dewglass Samba Member
Joined: August 23, 2009 Posts: 58 Location: cottonwood, AZ
Posted: Wed Aug 28, 2013 3:01 pm Post subject: Crank seal at fan hub |
Great thread.
I used that harmonic balancer puller with great success afterTrying many of the other suggestions. I am now attempting to replace this same crank seal and 'o' ring without dropping the engine - can't seem to get the seal to seat all the way down. Any special tools or sealing compounds? I see the tool recommended in the Bentley, of course that's not happening. Thanks in advance for any suggestions.
Doug |
Posted: Wed Aug 28, 2013 3:40 pm Post subject: |
Did your use a sealant on the exterior of the seal? If you used something like silicone the seal may keep trying to work its way back out. A little oil on the exterior of most seals is all you need, though I use Permatex on some.
A large socket can be used to drive in a seal or an old bearing race, but I usually just use a squared off chisel I have. I just work my way around the edge tapping the seal in a bit here and there. |
Posted: Wed Aug 28, 2013 9:08 pm Post subject: |
Ok. Ill give that a try. How about the 'o' ring - where is it supposed to go exactly? Also, this engine doesn't even have 50,000 miles on it, has good ventilation, and is leaking like a champ from this seal. Should I be concerned that it is something more serious? Thanks for the speedy reply. Doug |
Posted: Thu Aug 29, 2013 3:44 am Post subject: |
The o-ring goes onto the taper on the end of the crankshaft before you install the hub. Never understood exactly how it seals with the keyway being there???
Are you sure the seal is where the leak is coming from? The oil pressure switches are notorious for leaking. |
Posted: Thu Aug 29, 2013 12:04 pm Post subject: |
Almost certain, I tackled the pressure switch two weeks ago and it looks to be staying dry. |
Posted: Thu Aug 29, 2013 2:06 pm Post subject: |
So that 'O' ring goes where? |
Posted: Thu Aug 29, 2013 2:47 pm Post subject: |
Posted: Thu Aug 29, 2013 2:48 pm Post subject: |
Posted: Thu Aug 29, 2013 2:56 pm Post subject: |
It slides onto the taper on the crank and the recess in the end of the hub will mate with it as the hub is installed. Funky but it works. |
Posted: Thu Aug 29, 2013 2:58 pm Post subject: |
As pictured? |
Posted: Thu Aug 29, 2013 3:00 pm Post subject: |
dewglass wrote: |
As pictured? |
No!!! You slide the o-ring onto the taper on the crank, it does not go on the hub. |
Posted: Thu Aug 29, 2013 3:06 pm Post subject: |
Hmmmm
Kinda makes more sense on the hub. Fits good too. |
Posted: Thu Aug 29, 2013 3:52 pm Post subject: |
Do it however you want and post your results for the next guy. |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Thu Aug 29, 2013 4:28 pm Post subject: |
I just thought I would add to this thread that the gasket for the oil filler tube is the same as the 30pict-1 bug carb gasket. The VW parts stores will always have the 30pict-1 carb gasket. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Posted: Sat Aug 31, 2013 8:19 am Post subject: crank seal at fan hub |
so far so good. this AVP rebuild has been leaking since we put er in almost 3 years ago. can hardly believe it has stopped leaking now this crank seal was redone and quite possibly the "O"ring being placed in the right location :/
here is a link to ratwells page on seals where he refers to this "o"ring
http://www.ratwell.com/technical/GasketSet.html
cheers |
Posted: Sat Aug 31, 2013 11:32 am Post subject: |
Where did you end up putting the o-ring? |
Posted: Sat Aug 31, 2013 11:34 am Post subject: |
Wildthings wrote: |
as per ratwell - on the fan hub |
Posted: Sat Aug 31, 2013 11:55 am Post subject: |
Not going to seal much there as it is outside of the shaft seal and there is therefore nothing to seal. The purpose of the o-ring is to prevent oil from working down the taper past the woodruff key and out past the bolt and washer, as I said it is kind of funky. The washer will typically do the sealing job anyway so it probably won't matter, but if it starts seeping around the washer you can just remove the bolt and washer and smear some silicon on the mating surfaces and reinstall. That should stop any seepage.
Pick up a Haynes and check out Figure 18.3b. |
Posted: Sat Aug 31, 2013 1:40 pm Post subject: |
anyway to up load that image? |
Posted: Sat Aug 31, 2013 1:48 pm Post subject: |
Guess I could take a picture of it, upload it, and link to it. Not going to happen right now though. |
