Rear Brakes question
kerian159
kerian159 is offline
PostPosted: Sat Sep 19, 2009 1:49 pm    Post subject: Rear Brakes question Reply with quote
I went to replace my rear brake shoes this afternoon; and found that I could not remove the arm for the Emergancy brake. The pin looks to me like it was pressed on. Has anybody else seen this?
Thanks,
Jay
1976 Type II Westy P22
"Growing older, but not up!"
Wild Bill
Wild Bill is offline
PostPosted: Sat Sep 19, 2009 1:55 pm    Post subject: Reply with quote
Probably have to grind that small side off , remove the old pivot , reinstall a pivot that has the clip to hold it in. Donor?
"Life in the Fast Lane ?....What the Hell does that feel Like?"
"Wild" Bill Tucker
Pensacola, Fl
1978 Champagne Edition (High Top Camper Converstion.) 2.0L FI
1969 Squareback 2.0L
www.rareairvw.com
fusername
fusername is offline
PostPosted: Sat Sep 19, 2009 2:45 pm    Post subject: Reply with quote
support it somehow and hit the pin real hard with a flat punch and hammer and it will likely come out. then try reusing it, if you can't go to the store and pick up a new pin of sorts. if it is rusted in place along w/ being peened in place, yeah just grind around the edge for ahalf second and bop it out.
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
kerian159
PostPosted: Sat Sep 19, 2009 2:46 pm    Post subject: Reply with quote
Ok i'll try that out and "hope" it works Smile
Jay
fusername
PostPosted: Sat Sep 19, 2009 2:52 pm    Post subject: Reply with quote
best part is if you can just hammer it out you can ruse it by peennig it back in place like it is now. cheap is the operative word w/ a vw./
[email protected]
Rusty O'Toole
Rusty O'Toole is offline
PostPosted: Sat Sep 19, 2009 4:56 pm    Post subject: Reply with quote
The parts store should have a 'hardware kit' with all those parts in it. They are not expensive, and a good investment especially when the brake parts are as old and rusty as yours.
fusername
PostPosted: Sat Sep 19, 2009 5:43 pm    Post subject: Reply with quote
my replacement pin did not fit and allowed the ebrake to drag on the drum, ruining new cables in about a year
[email protected]
greenbus pilot
greenbus pilot is offline
PostPosted: Sat Sep 19, 2009 10:23 pm    Post subject: Reply with quote
I have eliminated the pin and used a small bolt and a nylock nut.
Grind off the pin, clean up the arm and bolt onto the new shoe.
What's wrong with that? Cool
Sent from a white van down the street.
germansupplyscott
germansupplyscott is offline
PostPosted: Sun Sep 20, 2009 7:04 am    Post subject: Reply with quote
there was a time when brake shoes came like that. maybe going back 15 years or so. not all shoes had the arms but lots did.
now the shoes usually don't have the arm. you have to grind or drill out the rivet to salvage the arm. a good brake hardware kit will have new pins, washers and clips to fasten the arm to the shoe.
http://germansupply.com/xcart/customer/product.php?productid=16183
http://germansupply.com/xcart/customer/product.php?productid=16490
SL
kerian159
PostPosted: Fri Sep 25, 2009 7:41 am    Post subject: Reply with quote
well got my brakes replaced. Had to replace the star adjusters (got all mangaled up during extraction) but other than that all went well. The new brake shoes had the e-brake arm on them so I didn't have to locate and rob them from anything which made my life abit easier. Smile just letting ya'll know
Jay
