risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Mon Sep 21, 2009 6:59 pm Post subject: weber carbs identification and parts source? |
picked up a pair of italian webers.. looks like the id numbers/letters have been ground off.. i assume they are dcnf but how do i find out what size? also, any good leads on getting some parts for these?
thanks! risk
[/img] |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Mon Sep 21, 2009 9:52 pm Post subject: |
I'd contact Gene Berg and see if they can help
www.geneberg.com _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Dale M. Samba Member
Posted: Tue Sep 22, 2009 8:05 am Post subject: |
As for the carbs, you may be able to ID them here........
http://www.piercemanifolds.com/carbdetails/carburators.htm
risk Samba Member
Posted: Tue Sep 22, 2009 8:28 am Post subject: |
i emailed berg about it.. looks like they are dcnf's and the manifolds are the shortys... just unsure about the size. what measurement dictates the size? ex. 40 dcnf, 44 dcnf, etc.. is it the inside diameter that the venturis slide into? |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Tue Sep 22, 2009 10:10 am Post subject: |
risk wrote: |
Just measure the diameter of the throttle plates in mm. That will tell you if it's a 40 or 42. _________________ 1966 Karmann-Ghia convertible |
risk Samba Member
Posted: Mon Sep 28, 2009 8:38 pm Post subject: |
They measure out to be 42mm.. i did a search on berg special 42s and it looks like i scored a set!.. numbers are ground off the bowls and they have the 13mm nuts on the idle airs. Anyone know if a rebuild kit will work or do the berg carbs require special replacement parts? |
