crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Sun Sep 20, 2009 7:09 pm Post subject: Propex Heatsource heater orientation options? |
Does anyone know if it is allowable or workable to mount a Propex on it's side with the combustion airflow pipes horizontal?
thanks,
Mark |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
ak_runner Samba Member
Joined: August 16, 2007 Posts: 231 Location: Anchorage, Alaska
Posted: Mon Sep 21, 2009 5:06 pm Post subject: |
Check with Karl but I am fairly sure that it is ok. Frank C. in BC Canada mounted his in the cabinet between the fridge and rear seat using space behind the false wall after deleting the shore power hook up. If I recall he laid the unit on its side to do this. When we add a heater to our van I will be copying Franks installation as it uses space normally not used and let the vents go out the side vs the floor. _________________ AK_Runner
`87 Westy Syncro |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Mon Sep 21, 2009 5:41 pm Post subject: Re: Propex Heatsource heater orientation options? |
crazyvwvanman wrote: |
thanks,
Mark |
Mark, always feel free to call me. The Propex can be turned on it's side, just not on end. |
WiboBusMan Samba Member
Joined: September 26, 2009 Posts: 141 Location: Canada
Posted: Sat Sep 26, 2009 7:25 pm Post subject: From the Propex web site faq |
Quote: |
Q: Can the heater be mounted vertically?
A: No. The heater must not be mounted vertically or upside down. |
I read this as meaning "not on its end nor upside down". I don't read this as meaning "not on its side", but I wish they would spell it out. The site simply doesn't specify.
WiboBusMan |
Posted: Sat Sep 26, 2009 7:31 pm Post subject: Re: Propex Heatsource heater orientation options? |
Thanks Karl. I want to put it between the front seats with the combustion pipes going sideways out into the wheel well area under the passenger seat. Syncro of course so no fuel tank or fuel lines in that area like 2wd has.
Mark
westyventures wrote: |
thanks,
Mark |
matteochiochetta Samba Member
Joined: October 25, 2011 Posts: 17 Location: Verona, Italy
Posted: Fri Nov 04, 2011 6:49 am Post subject: |
Propex Heat Source site reports on the FAQ page:
Does it means I can install it between the front seats, facing back and with the combustion pipes going sideways out into the wheel well area as "crazyvwvanman" has said, under the passenger seat?
I'm going to do it tonight...
Thankyou! |
Posted: Fri Nov 04, 2011 6:54 am Post subject: |
'Vertically' means on end. It can be mounted in any direction around it's horizontal axis, but never on end. |
Posted: Fri Nov 04, 2011 6:57 am Post subject: |
I installed it that way a couple years ago and am happy with the way it works. I wish I had used the smaller unit though as the big one makes more heat than we need and would block a seat swivel if we had one installed.
Mark
matteochiochetta wrote: |
Thankyou! |
Posted: Fri Nov 04, 2011 6:58 am Post subject: |
Thanks a lot. |
Posted: Fri Nov 04, 2011 7:06 am Post subject: |
Mark
Thankyou! |
Thanks Mark,
It seems it fits good, is the yellow pipe the gas pipe? may be it's a different version of the heater (I bought the blue HS2000, it has the gas pipe on his bottom).
Do you have some more pictures to show me, please? (e.g. how the heater fits for the first part of the outgoing gas pipes?). |
Posted: Fri Nov 04, 2011 7:18 am Post subject: |
I used the larger 2800 version and wish it was the smaller one like yours. Mine is mounted on its side with the bottom against the seatbox/wheelwell. The yellow pipe is a flex gas line.
Mark
Thanks Mark,
