Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Wed Aug 26, 2009 1:50 pm Post subject: |
EODinert wrote: |
Is this the bus it comes in?
Possibly. That's definitely one of the buses mentioned earlier. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
Posted: Wed Aug 26, 2009 1:51 pm Post subject: |
They were called "Fleetlines" right? _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Wed Aug 26, 2009 5:51 pm Post subject: |
Long-roofs wrote: |
cdennisg wrote: |
I would really like to see photos of this setup. I have had an idea to do a similar thing but with IRS CV's mounted to a RGB at the end, with the goal of a rear suspension lift in a spit bus. The CV's could handle a more extreme angle when re-indexing the springplates, and the RGB's keep the height. All this without lowering the engine/tranny to keep the ground clearance.
If it sounds crazy, then it's just right. |
Corey, I told you about that guy doing this over by CDA, he had it figured out, and could be done by now? |
Is this the guy making the electric/hybrid bus thingy? I would be interested to see what he has accomplished so far. _________________ nothing |
SurfCityRacing Samba Member
Joined: September 12, 2007 Posts: 1286 Location: Santa Cruz, CA
Posted: Wed Aug 26, 2009 6:00 pm Post subject: |
I think this bus ad them. It was at Busfest a few weeks ago. Didn't get any pics.
_________________ Riding with Surf City had me thinking "F'n Piercy" was your real name. |
bevelhead Samba Member
Posted: Wed Aug 26, 2009 6:09 pm Post subject: |
Good to see so many responses to this. I have wanted to run reduction boxes for years but with cvs, have seen some conversions and was about to start my own when i discovered the factory, brazil, had sort of already done it anyway. Have someone in South Africa looking into it for me, i believe they were in the brazilian split/bay hybrid...not in the fleetline like i thought only a couple of days ago. I think its brilliant and dont give a stuff if it looks odd, but would rather have cvs than halfshafts, would think makes fitting options for gearboxs a bit more open unless going for in the weeds look as well, i want to go up not down, now if i can just find a 4wd jeg box and front diff and spindles.... have included some links...fist one is fleetline and brasilia in South Africa history and second link is home made irs reduction hub setup..and third is photo of factotory setup im talking about..... http://issuu.com/acvwsa/docs/vw_fleetline_bus_history http://www.mudtrials.org/thetrialscar41.htm
http://s282.photobucket.com/albums/kk259/bevelhead...p;newest=1 |
Posted: Wed Aug 26, 2009 6:51 pm Post subject: |
Trippy...
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Wed Aug 26, 2009 7:03 pm Post subject: |
So this setup would require trailing arms, yes? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Wed Aug 26, 2009 7:56 pm Post subject: |
Yes. The pics in the link show them. The Brazilian setup looks to have used trailing arms also.
From the text on that site:
Inside end of the radius arms. Four tubes welded into the end of a Toyota Corolla lower control arm (front). Bracket on torsion bar housing is RHS, and the mounting point is adjustable vertically. Lateral adjustment is by spacer washers. _________________ nothing |
Posted: Wed Aug 26, 2009 8:32 pm Post subject: |
Interesting inboard disc brake setup, too. I wonder how loud the log chain limiting straps are on an open buggy? _________________ nothing |
Andy P Samba Member
Joined: February 04, 2001 Posts: 1166 Location: NSW, Australia.
Posted: Thu Aug 27, 2009 2:52 am Post subject: |
Tell me, do they IRS/redux-hub buses have the same tuck-under problems the swingaxle buses did? _________________ Cheers & God Bless
'62 Beetle
Jägdwagen |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Thu Aug 27, 2009 6:44 am Post subject: |
Andy P wrote: |
Tell me, do they IRS/redux-hub buses have the same tuck-under problems the swingaxle buses did? |
No. The "extreme" tuck is cause by the swing axle. The trailing arm basically "replaces" the swing axle as far as suspension geometry is concerned. It still does affect camber both positive and negative depending on initial set up and up/down travel, but no as severely as it does with the swing axle.
Here's a pix of my new IRS at its extreme, jacked up position. Looks to be about 1-2 degrees. I'll have to put my angle finder on a swing axle bus for comparision.
_________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Thu Aug 27, 2009 7:02 am Post subject: |
Oh man!
Just when you think you've seen it all.
Too cool. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
Posted: Thu Aug 27, 2009 7:28 pm Post subject: |
Seeming as we are on cvs etc heres one for the off road guys....http://www.thompsoncouplings.com/ |
Andy P Samba Member
Posted: Fri Aug 28, 2009 5:18 am Post subject: |
Those were on the ABC show The Inventors weren't they?
Can't remember exactly how they worked but I remember them being pretty impressive. _________________ Cheers & God Bless
'62 Beetle
Jägdwagen |
Posted: Fri Aug 28, 2009 5:52 am Post subject: |
Yep thats them, bloody amazing, wish they would hurry up and make them for cars. |
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
Posted: Mon Aug 31, 2009 3:41 am Post subject: |
Anyone know if the gearbox output shaft for the axles unique to this or same as cv? |
