JDub Samba Member
Joined: October 16, 2002 Posts: 97 Location: Mountain Grove,MO
Posted: Sat Oct 03, 2009 2:11 pm Post subject: Q's about rusty section on my '67 bus |
How would up repair the rust in these places and who/where would have the replacement panels for these sections if any are made? Klassic Fab?
This is the right front inner wheel well:
left front inner wheel well:
Lower right bulkhead/cargo floor near the cargo doors:
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Sat Oct 03, 2009 3:28 pm Post subject: |
It was not quite as rusted out as yours but I repaired the same area on one of my old buses. I had the inner and outer rocker, and outer cargo floor section removed, which helped, then I removed the jack support, outrigger, outer end of the U-shaped cargo floor support, and lower wheel well wall. I bought sheet metal and fashioned the lower wall and U-shaped cargo floor support, myself. My buses lower B pillar was good; yours may be bad.
You can get all of the pieces that you need from Klassic Fab. _________________ Don't worry; be happy. (Baba) |
DownRiver Samba Member
Joined: January 05, 2003 Posts: 797 Location: threeonethree
Posted: Sat Oct 03, 2009 4:58 pm Post subject: |
Your probably going to have to start digging to know exactly what you need. You might be lucky and the B pillars are still decent. How do they look on the outside?
Skim through Nor-Al's thread. I think he documented both sides.
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...;start=220
_________________ Whether you think you can or think you can't, you're right. -Henry Ford
VanSlyke VW Doublecab |
