Original Engine Traders Thread
Page: Previous  1, 2, 3 ... 9, 10, 11
GERMANAIRE
GERMANAIRE is offline
PostPosted: Sun Jan 28, 2018 6:11 pm    Post subject: Re: Original Engine Traders Thread Reply with quote
Well thought I would post this Engine up here. Seems to fall between
April and May of 1959. I took this engine out of a 53 Zwitter I had which was incorrect and has just been sitting under my work bench for several years in case something comes up Cool
Douglas Denlinger
Douglas Denlinger is offline
PostPosted: Tue Jan 30, 2018 4:21 am    Post subject: Re: Original Engine Traders Thread Reply with quote
Would like to find for a 60...... 5 073 407 thru 5 157 563.
Thanks any help GREATLY appreciated!!
Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986
Abscate Premium Member
Abscate is offline
PostPosted: Tue Jan 30, 2018 7:38 am    Post subject: Re: Original Engine Traders Thread Reply with quote
Be careful buying any motor represented by serial number..the file of engines and VINS is not secure, so if someone has laid there hands On it itís easy to make an engine to a number spec.
Verify parts, progressive refinements etc.
.ssS!
mdege
mdege is offline
PostPosted: Wed Jan 31, 2018 1:43 am    Post subject: Re: Original Engine Traders Thread Reply with quote
Just a short note on re-stamping. To give you an insight why VW used to re-stamp replacement engines.
In Germany the shops were required to re-stamp the cases before engine codes were introduced, because that was the only way for the inspection guys to tell if the right engine was installed in the car.
These days all you need is the correct engine code on the case.
Any change of engine to a different engine type must be recorded. The engine size, hp and emission standard have influence on the taxes and the insurance premiums you pay.
- Michael
Restoration of a former '65 firetruck (21F)
1988 Multivan Magnum 112i
2006 T5 (sold)
1986 Caravelle C (sold)
1987 Caravelle Coach (R.I.P)
1972 T2ab Bay Window (sold)
1965 21F
1971 & 1969 Variant LE (sold)
Thompson2
Thompson2 is offline
PostPosted: Thu Sep 06, 2018 10:15 am    Post subject: Looking for a specific engine. Reply with quote
My '63 Bus was originally titled using the engine number instead of the chassis number. I know it's a super long shot, but since I have the info, I thought it would be cool to see if I can find the original engine (or at least the case).
Anyone happen to have engine number 0243487 lying around?
Thanks!
Abscate is offline
PostPosted: Thu Sep 06, 2018 12:37 pm    Post subject: Re: Looking for a specific engine. Reply with quote
Thanks!
Someone will soon.
Surprised
.ssS!
Page 11 of 11
