No Wire on Oil Sensor Switch 78 bus
kerian159
kerian159 is offline
PostPosted: Sun Sep 06, 2009 10:06 am    Post subject: Reply with quote
Yay! always take pics of stuff Smile I tell that to older people when they need to bring their computer to me to work on. Digital or Polaroid works when brain's do not!
Jay
1976 Type II Westy P22 (Mine)
1969 Type I Autostick (Wife's)
"Growing older, but not up!"
pcon42
pcon42 is offline
PostPosted: Sun Sep 06, 2009 9:53 am    Post subject: Problem solved! Reply with quote
Remembered I took a picture before I bought this bus, blew it up and saw I had one wire missing. Now it starts. Thanks for the help.
pcon42
pcon42 is offline
PostPosted: Sun Sep 06, 2009 5:51 am    Post subject: no luck Reply with quote
Tried the wd 40 but not luck, checked the hoses and all are in order. Go figure, wanted to make my first bus nice looking and I screwed it up!
Any other advice?
Saw a post to check the spark on everything.
Thanks
VDubTech
VDubTech is offline
PostPosted: Sun Sep 06, 2009 5:29 am    Post subject: Reply with quote
Rusty O'Toole wrote:
Some engines are wired so if you lose oil pressure it kills the ignition. Not sure if VW ever did this.
Definitely not. The lack of wire to the oil pressure switch isn't cauing your engine not to start. If it ran before you cleaned it, it has to be a simple problem. Spray some WD-40 under the cap and give it another go.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
Rusty O'Toole
Rusty O'Toole is offline
PostPosted: Sun Sep 06, 2009 5:26 am    Post subject: Reply with quote
Hook it up and see. Some engines are wired so if you lose oil pressure it kills the ignition. Not sure if VW ever did this.
You may have knocked something else loose accidentally. Go around and push all the electrical connectors on good and vacuum hoses too.
pcon42
pcon42 is offline
PostPosted: Sun Sep 06, 2009 4:40 am    Post subject: No Wire on Oil Sensor Switch 78 bus Reply with quote
After cleaning the engine and compartment with a degreaser, my engine will now not start. I didn't douse it at all. Have a spark off the coil and today will test if the distributor works and the plugs. I did notice there is no wire to the oil switch. Can this be the simple problem?
Thanks
