Trevor P Samba Member
Joined: January 21, 2004 Posts: 863 Location: Saskatoon, SK, Canada
Posted: Mon Oct 05, 2009 9:36 pm Post subject: Euro headlight confusion. |
I plan on running a set of Euro lights that I picked up when I was in Germany several years ago. These came right out of the vintage parts place in Wolfsburg. When I got looking at these closer recently I noticed that obviously they are not the same. One looks earlier than the other, and apparently has an earlier lense as well as a Bosch ring with the L shaped retaining tab.. My question is are these correct (or which one) is correct for a 56 oval, and if not what do I need to make them correct?
The lenses I have are 1 Bosch with a VW symbol at the top, and 2 other fluted Bosch ones with different size script with no VW symbol at the top.
L shaped retaining tab (note different lense script and this glass has the VW emblem at the top)
Bosch ring
single rivet style but ring has NO Hella marking on it and no VW emblem at the top of the lense
This is the one I believe to be an earlier bucket setup (note the drain holes compared to the other)
_________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1275 Location: australia
Posted: Tue Oct 06, 2009 5:19 am Post subject: Re: Euro headlight confusion. |
hi, i'm sorry to say that as far as i know none of the headlights you show are 100% correct for a 56.
this lense is too early (i'm sure you'll find plenty of people willing to swap)
the lenses with the NL and A and 58 on or there abouts.
if you want to be a perfectionist you want lenses with the VW logo at the top and the same bosch writing as the NL ones but without the NL and A lettering.
you want buckets that use a metal stud and a clip on the reflector swivel point not a rubber plug. i'm fairly sure my one 56 light has the 3 pressed drain holes.
as far as the rings go i know nothing about the L tabbed rings as i have never seen a set in person. there are 2 different sizes of bosch scripting on the rings. what you have looks to be the right one (the earlier lights had larger lettering)
oh and you want flathead mount screws with metal spacer collars. |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Tue Oct 06, 2009 7:22 am Post subject: |
just curious, does the lamp inside have a beam pattern on the lens, or is it clear smooth glass? I will be running fluted style lenses, and it just seems wrong to have a beam pattern shoot into another beam pattern. |
Posted: Tue Oct 06, 2009 11:09 am Post subject: |
I guess I'm not too concerned about being a perfectionist as far as the headlights go. Just want something that is close to era correct, and matched side to side.
So what vintage are these buckets and reflectors from considering they have the rubber plug at the pivot point? _________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
70 911T
91 Westy |
janerick3 Samba Member
Posted: Tue Oct 06, 2009 7:50 pm Post subject: |
Are there any date codes (1-2 numbers, followed by a letter) printed on the backs of the reflectors? _________________ Thanks,
Jan K. |
Posted: Tue Oct 06, 2009 8:09 pm Post subject: |
Can't see any. The writing I have seen is whats shown in the pics. _________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
70 911T
91 Westy |
