dewglass Samba Member
Joined: August 23, 2009 Posts: 58 Location: cottonwood, AZ
Posted: Sat Aug 31, 2013 2:57 pm Post subject: |
sweet |
Posted: Mon Sep 02, 2013 9:31 pm Post subject: |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Mon Feb 22, 2016 1:27 pm Post subject: Re: Type IV fan shroud removal (Oil Leaks) |
Good thread for me. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 1227 Location: Edmond Oklahoma
Posted: Mon Feb 22, 2016 4:02 pm Post subject: Re: Type IV fan shroud removal (Oil Leaks) |
I have been battling this exact issue. I also pulled the fan and replaced the fan hub seal. Didn't know about the O-ring that I am sure I am missing at this moment!
I ran the engine with out the fan with the old seal and new seal and no leaks.
I replaced the dipstick oring and was using a Re popped Bus Depot oil filler, but it didn't last long.
Last I found what I think has been leaking so bad. My breather gasket was torn. I cut a new gasket out of cork. Seems to have helped. _________________ James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020 |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Sat Jul 08, 2017 4:17 pm Post subject: Re: Type IV fan shroud removal (Oil Leaks) |
I’m about to tackle this job in a 79 transporter, hopefully without much fits.
From what I’ve gathered thus far, I need a harmonic balancer puller, remove the center (fan area) cooling tin, a new crank pulley seal and O-ring and some time, correct? Button things back up, smile, and cruise looking back over my non-oily fan and motor? _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
