j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Tue Apr 13, 2021 10:04 am Post subject: Re: Shift Extender Ruins Transmissions? |
SHIFTING should require no more than two fingers on the knob.. If more force is necessary, then adjustment is out.. or there is something in the rod linkage not right. (or even worse trans itself is ready for a rebuild)
The extender, at worst, may compound the real problem... because it gives a little more lever to your hand/arm force.
I don't think data exists to say it can be "fact" one way or another.
I've had an extender for years and years. 150k+ miles?
And one trans failed due to abuse.. that's on me.. Not the extender. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Sodo Samba Member
Joined: July 06, 2007 Posts: 9517 Location: Western WA
Posted: Tue Apr 13, 2021 10:48 am Post subject: Re: Shift Extender Ruins Transmissions? |
j_dirge wrote: |
SHIFTING should require no more than two fingers on the knob. |
Agreed !
A ^^random pic^^ of the gear lever extension.
I think they're saying the increased leverage will enable a ham-fisted driver to increase the load on the shifting components.
If you MUST shift fast, it puts more pressure on the synchros and they will wear out faster.
It seems reasonable that owners (the few who maintain their transaxles )
would choose a modern gear oil of higher lubricity to get longer life from the transaxle.
Then they discover that this added protection comes at a cost - that it's now harder to shift fast
( as they were accustomed to / habit etc).
And rather than adapting driving style (shift slower)....
prefer to keep shifting fast by increasing the leverage (with that gear lever extension).
Another feasible problem is the shifting is difficult because of linkage wear, defect, or lack of lubrication.
Adding a lever extension might just break the shift lever off at the base. _________________
....KTMs, GasGas, SPOT mtb
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17009 Location: Retired South Florida
Posted: Tue Apr 13, 2021 11:12 am Post subject: Re: Shift Extender Ruins Transmissions? |
VW did not use shift stops in their transaxles back in the day. If you are gentle on your shifts as described, the shift lever could be up to the mirror and you aren't going to hurt anything.
If you shift hard, you are shoving the slider ring and syncro against the gear. With the extra leverage, you could force it enough to let the dogs pop out. Not good. You could also exert more load on the shift fork with the extra leverage.
If you are concerned, you could add bearing locks to both sides of one of the shift bushings to act as physical stops. I did this on my VW race car. _________________ ☮️ |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6798 Location: Fort Lauderdale, Fl.
Posted: Tue Apr 13, 2021 12:29 pm Post subject: Re: Shift Extender Ruins Transmissions? |
On the original British Mini somebody came up with a shift lever extension so you didn't hit the dashboard with your knuckles when shifting.
It was a short extension really, but the end resulting theory was that the added weight of the shifter was helping wear out whatever it was that kept the transmission in gear because as it aged it kept dropping out of gear the top gear closet to the dashboard. The extension curved away from the dash so the assumption was the weight was off center on the original shift lever.
Just saying! _________________ This free advice is worth exactly what you paid for it.
Sodo Samba Member
Posted: Tue Apr 13, 2021 12:40 pm Post subject: Re: Shift Extender Ruins Transmissions? |
Steve M. wrote: |
The extension curved away from the dash so the assumption was the weight was off center on the original shift lever. |
Perhaps the driver adds the weight of their right hand to
the shifter (for extended periods) as well, putting a constant
pressure on the 4th gear shift fork. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Tue Apr 13, 2021 12:43 pm Post subject: Re: Shift Extender Ruins Transmissions? |
Sodo wrote: |
Steve M. wrote: |
pressure on the 4th gear shift fork. |
Nobody ever "proved" any reason, but the ones without the extension I do not remember having the problem or I'm just getting senile. _________________ This free advice is worth exactly what you paid for it.
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15129 Location: Syracuse, NY
Posted: Tue Apr 13, 2021 12:55 pm Post subject: Re: Shift Extender Ruins Transmissions? |
I'd say this, user heavy handed
if it's easier to rest a hand on the shifter people(I) will.
it's only in these later years I've learned that's bad and try to brake myself of the habit. having armrests helps alot.
Sodo wrote: |
Steve M. wrote: |
Abscate wrote: |
