nybugguy Samba Member
Joined: September 21, 2008 Posts: 117 Location: Upstate New York
Posted: Sun Oct 04, 2009 6:14 am Post subject: question on gas tank grounding... |
Wondering what gauge wire is recommended for grounding a gas tank on a fiberglass buggy. Should I use a braided grounding strap or a 10-12 gauge wire. Also using a 70's era speedometer with the gas gauge in it and need to know what terminal do you pick the power up from?....any pics on that diagram would be very helpful. Thanks for the help! |
jspbtown Samba Member
Posted: Sun Oct 04, 2009 6:33 am Post subject: |
16 gauge is plenty. If your a fanatic you can go 14. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Oct 04, 2009 6:44 am Post subject: |
The whole idea of grounding tank is so electric gauge will work and keep static electricity down..... IF you look at wire to electric gauge from sender the grounding wire need not be any bigger that sender wire... As for static electricity its about voltage not current and if it is grounded no matter how small the wire any buildup is prevented ...
16 gauge is probably just fine but if in doubt always go bigger (14 gauge)....
sturgeongeneral Samba Member
Joined: June 23, 2005 Posts: 2460 Location: Sacramento, California
Posted: Sun Oct 04, 2009 10:08 am Post subject: |
Definetely ground the tank against static discharge. I go at least 12 guage. 10 would not hurt either. _________________ Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her |
dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Sun Oct 04, 2009 7:27 pm Post subject: |
sturgeongeneral wrote: |
Definetely ground the tank against static discharge. I go at least 12 guage. 10 would not hurt either. |
Why not just use 00 welding cable to be sure. Just kidding. All you need is the original ground wire from your sending unit. This grounds the sender body which is grounded to the tank by the sender screws or the locking cams on a twist and turn sender. _________________ Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone |
