allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Mon Oct 05, 2009 8:46 pm Post subject: Will a stuck T stat keep the water pump from flowing? |
My wife told me the heat gauge got to the second white line today. She promptly shut it down and parked it and got a ride. So I get home from work And go and pick it up It runs where it has the past few times I have drive it just a tick above the led. So I pull it in the driveway and pop the deck lid Its reading on the temp gauge that the engine is warm But I have A cold hose coming from the water pump outlet. SO I carefully open the pressure cap. Not much pressure in there. But I dont see any recognizable flow. I go to the radiator next it cool to the touch. SO I let it idle a while. After nearly 30 min, it finally warms up the radiator.So I open the bleeder to see if any trapped air escapes. Nothing but a little water dribbles out. So I close that back up still no noticeable flow but the Outlet hose is starting to warm. Am I being paranoid or is there an underlying problem here. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
?Waldo? Samba Member
Posted: Mon Oct 05, 2009 8:53 pm Post subject: |
There is no hose from the water pump outlet. The only outlet from the water pump is the big hole into the block. All three hoses connected to the water pump flow into the water pump. |
Posted: Mon Oct 05, 2009 8:55 pm Post subject: |
Well Should I be able to see flow in the tank with the cap off? _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
Posted: Tue Oct 06, 2009 12:23 am Post subject: |
Really have no idea how your TDI is actually plumbed, but it sounds like you may have a thermostat that is stuck just slightly open. This can cause overheating under load and a cold running engine at other times. Some diesels hardly put out enough heat at idle to warm themselves up, the curse of efficiency. |
Posted: Tue Oct 06, 2009 4:05 am Post subject: |
well looks like I need to change the T stat. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
