sloans265 Samba Member
Posted: Sun Sep 20, 2009 12:28 am Post subject: Empi GT wheel fitment |
Tonite I realized that the splines on the steering shaft in my '59 ragtop are bigger than those on my Empi Gt wheel. What can be done to remedy this. Change out the steering shaft. Would this mean I'd have to change out column also. Any input is appreciated! _________________ 1970 Lotus White Panel
In search of any Pensacola Fla dealership items |
toyvergnugen Samba Member
Posted: Sun Sep 20, 2009 10:27 am Post subject: |
I ran into this problem with a stock steering wheel and the early shaft. I wasn't awre that the splines still matched up. They line up there are just fewer adjustment splines. I think this should also apply to the Empi wheel. I would try it gently and make sure it is centered, but don't force it. |
EMPIFLAKE Samba Member
Posted: Sun Sep 20, 2009 4:02 pm Post subject: |
Gt's where for 61 on I beleive any way Im not 100% But your colum is longer what you need to do is find a 62 and later colum and shaft and turn signal switch. Whats nice about the later switch is it helps blend in to the back of the gt's hub!! wthout it it just looks stuped and outta place!! Now the thing Im not 100% on is if theirs a problem with the later shaft and you steering box. But really I think it will work!! But really at least run the later switch it looks bad without it!!! |
Posted: Sun Sep 20, 2009 4:31 pm Post subject: |
EMPIFLAKE wrote: |
Thats what I was thinking I was gonna have to do. Problem now is finding said parts since theres not even any parts cars in the area _________________ 1970 Lotus White Panel
my65vert Samba Member
Joined: November 09, 2003 Posts: 6186 Location: Middleburg, Florida
Posted: Sun Sep 20, 2009 4:48 pm Post subject: |
what year do you need sloan? _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
Posted: Sun Sep 20, 2009 5:00 pm Post subject: |
my65vert wrote: |
what year do you need sloan? |
would guess maybe 62-65. I guess I would just have to foigure out the difference in the wiring of the TS switch. What ya got Mike? _________________ 1970 Lotus White Panel
Posted: Sun Sep 20, 2009 5:26 pm Post subject: |
I look through my stuff and see what I got. unfortunetly I recently threw away a complete column from a 65.
I can probably come up with one this week. _________________ OGJHC
Kombisutra;
Posted: Sun Sep 20, 2009 6:12 pm Post subject: |
Let me know. I'll be looking around here. I know a '60's baja'd vert showed up at a local yard but will have to see what year it is. _________________ 1970 Lotus White Panel
Posted: Sun Sep 20, 2009 7:03 pm Post subject: |
sloans265 wrote: |
Let me know. I'll be looking around here. I know a '60's baja'd vert showed up at a local yard but will have to see what year it is. |
cool. is it fixable? _________________ OGJHC
Kombisutra;
Posted: Sun Sep 20, 2009 7:43 pm Post subject: |
my65vert wrote: |
sloans265 wrote: |
cool. is it fixable? |
If it was worth anything it would already be in my yard. _________________ 1970 Lotus White Panel
