widehatch Samba Member
Joined: May 27, 2007 Posts: 775 Location: Memphis, TN aka The Armpit of the South
Posted: Wed Sep 09, 2009 9:46 am Post subject: 40HP question |
i just picked up a 64 beetle w/ a 1200cc 40hp engine. i got it running but it sounds like it has a loose head. none of my vw books go back that early so here's my question.
is the head tourque the same as a 1600? if no. whats the proper tourque.
whats the valve clearence so i can adjust the valves? _________________ Missouri Micros |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Sep 09, 2009 12:09 pm Post subject: |
You are going to pull the heads off and have a look right? If it has had a loose head, you need to make sure the mating surface between head and cylinder is OK.
If you just torque them down and there is not a good clean mating surface, you will have wasted your time and might torch a head or a cylinder.
If you need to clean up that surface, you can use a dab of valve grinding compound and just work the cylinder around for a bit.
Sorry I'm not able to check my books for you to answer your question right now, but I'll try latter if no one else has chimed in. _________________ Mother Nature is a Mean Evil Bitch! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Wed Sep 09, 2009 6:08 pm Post subject: |
Hover your mouse on the "Technical" button above. Up will pop a list. Left click on "Manuals". Next webpage select "Misc. Manuals & Instructions". The next webpage check out the "Without Guesswork" manuals there for torque values.
If the heads are loose you really should retorque ALL the engine fasteners in same sequence as if you were rebuilding it. Simply amazing how loose the main case studs and the nuts and bolts around the case halves can get!!! _________________ In Stereo, Where Available! |
nirahlee Samba Member
Joined: August 20, 2008 Posts: 31 Location: Dearborn Heights, MI
Posted: Thu Sep 10, 2009 11:05 am Post subject: |
what were the symptoms that you might have a loose head? |
FINEGERMANSTEEL Samba Member
Joined: February 21, 2008 Posts: 261 Location: Spokane Wa
Posted: Thu Sep 10, 2009 10:41 pm Post subject: |
40 HORSES OF POWER HA. I JUST COMPLETELY REBUILT MY EARLY 40H AND HOPEFULLY PUTTIN IN MY 61 TOMARROW! BUT CANT RECALL TORQUE SPECS ON HEADS. _________________ --MovedFromSeattleArea2SpokaneLate2021-----------
60 bus mango
61 bug. low n slow1200
65 bus project_sadly sold it
66 squareback project..in process..kinda
--CultWagen--slowlow61 |
glutamodo The Android
Joined: July 13, 2004 Posts: 26310 Location: Douglas, WY
Posted: Fri Sep 11, 2009 3:58 am Post subject: |
It's the same as later 10mm head studs - the final torque pattern is at 22-23 ft lbs.
Now though, as mentioned, just tightening a loose head might not help out a whole lot. I've seen 40HP engines pull the lower studs right out of the block before too. You can get those "fixit" studs that are an alternate pitch, slightly larger self-tapping thread that will usually work in a pinch if that happens.
Now valve adjustment on 40HP.... depends on the type of rocker gear you have. I'm not going to repeat myself on that topic, instead I'll point you at this thread where it's thoroughly discussed:
http://www.thesamba.com/vw/forum/viewtopic.php?t=103248&
-Andy |
-Andy |
