57streetrodbuggy Samba Member
Joined: November 17, 2008 Posts: 900 Location: Santa Cruz, CA
Posted: Sun Oct 04, 2009 10:25 am Post subject: |
Wayne S. Johnson wrote: |
My test stand |
hey wayne your gonna have to hook me up when i finish my 2332 _________________ Bermoco buggy on 57 pan - under construction
There's no such thing as too much horsepower, there is only a point where the car breaks in two |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Tue Oct 06, 2009 6:25 am Post subject: |
Max Welton wrote: |
You might get a chuckle out of this "first-fire" picture. Dig my high-tech throttle control!
Max |
Max, if you had the spark plug wires in the right place it might start faster. |
Posted: Wed Oct 07, 2009 7:16 am Post subject: |
Quote: |
They are in the right place |
Unless you have a 050 dist. A 009 has a 3 degree 'retard' on #3 cylinder and having the wires in the wrong place moves that. Spark plug wires on the right go to #1 & #2. The ones on the left go to #3 & #4. In your photo it looks #1 cylinder on the dist. is going to #4 spark plug.
craigman Samba Member
Posted: Wed Oct 07, 2009 7:22 am Post subject: |
009's don't have a #3 retard. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Wed Oct 07, 2009 7:24 am Post subject: |
craigman wrote: |
that's right... they don't. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Oct 07, 2009 9:09 pm Post subject: |
I'm not sure if I'm surprised or disappointed by the replies.
Aircooled VW Engine Interchange Manual: The User's Guide to Original and ... By Keith Seume
A passage...." with a retarded number 3 spark..pp 119
http://books.google.com/books?id=NPJVPIGRJ0EC&...mp;f=false
GeneBerg...
A passage...."Bosch 009 centrifugal advance distributor. The only Bosch distributor currently made with the correct advance curve and #3 retard for VW engines"
http://www.geneberg.com/cat.php?cPath=10_310_2879
VW Beetle performance handbook
A passage...."spark retard to number 3 cylinder"
http://books.google.com/books?id=rWTbIiTcRk8C&...mp;f=false
I could go on, but I think you get the point. Max, I really don't give a rat's ass how you run the spark plug wires on your engine, just thought I'd try to help by pointing out, in a nice way, they are WRONG! BUT I will say one thing, you have got to have the best timing light ever made if it can detect 3 degress difference on one lobe from the rest on a running 009 dist. |
Posted: Wed Oct 07, 2009 10:17 pm Post subject: |
funny, if you look at Gene Bergs link you posted, their "DISCONTINUED",
and i would think it's because THEY DON'T MAKE THEM ANYMORE.. |
Posted: Wed Oct 07, 2009 11:30 pm Post subject: |
Runamoc, I appreciate your attempts to help me straighten out my wiring. But you really can't do that with inaccurate information.
I also applaud your attempts to become knowledgeable by reading books. But it sounds like you have managed to come up with some incorrect information that way.
I read books too. But I know they aren't always right. People (including writers of books) are sometimes mistaken. That is why I try to get the information I rely on directly from my engine. It is a machine. It can be inspected and measured.
I certainly can measure 3º or even 1º with a timing light. And so can you if you are careful in your method and take steps to minimize timing scatter.
Here's what I did.
First, this particular 009 is made up of parts of at least 5 distributors in a box 009s I picked through several years ago. My intent was to come up with the least sloppy combination using parts I already had. Consider it the poor-mans pick-of-the-little approach.
Second, crankshaft end-play contributes to timing scatter. I set mine at roughly .0045". Sloppy engines will have more scatter, independent of what type of distributor is used. Only crank-fire triggering is immune to this.
Third, I found that use of a Compufire ignition trigger substantially reduced the amount of scatter I could detect. I believe this has to do with the absence of that intermittent load as the points are periodically in contact and not in contact with the lobes as they come around.
The Compufire disk holds four magnets, the spacing of which determines the spacing of the trigger events as each magnet passes the sensor.
In fact, that Compufire disk was the reason I checked timing for all four cylinders. Because to me that plastic disk just didn't look like a precisely made part.
But I have the feeling you are saying my wires are wrong because they aren't where the pictures in the various books say they should be. And you may be right in that regard.
I paid no attention whatever to the orientation of the distributor drive when I installed it. I just needed it to fit properly and work well with the crankshaft gear. I use rotor position to determine where each plug wire needs to go, not some notch on the distributor and a picture in a book. Those can all be wrong. The rotor position cannot be wrong.
Now, someone else working on my engine may be confused if they try to locate the #1 plug wire position based on a mark on the distributor. If they are any good at all, they'll figure it out pretty quick.
But the only person that will be working on this engine is me.
Another issue might be distributor shaft oiling. On the side of the distributor body where it fits into the case there is an opening that appears to be there to allow splash oiling of the shaft. I believe that opening needs to face towards the center of the engine. Since I have no vacuum canister, I just pick an orientation of the distributor body that accomplishes that.
As long as I satisfy my engine, I and my engine are happy.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Posted: Thu Oct 08, 2009 4:52 am Post subject: |
Quote: |
I paid no attention whatever to the orientation of the distributor drive when I installed it. |
Them dam books, what do they know! |
Posted: Thu Oct 08, 2009 5:02 am Post subject: |
craigman wrote: |
Your point being?
Maybe you didn't get the memo, Bosch stopped making the 009 dist. a few years back. Gene was just pointing out he doesn't HAVE ANYMORE to sell! |
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Thu Nov 05, 2009 5:14 pm Post subject: |
Welded in the center leg as everyone wanted. Made 5 welds at the top of the support. Made 6 welds to the back of the engine plate. Made 5 more welds at the bottom. The support is a thick piece of "T" section with lots of useful holes.
Made a laser cut bracket to hold my Oberg and fuel pump. Still have lots more to do and also found that my oil pump fittings have to go. Maybe crank the engine in a few days. Will put on youtube if it works out.
Posted: Fri Nov 06, 2009 10:34 am Post subject: |
Dale M. wrote: |
Only thing see wrong is no bottom brace on plate.... You are going to have 300 pound bucking and shaking, cantilevered on one single weld.... Structurally its a poor setup... You need a bar from crossbar at top to bottom behind plate belhousing is bolted to....
Dale |
Your request is my demand. |
Posted: Fri Nov 06, 2009 10:36 am Post subject: |
fastinradford wrote: |
seems like an overkill, but looks nice. |
When everything gets bolted on, the extra width is handy. I found room for everything sofar. |
