Wed Aug 26, 2009 11:28 am    Post subject: Reply with quote
It is not an IRS set up, just the IRS center section with normal swing axle side plates and tubes.
OGJHC
Kombisutra;
sled
sled is offline
PostPosted: Wed Aug 26, 2009 11:32 am    Post subject: Reply with quote
oh I see, what makes the center section IRS? a swing case and dual sideplate IRS case is the same right?
drive your split.
my65vert
my65vert is offline
PostPosted: Wed Aug 26, 2009 11:54 am    Post subject: Reply with quote
I believe so? The #'s on the trans are the same as an IRS in a superbeetle. also has the sleeved shaft for the through out bearing.
OGJHC
Kombisutra;
joe56vw
joe56vw is offline
PostPosted: Wed Aug 26, 2009 11:58 am    Post subject: Reply with quote
'68 bug is 4:12 swing axle
'69-'72 bug is 4:12 irs
the only different between those that i know of is the r&p gear
and the diff one is irs only the other is swing axle only
you can redrill the gear to use either one but it is not recommand
if done wrong it can weaken the gear
'60 15 window walkthrough
why is there no sarcasism button on here?
cdennisg
cdennisg is offline
PostPosted: Wed Aug 26, 2009 1:16 pm    Post subject: Reply with quote
Hope this helps.
Cool
I would really like to see photos of this setup. I have had an idea to do a similar thing but with IRS CV's mounted to a RGB at the end, with the goal of a rear suspension lift in a spit bus. The CV's could handle a more extreme angle when re-indexing the springplates, and the RGB's keep the height. All this without lowering the engine/tranny to keep the ground clearance.
If it sounds crazy, then it's just right.
nothing
Long-roofs
Long-roofs is offline
PostPosted: Wed Aug 26, 2009 1:25 pm    Post subject: Reply with quote
Corey, I told you about that guy doing this over by CDA, he had it figured out, and could be done by now?
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
EODinert
EODinert is offline
PostPosted: Wed Aug 26, 2009 1:39 pm    Post subject: Reply with quote
Is this the bus it comes in?
'61 rag top beetle, '73 type 181, '66 13 window deluxe
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Aug 26, 2009 1:44 pm    Post subject: Reply with quote
Laughing
Page 1 of 4
