Fabinstein Samba Member
Joined: April 11, 2009 Posts: 257 Location: brawltimore
Posted: Sat Jun 05, 2010 9:28 am Post subject: |
now thats just some nice work there... |
VeGaSFREAK Samba Member
Posted: Sun Jun 13, 2010 9:18 pm Post subject: |
FANTASTIC ! ! ! |
bigred1957 Samba Member
Posted: Tue Aug 23, 2011 8:48 pm Post subject: Maybe a thought |
This is a very slick conversion! I've been thinking the same but trying to simplify a bit more. Yours reminds be of a bug alternator but backwards. How about that? See what I'm saying? Install the pully on the fan end of the bug alternator, only does anyone know if you can run a bug alt backwards and still work? I don't have any lying around to try or I would answer that myself. Any thoughts? Although I do like this conversion! |
supaninja Samba Member
Posted: Tue Aug 23, 2011 8:54 pm Post subject: Re: Maybe a thought |
bigred1957 wrote: |
a bug alternator can spin backwards but the problem is cooling. in a bug the tin has a duct on the back. the t3 generator has a port on the side for cooling. even t4 alternators have ducting for airflow into them. _________________ http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/ |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Tue Aug 23, 2011 9:16 pm Post subject: |
why can't you put a alternator fan on the "back end"? (the front in a bug).
it should draw air from the engine belt shroud and through the alternator and out its fan on the back. |
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 479 Location: Australia
Posted: Wed Aug 24, 2011 5:33 am Post subject: |
You should be able to put the cooling port in a type 1 alternator. |
Posted: Sun Jul 28, 2013 4:15 am Post subject: |
004-009
Posted: Sun Jul 28, 2013 11:40 pm Post subject: |
Been experimenting with a slightly different donor alternator, it has a 93mm diameter stator compared to the 100mm I normally use. I can get these new as genuine NipponDenso.
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Jul 29, 2013 1:16 am Post subject: |
mackaymanx wrote: |
So are you building these for sale? If yes, please PM me. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Mon Jul 29, 2013 1:27 am Post subject: |
$$$? How much? _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Posted: Mon Jul 29, 2013 3:35 pm Post subject: |
Presently I'm only selling locally here in Australia. |
Posted: Thu Aug 01, 2013 4:21 am Post subject: |
Mark II
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Thu Aug 01, 2013 5:31 am Post subject: |
I have to say this is a pretty sweet way to make it fit without modification. Great job! I'm still struggling to make the ND alternator fit with custom brackets... _________________ 69 Fastback Build
Berg5 Build |
damauk Samba Member
Joined: July 23, 2012 Posts: 48 Location: Riverton, WY
vlad01 Samba Member
Posted: Fri Aug 02, 2013 1:46 am Post subject: |
mackaymanx wrote: |
Mark II
fuckin nice!
good work.
question? what are you doing to ground the alternator?
i see the case is painted so I see no obvious means of ground. |
Posted: Fri Aug 02, 2013 2:30 am Post subject: |
Yes a grounding strap will probably be required, after welding up the field coil holes and machining the back the original plating gets damaged. So sandblasting and painting is needed. Any of the 3 screws that hold the cover on the back would be a good location as they double as earths for the rectifier.
I usually do these in just a primer which lets you paint it to suit how you think it should look in your engine bay. |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Fri Aug 02, 2013 8:28 am Post subject: |
damn aussies always teasing us..... lol _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Fri Aug 02, 2013 6:00 pm Post subject: |
All that work for 40 amps?
Surely since you are welding and machining you could find an alternator of higher amperage to adapt. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
Posted: Fri Aug 02, 2013 6:07 pm Post subject: |
Mr. Unpopular wrote: |
Surely since you are welding and machining you could find an alternator of higher amperage to adapt. |
Now we know why you're Mr. Unpopular. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Fri Aug 02, 2013 6:11 pm Post subject: |
Why because I don't see the point in going through all that trouble for 5 amps more capacity than the stock generator?
What's the point of the conversion? _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
