nybugguy Samba Member
Joined: September 21, 2008 Posts: 117 Location: Upstate New York
Posted: Wed Sep 23, 2009 12:18 pm Post subject: do I have a bad switch? |
I'm using a used headlight switch on new lights.When I run the headlights into the fuse panel then out to the switch through the dimmer switch the headlights come on even without the switch pulled out to the on position.Could this be a bad headlight switch? Could the dimmer switch be affecting it as well? Looking for some insight. Thanks in advance for any suggestions! |
jspbtown Samba Member
Posted: Wed Sep 23, 2009 12:23 pm Post subject: |
The basic circuit for the headlights should be power into the switch, then out to the floor mounted dimmer, and then to the hi/lo beams. Thats assuming your using a stock dimmer.
What kind of switch are you using? Do you have it wired correctly? |
Posted: Wed Sep 23, 2009 12:54 pm Post subject: |
I'll double check my wiring route......am using a stock dimmer too. I'll check back a little later with the results..........THANKS |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Sep 23, 2009 2:34 pm Post subject: |
IF lights are on with switch off, it pretty much tells me if everything is wired correct you have a bad switch........
Posted: Wed Sep 23, 2009 6:53 pm Post subject: |
switch was bad..........got another new one and the problem is solved!
THANKS GUYS |
