irockat3square Samba Member
Joined: February 08, 2009 Posts: 98 Location: Portland OR!!
Posted: Thu Oct 15, 2009 2:20 am Post subject: a quick picture of the new motor |
I am getting closer! |
Aaron M265 Samba Member
Joined: March 31, 2008 Posts: 656 Location: Adelaide, South Australia
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Oct 15, 2009 7:23 am Post subject: |
You are missing one piece ot tin on the left side next to the distributor.
And where is the thermostat linkage? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Thu Oct 15, 2009 1:30 pm Post subject: |
Russ Wolfe wrote: |
And where is the thermostat linkage? |
I am not missing that tin its is just not painted yet. and thermostat linkage?? |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Thu Oct 15, 2009 1:47 pm Post subject: |
irockat3square wrote: |
Russ Wolfe wrote: |
for the thermostat and flaps. alot of engines dont have them anymore. the PO ripped mine all out too. _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
Posted: Thu Oct 15, 2009 2:02 pm Post subject: |
JSMskater wrote: |
Russ Wolfe wrote: |
for the thermostat and flaps. alot of engines dont have them anymore. the PO ripped mine all out too. |
ok then its the same for my motor as well. Is it going to be an issue over time? |
Posted: Thu Oct 15, 2009 3:05 pm Post subject: |
It iwill be a cold blooded engine. It will not warm up fast.
Why people thought that taking out the thermostats will help the engine run cooler, I will never now. It takes no horsepower to run the thermostat.
[/rant] _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Thu Oct 15, 2009 6:38 pm Post subject: |
Russ Wolfe wrote: |
[/rant] |
I don't think they thought it would make it run cooler, I think many of them thought that it was a cause for overheating if they failed, which is erroneous since they fail in the open position. _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
68notch Samba Member
Joined: August 16, 2007 Posts: 544 Location: Perth, Western Australia.
Posted: Thu Oct 15, 2009 10:30 pm Post subject: |
I have my own motor out at the moment also with a broken flap thermostat.
Last week I enquired about buying a new thermostat and the supplier said they are not needed as a VW workshop bulletin has previously recommended they be removed.
Maybe this is only in Australia since mostly we do not get as cold as USA and Europe?? _________________ John
68 Aussie notch
2011 Citroen Berlingo
https://www.facebook.com/Fastacraft
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227 |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Thu Oct 15, 2009 10:36 pm Post subject: |
Clean!! i cant wait to get mine back together. when i do, it will have a functioning thermostat. |
Posted: Thu Oct 15, 2009 10:49 pm Post subject: |
68notch wrote: |
Maybe this is only in Australia since mostly we do not get as cold as USA and Europe?? |
I want to see that bulletin. I have bulletins going back to 1967. If VW said to take them out, then why did they keep installing them on the assembly line up until almost the end. Some of the last Mexican engines did not have them. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Thu Oct 15, 2009 10:56 pm Post subject: |
Thanks a lot guys! Yeah its been a lot of work seeing as she started out looking like this
The old motor was just done. when i pulled it out of the car i re torked the heads down and i could still spin the fly wheel with just about no effort lol.
I am so looking forward to this new motor lol |
Hornman Samba Soul Surfer
Joined: April 16, 2002 Posts: 1062 Location: Ventura, CA
Posted: Thu Oct 15, 2009 11:17 pm Post subject: |
Looks good! _________________ Michael
1969 Fastback |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Fri Oct 16, 2009 10:49 am Post subject: |
68notch wrote: |
A more likely explanation is that your supplier just doesn't have one to sell you. It would be refreshing if they would just say that.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Posted: Fri Oct 16, 2009 2:24 pm Post subject: |
"Real" new thermostats are up around $90 each, last I checked.
In going through my stash, every time I find one, I feel I have found a nugget of gold.
Right now though, I am down to 2 good used ones.
I bid $35 ea. on 3 cars at an auction that were complete junk, but they had thermostats in them. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Sat Oct 17, 2009 4:55 am Post subject: Re: a quick picture of the new motor |
Since you're running carbs, you might want to change that breather assembly or you'll have an oil leak at the end of the fan. That breather was set up to be used with FI, and it doesn't quite work well with carbs. Otherwise it looks real good. Keep up the good work. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
