joescoolcustoms Samba Member
Posted: Sun Sep 20, 2009 4:28 pm Post subject: |
This debate kind of reminds me of the old debate about turbos.
"You cannot go over 2.5 to 3 pounds boost on a VW, the carbs will not handel it." Well that myth was proved so wrong wasn't it?
Why not try?
I have not seen one good answer to that question in this debate so far. If Nick wants to do it, so what, still a free country at this point. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Sun Sep 20, 2009 4:41 pm Post subject: |
Just slap em together and linebore it. I have seen it done it will be fine. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sun Sep 20, 2009 4:44 pm Post subject: |
Just like driving around without front brakes. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Posted: Sun Sep 20, 2009 4:46 pm Post subject: |
miniman82 wrote: |
Just like driving around without front brakes. |
Did that for a semester while going to college. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Jimmy111 Samba Member
Joined: October 05, 2006 Posts: 2643 Location: Wyoming
Posted: Sun Sep 20, 2009 5:03 pm Post subject: |
Michael Fischer wrote: |
This is why most ACVW's end up in the crusher.....
If someone is pickey enough to want and pay for matching numbers, they are not going to be too happy with a poor running oil pissing motor... |
Posted: Sun Sep 20, 2009 5:22 pm Post subject: |
Jimmy111 wrote: |
One I saw wasn't in the crusher. It was hauling ass down the freeway. I drove it. It ran GREAT. Better than my matching case halves AJ engine.
Who crushes a car over an oil leak? |
Posted: Sun Sep 20, 2009 6:06 pm Post subject: |
This guy.
nsracing Samba Member
Posted: Mon Sep 21, 2009 2:38 am Post subject: |
Jimmy111 wrote: |
The problem is that you need to take about 1 mm of of each side to shorten the top to bottom diameter to stock diameter.
Then you need these operations:
1 Align bore mains
2. Align bore cam bores.
3. resize oil pump register.
4. resize rear main seal register.
5. recut cam and Main bearing Tangs.
6. Mill down lifter registers.
7. resize pulley register.
8. Clearance case for rods.
9. Recut thrust.
10 enlarge mounting holes in bell housing and case.
Now after you did all that your pushrods and rods are too long.
You will need to use 1mm spacers under each cylinder or recut your head registers or find shorter rods.
So it really must be worth it. |
Wow! 0.040" just to clean up each cheek? Doggone, how much warpage are we talking here? 0.080 thou on both cheeks. What the hell happened to the block that it had to be flycut that deep?
0.002 - 0.004 thou should be plenty to clear most warps on both cheeks.
If a machinist tells me he needs to remove 0.080" off the parting line to clean up, I will be asking him what the hell he is smoking?
I can see someone taking out 0.040 thou off the parting line w/ a dull endmill to "correct" the case.
Just unbelievable. I don't think so. |
Posted: Mon Sep 21, 2009 6:28 am Post subject: |
Nick I dont think anyone is going to do this it they only have a .020 over bore. But if they have a .060 over bore and the case is needed then they might consider it.
That .060 has to be removed and brought down to stock or less. The side to side is not the problem. the up to down dimention is the hard one and requires all the material removal to make round again. |
Posted: Mon Sep 21, 2009 7:51 am Post subject: |
Actually, you can bore to the same size...whatever it is already.
If the you have a case say bored to 0.040 already, and you have some warping, it can be reflycut along the seams and then re-bore to 0.040 again. Since the old 0.040 size will be undersized after the flycut. This is the only way you can do it.
I do not think you can bring back to standard after it got linebored already. |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Tue Jan 26, 2010 6:52 pm Post subject: Mixing case halves between type two and three engines |
GEX has indeed done it, but not well. I got an engine from them with a left case half part number starting with a "2" and the right half starting with a "3"; the thing is half bus, half fastback! Larry at GEX swears those things I sent him pictures of are not part numbers and that the stamped numbers at the flywheel cover prove they came on the same car. Said numbers are crystal clear despite being allegedly 45 years old, and are stamped into machined flat surfaces, not the original sand cast surface. How unique! No corrosion at all since 1964!
The engine has never run right and is currently blowing oil drops out the exhaust and pushing lots of oil out of the dipstick tube. The spark plug holes were coated in paint, which is not a bad thing except if you want to believe Larry's claim that it was test run at the factory. I had to chase the threads with a tap before installing the plugs. In short, case halves are married at the factory and will have unnaturally short lives if mixed. On the plus side, the engine has a few thousand miles on it and does not make any lower end noises. Might have worked if I hadn't gotten greedy for displacement and ordered the 1644 pistons. It needs major breathing therapy to handle the air from under the pistons. I'm thinking of putting a PCV in. |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Tue Oct 01, 2013 9:54 pm Post subject: |
with mixing of case halves many other areas of the case needs checking/adjustment.
-plane of sump plate
-plane of sealing surface of the oil pump
-mismatched height of cam plug (there is a v machined ring that will not match)
-out of shape hole for flywheel seal (the dual C shape will not much being at different height)
-same for cam, and oil pump hole.
having many cases to choose from, you can select the ones that are more similar in distance between mains and cam tunnels and maybe you will have to correct less things.
using oversize fan pulleys and oversize cam bore bearings will help a lot. (some euro rebuilders do it)
another detail is to use an undersize brass gear for distributor. it is needed for giant sealing surface flycuts. (euro rebuilders do it)
not easy at all. but very little case halver are good candidate for the machining cost and result. |
PEPPE Samba Member
Posted: Tue Oct 01, 2013 9:58 pm Post subject: |
oh, and you will have also to redo oversize the centering holes for the up and down centering pins of the case. they will not center on differnent case halves, this will help the rest of the holes centering.
some holes of the studs will need some trimming for ease of sliding of them through the case on new centering pins. |
AJTowers Samba Member
Posted: Wed Oct 02, 2013 8:52 pm Post subject: |
Some of the replies in this thread make me LMAO. It sure is easy to tell who is a machinist, or at least has some knowledge, and who is not. I happen to be a machinist and the last time I put my 2275 together I resurfaced the case halves, because they had some fretting from high RPM, and honed the main and cam bores back to standard size. It's not that big of a deal people. Btw, that was 6 or 7 years and several thousand miles ago, still runs good and doesn't leak a bunch of oil or have any of the other problems listed above. It's just machining folks, anything can be done with enough time and money. _________________ RPM's= Ruins-People's-Motors |
PEPPE Samba Member
Posted: Thu Oct 03, 2013 2:16 am Post subject: |
if it is only very few to correct, ie 0-10mm it will work with no big machining. mains and cam will center tools and correct with honing and oil pump will not have problem due to the fact that oil pump are usually 0.10mm undersize and will install ok. using a silicone/rubber main seal will work the same 0.10mm will not do nothing, just a little more difficult to slide. |
