NAES Samba Member
Joined: September 10, 2003 Posts: 2121 Location: AREA-52 Southern Killafornia
Posted: Fri Sep 04, 2009 4:48 pm Post subject: All steel Avis adjusters |
I'm familiar with all steel Avis style adjusters and have only used them in the past. Now I came across a set that were steel but the clamping part was aluminum. I don't really like that idea. Anybody know where I can get some all steel Avis style adjusters?
Thanks, NAES _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
my65vert Samba Member
Joined: November 09, 2003 Posts: 6186 Location: Middleburg, Florida
Posted: Fri Sep 04, 2009 4:49 pm Post subject: |
The ones with the aluminum clamping part are for beetles I think? _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
spook Samba Member
Joined: December 30, 2003 Posts: 2038 Location: in the shop 35750
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
Posted: Fri Sep 04, 2009 6:08 pm Post subject: |
Either CSP or Wagens West. _________________
aeromech wrote: |
in my opinion you don't know shit |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Fri Sep 04, 2009 6:42 pm Post subject: |
I prefer the aluminum ones. They have better grip. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
NAES Samba Member
Posted: Fri Sep 04, 2009 10:16 pm Post subject: |
Anybody had issues with the aluminum ones failing or doing anything weird? If Jeremy says they work well, then I might just go with them. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
Posted: Sat Sep 05, 2009 5:41 am Post subject: |
I have used a couple of the all steel type and one beam the guy ended up having to tack weld the plate to keep it from slipping. The problem is the grooves are rolled into the steel and don't mesh very well. The aluminum on s I have used have sharp teeth and fit right into the grooves. I have aluminum ones on my deluxe now for 5 or six years of lots of driving and they have never slipped . I also never mess with them. Once I found the right height I left them alone.
The CSP ones are nice and don't apply to my experience. _________________ Why buy what you can build.
mtb7001 Samba Member
Joined: February 11, 2009 Posts: 899 Location: Meridian Idaho
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Sun Sep 06, 2009 9:46 am Post subject: |
but they will fit a bus with a little work. _________________ OGJHC
Kombisutra;
Posted: Sun Sep 06, 2009 10:36 am Post subject: |
they you can make them fit but they don't work good on a bus
i have them on my '56 project and they don't hold
i haven't even driven the bus yet and the adjusters slip _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Sun Sep 06, 2009 11:57 am Post subject: |
joe56vw wrote: |
i haven't even driven the bus yet and the adjusters slip |
Perhaps try tightening the nut on the adjuster screw more. Those looks like the adjusters that are in my beam (jeremy built my beam probably 5ish years ago) and when I first set the bus on the ground after putting the beam in, the adjusters slipped because I didn't have the nuts tightened enough. Tightened them up about as much as I could, messed with them maybe once since, and haven't had a single problem since then. No slipping what so ever. _________________ -Andrew |
Posted: Sun Sep 06, 2009 1:12 pm Post subject: |
i have tighten them and i have the same issue with the ones on my wife's bug
i have run into this problem before with other beams i have build
the only ones i have not had any issues with are the one i have filed to make them fit better _________________ '60 15 window walkthrough
