Change your ignition switch
ftp2leta
ftp2leta is offline
PostPosted: Tue Sep 01, 2009 7:07 pm    Post subject: Change your ignition switch Reply with quote
Is that clear enough???
You want proof? You want to know why?
I will only tell you that this stupid part cost me a lot this year, not counting all the customers that where stranded somewhere because of a 20$ parts.
So get 20$, read that:
http://www.benplace.com/dash.htm
And change that stupid part! Stop saying mine is fine and listen to guys like me who work on those van 50 hours a week.
So what does it take to convince you? An electric fire????
I'm not kidding here.
Ben
Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta
dobryan
dobryan is offline
PostPosted: Tue Sep 01, 2009 7:20 pm    Post subject: Reply with quote
I've been thinking that would be good preventative maintenance and now you've pushed me over the edge. It will get done.
Thanks. Very Happy
Dave O
The Western Syncro build
dubstar
dubstar is offline
PostPosted: Tue Sep 01, 2009 7:23 pm    Post subject: Reply with quote
what happens to the switch as it ages? corrosion or wear and tear causes short circuits that can lead to fire?
1963 Type II Kombi
1977 Type I Fuel Injection
http://instagram.com/john_aka_dubstar/
http://web.stagram.com/n/john_aka_dubstar/
"you could transport really tall things too, like a giraffe"
ProvoCyclist
ProvoCyclist is offline
PostPosted: Tue Sep 01, 2009 8:17 pm    Post subject: Reply with quote
I did mine about a year ago, lock cyl and switch (overkill, i know) to try and remedy a random no-start thing happening...didnt fix it Embarassed , turns out the starter had gone to hell.
Oh well, the switch was pretty far gone anyway. An ounce of prevention as they say.
Clark
agreendaya
agreendaya is offline
PostPosted: Tue Sep 01, 2009 9:35 pm    Post subject: Reply with quote
Don't know how it causes fire, but I had mine try to strand me several times. Good news is if you've got two short pieces of wire, it's a piece of cake to do an emergency repair (what I had to do). If you just pull the wiring bit out of the back of the switch, connect the fat red wires (I think one is striped), then jump that to the other hole that does the starter (just guess & check). You of course need to have the key to unlock the steering wheel...
Having put that info up here, it is super easy to replace the switch.
'74 Bug - Gone
'69 Westy - Gone
'74 Westy - Gone
'78 Transporter - Gone
'69 Baja - Gone
'91 Vanagon Carat - Gone
‘71 Bus - Gone
Current: ‘74 Westy 2.0L, hydraulic valves, dual EMPI 34s
?Waldo?
?Waldo? is offline
PostPosted: Tue Sep 01, 2009 11:18 pm    Post subject: Reply with quote
Mine's fine. Very Happy
Mundopacheco
Mundopacheco is offline
PostPosted: Wed Sep 02, 2009 12:35 am    Post subject: Reply with quote
BTW that mounting screw that Benny points to with his red arrow, should be good and tight. I always put blue lock tite on the threads. This can work itself loose and be quite an irritant. I've gone in there thinking the switch had to be replaced, and it turned out to be loosely mounted....just an FYI
?Waldo?
?Waldo? is offline
PostPosted: Wed Sep 02, 2009 7:28 am    Post subject: Reply with quote
I really wish that VW had put the mounting screw accessible without removing the whole ignition lock assembly. If they had put the screw on the outside of the assembly, it would be 1/20th of the work to swap out.
Andrew
ajdenette
ajdenette is offline
PostPosted: Wed Sep 02, 2009 1:30 pm    Post subject: Reply with quote
And 1/20th the effort to steal the van after you get in!! I dont mindthe work that makesit harder for some one else.
dobryan
dobryan is offline
PostPosted: Sat Oct 17, 2009 11:41 am    Post subject: Reply with quote
Thanks. Very Happy
Got it done today.
Thanks! Very Happy
Dave O
dobryan
dobryan is offline
PostPosted: Sat Oct 17, 2009 11:43 am    Post subject: Reply with quote
Actually that switch isn't needed at all to steal the bus. Just take off the harness plug from the bottom of the switch and then jump the right terminals. Takes 30 seconds. Only problem would be the steering wheel lock, but that can be defeated as well.
Dave O
errolprowse
errolprowse is offline
PostPosted: Sat Oct 17, 2009 4:52 pm    Post subject: Reply with quote
thats why i roll with a big old steering wheel lock that goes over the whole thing. i think it offers better protection than a alarm in some ways.
'89 Vanagon GL
The ultimate kiteboarding/surfing/skimboarding van!
dobryan
dobryan is offline
PostPosted: Sat Oct 17, 2009 9:23 pm    Post subject: Reply with quote
And I have a fuel pump relay that is activated by a regular switch on the dash panel. If you don't know which one to turn on it won't start. Hidden in plain sight. Laughing
Dave O
Vsyevolod
Vsyevolod is offline
PostPosted: Sat Oct 17, 2009 11:23 pm    Post subject: Reply with quote
Details please!
Stephen
scobax
scobax is offline
PostPosted: Sun Oct 18, 2009 1:30 pm    Post subject: Reply with quote
The wierd thing is, I read this yesterday during my morning coffee, then about an hour later the wife and I jump in the van to go for a hike. We made it about a block and lo-and-behold, the wipers won't work- nor will the lowbeams- nor the heater fan.
We turned around, I pulled the ignition plug, hotwired it, and everything came back. Crazy timing! If I hadn't read this post that morning, I probably would have spent hours trying to figure out what happened. Then again, maybe if I hadn't read this post, the switch wouldn't have failed!!
All of these have worked fine for years. It's as if reading this post was all that it took to kill the ignition switch! Spooky!
Thanks Ben, but I'd appreciate it if you wouldn't do that long-distance Canadian voodoo again! Wink
87 Syncro Westy w/ Suby 2.5
RIP: 2.1 WBX. You were a good dog 'ol feller
“The word adventure has gotten overused. For me, when everything goes wrong, that's when adventure starts” -Yvon Chouinard
"It's not expensive, its priceless" -Unknown
dobryan
dobryan is offline
PostPosted: Sun Oct 18, 2009 5:00 pm    Post subject: Reply with quote
Vsyevolod wrote:
Details please!
Stephen
I use a fog light switch to activate a relay that connects the ground wire for the fuel pump. With the fog light switch in the 'ON' position the relay is active and the ground circuit is complete. In the 'OFF' position the relay breaks the ground connection. How many people will turn on the fog light switch prior to trying to start a car? Very Happy
Dave O
DWC
DWC is offline
PostPosted: Sun Nov 01, 2009 7:12 pm    Post subject: Reply with quote
I'm starting the "I hate Ben" post.
Damn it Ben, your always right!
Changing the switch was a pain in the ass, but it would have been a bigger pain in the ass without the link to your page showing all the steps to take to get to the switch since the Bently didn't really show anyone what was involved.
Perhaps I will add 10c and Dogpilot, and Kevin and a few more of you that always help me when I've got a problem (and everyone else here) to the post.
Seriously, thank you all - you've been a great help and it's appreciated.
DC
83.5 Westy Waterboxer
71 Squareback
81 Westy
59 Panel van
ftp2leta
ftp2leta is offline
PostPosted: Mon Nov 02, 2009 6:14 am    Post subject: Reply with quote
DC
No need to start such a thread, i have plenty of enemies. 30% like to argue with me, i have learned how to deal with them.
When you do that once, and only once:
You learn about everything, no way out.
I choose to share, that is my problem.
dobryan
dobryan is offline
PostPosted: Mon Nov 02, 2009 6:30 am    Post subject: Reply with quote
Ben,
Sharing is not a problem, it is a gift. The problem is when a small amount of people want to argue about what is being shared. But you already know this.....
Always live your life by sharing.
All the best.....
Dave O
gears
gears is offline
PostPosted: Mon Nov 02, 2009 9:05 am    Post subject: Reply with quote
Thanks a million for the help, Ben. Due to your clear photo tutorial, it took me about 30 minutes to change my ignition switch instead of probably a couple hours of head scratching. Great stuff.
Page 1 of 8
