elikus Samba Member
Posted: Fri Sep 11, 2009 10:43 am Post subject: Turn/hazard signals help! |
Ok, I went and searched the forums and found many helpfull ones, but I'm still stock with my problem and after performing different test suggested by others I gave up. Evrything was working a couple of weeks ago and now.
Here is my situation:
1966 sedan, 12v converted; 211 953 227 A FLASHER BOX
Emergency signal: I get none of the bulbs light up or any sort of blinking on them, but the speedo light bulb on but steady while the ignition switch is off, when ignition is on speedo arrow goes off.
Lef/Right turn switch signals: When turn right or left, light bulbs on but steady in either case, no blinking. Speedo arrow off.
I checked grounds, and replaced with a NEW FLASHER BOX, no success. I guess I wasted my money there . Is that mean that the turn signal switch may be the problem? Can anybody tell me how to test my turn signal switch?
I'm tired of going thru the diagrams and checking all connection over and over. Please I'll appreatiate any help. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Fri Sep 11, 2009 11:02 am Post subject: |
Checking the turn signal switch is very simple. All it does is connect terminal 49 to either R or L. Just unplug those 3 wires and connect them by jumpering them by hand. Although I'm thinking your switch is probably fine, if activating the switch is making the lights come on.
Sounds like you are getting uninterrupted power out of the flasher relay. Why, I don't know. A grounded relay like this will send power straight through to light up the lights outside the car as soon as you engage the switch, then they'll start to flash off/on. The dash light, comes from a separate set of contacts, although you can just hook those up to terminal 49a and they'll flash opposite of the outside lights (on inside, off outside and vice-versa)
Are you using standard 12V incandescent bulbs?
Did both the old flasher relay and the new one have the same symptoms?
Have you thought about forgetting the e-flashers for now and just trying it with a normal VW-style 3 terminal relay? ( or even a an el-cheapo 2-prong unit, which works but I don't like them )
-Andy |
elikus Samba Member
Posted: Fri Sep 11, 2009 11:19 am Post subject: |
Yes, I'm using standard 12V bulbs and Yes both flashers have the same symptoms. that is why I thought I wasted money buying another one. The old one is the original and the new one is the replacement that I got from Wwest. http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211953227BWW
I did not know about using the style-3 terminal I guess at the end I might need to do that, but I'll deffinetely would like to try to solve this first, since already spent some on that new one.
Thanks for the reply, I'm going to try connectinf the 49. I'll post what happend. |
elikus Samba Member
Posted: Fri Sep 11, 2009 11:37 am Post subject: |
Ok, connecting 49 to either R or L terminals, will light up the bulbs but no blinks, just steady, same as before when turning the switch to left or right. |
Jeckler Samba Member
Joined: September 27, 2005 Posts: 2718 Location: Mesa, AZ
Posted: Fri Sep 11, 2009 12:29 pm Post subject: |
Is it an original relay with the hole in the middle? Is it bolted down? The ground for the relay is provided through that mount. _________________ Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote: |
I am the crabby old guy. |
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad. |
Posted: Fri Sep 11, 2009 12:31 pm Post subject: |
He said the latest one was a WW repro, which should have a dedicated ground wire. |
elikus Samba Member
Posted: Fri Sep 11, 2009 1:04 pm Post subject: |
Yes the original is the one with the hole in the middle thru which the ground is provided. |
elikus Samba Member
Posted: Sat Sep 12, 2009 7:36 pm Post subject: |
still noting so far, thanks guys. |
rokemester Samba Member
Posted: Sun Sep 13, 2009 7:42 am Post subject: |
Has anyone experienced a situation where the turn signal indicator on the speedo works intermittently, but the exterior lights work fine? The longer the car has been running, the speedo indicator seems to work more regularly. I'm wondering if it has something to do with the generator/regulator. At idle the red light goes on, but during acceleration the red generator light goes off. |
Posted: Sun Sep 13, 2009 8:23 am Post subject: |
I've seen or heard of 9-pin and 4-pin terminal relays (any such one with a separate terminal for the K dash warning light) go bad to where it the main contacts work to flash the lights but not connect on the secondary contacts for the dash light.
Yours is still 6V right? The gen light being on at idle on a 6V is not unusal and is OK if as long as it goes out when revved, and is noted as such in the owner's manual.
-Andy |
Posted: Sun Sep 13, 2009 10:12 am Post subject: |
Yep, you're absolutely right Andy, a 6v holdout. I'll check those contacts and the relay. Thanks! Enjoying the first regular NFL game of the season as I write this. |
Fusillade Samba Member
Joined: April 24, 2003 Posts: 399 Location: Abilene, TX
Posted: Mon Oct 26, 2009 8:22 pm Post subject: |
elikus wrote: |
Did you resolve your problem? _________________ Fusillade |
elikus Samba Member
Posted: Fri Apr 09, 2021 5:06 am Post subject: |
Fusillade wrote: |
elikus wrote: |
Did you resolve your problem? |
Yes, I did. And honestly do not remember what was the problem. But it was not the relay or the flash switch. After solving the issue, I sold the car a couple of years afterwards.
Interestingly enough I just purchased another 66 Bug and guess what, after getting it home last week, it has the same exact problem
I'm in the process of finding out what it is this time.
I found this VW 9 Prong Box Troubleshooting and Replacement by Matt Roberds very helpful: http://www.type2.com/library/electris/vw-9prong.html#Troubleshooting
and as mentioned by Matt, "Thom Fitzpatrick has put up color scans of *many* air-cooled VW wiring diagrams, not just Buses, at https://web.archive.org/web/20190816155922/http://www.vintagebus.com/wiring/index.html."
Thanks All for the help |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Fri Apr 09, 2021 6:32 am Post subject: Re: Turn/hazard signals help! |
An 11-year delay in responding... that has to be a record!
I'm just messing with you.
That page on the 9-prong flasher relay looks like it could be very useful. When you resolve your flasher problem on your new '66 be sure to post here what the fix was. _________________ AshMan40
elikus Samba Member
Posted: Sat Apr 10, 2021 7:44 am Post subject: Re: Turn/hazard signals help! |
I found the issue(s). But let me start by saying, sometimes the most simple things can eat you alive
I just got this beetle (week ago), and the battery cables and terminals had the colors switched and you get the idea, positive pole connected to the ground... etc. Spent good time testing relay, switch, flasher and every part including ground connections all over, was getting frustrated. I should have of course of course, checked the grounding to the battery first. That’s how I found out the crossed connections.
After that the majority of the issues got resolved. Then afterwards testings gave me good results and found some bad connections. Only need the high/low beam relay for now.
If it has not been mentioned before in any post, MAKE SURE THE BATTERY IS CONNECTED CORRECTLY!!!!!! |
