luis.1965 Samba Member
Posted: Thu Oct 15, 2009 9:08 am Post subject: CB Performance Brazilian fan shroud |
I have the CB Perfromance Brazilian fan shroud: http://www.cbperformance.com/catalog.asp?ProductID=1523
The issue I have is the oil cooler adapter hits the shroud when installed and a gap of ½” is visible on the right side when the left side of shroud is bolted down. The opposite is true when the left of side of shroud is bolted down. Do I need to change the oil cooler adapter to a different one? If so, which one?
I called CB Performance and they want me to take pictures and send them to them. I will do that this afternoon…just want to know if anyone here has had this issue as well.
Thanks in advance
Luis |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Thu Oct 15, 2009 10:07 am Post subject: |
Are you using a German oil cooler and adapter? Some pictures may help as well. _________________ 1965 Beetle sedan
Click to view image |
Posted: Thu Oct 15, 2009 10:24 am Post subject: |
Matthew wrote: |
Are you using a German oil cooler and adapter? Some pictures may help as well. |
I know. This happens last night and as always...got diverted torwards a non-acvw issue. I will post some pics so you guys see what I am talking about. |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Fri Oct 16, 2009 9:56 am Post subject: |
In picture 3, the two holes are for the stock spark plug wire retainers. _________________ 1966 Karmann-Ghia convertible |
Posted: Fri Oct 16, 2009 10:18 am Post subject: |
I can't read the text, but what does CB say about your issue? _________________ 1965 Beetle sedan
Posted: Fri Oct 16, 2009 10:34 am Post subject: |
Matthew wrote: |
I can't read the text, but what does CB say about your issue? |
No respose yet |
Posted: Fri Oct 16, 2009 10:43 am Post subject: |
Matthew wrote: |
FWIW.
When you click on the link make sure it open on a 'full window' |
veeweekid Samba Member
Posted: Fri Oct 16, 2009 10:45 am Post subject: |
those holes i believe are for the plug wire holders(im not sure what they're called, but they hold the plug wires up off the engine) |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Fri Oct 16, 2009 1:02 pm Post subject: shroud holes |
Ditto...those holes are for the spark plug wire "clips"...just find some OEM wire clips. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
akokarski Samba Member
Posted: Fri Oct 16, 2009 1:08 pm Post subject: |
how thick are your plug wires? They will probably get chewed up by stock holders |
SkrapMetal Samba Hornblaster
Joined: January 18, 2006 Posts: 2558 Location: Dallas, TX
Posted: Fri Oct 16, 2009 1:37 pm Post subject: |
Off topic.... how well does that shroud keep things cool? _________________ oo9less since 2007
-72 Ghia- |
Posted: Fri Oct 16, 2009 1:39 pm Post subject: |
akokarski wrote: |
They are 8.5mm.
I do not plan to use the stock wire holder in this application. |
74 Thing Samba Member
Posted: Fri Oct 16, 2009 2:00 pm Post subject: |
Even if you are not going to use them I would still put the plug holders in the shroud so the air does not escape through those open holes. |
Posted: Fri Oct 16, 2009 2:03 pm Post subject: |
Those open holes and the other ones. Now, the is one that has a oval shape...it might be a challenge to cover that one. We will see. |
Posted: Fri Oct 16, 2009 3:33 pm Post subject: |
you can weld it up |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4916 Location: Southern AB
Posted: Fri Oct 16, 2009 3:39 pm Post subject: |
Mine fit pretty good right off the bat.
I did some clean up on the brackets and holes before I powder coated it.
These were taken while we did the break in on the chassis a couple years ago.
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Fri Oct 16, 2009 5:07 pm Post subject: |
akokarski wrote: |
Use the early style rubber ignition wire holders.
I have the same shroud. It's an older style without all the extra holes and brackets welded to it.
I use a German oil cooler with no problems. _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
volkaholic1 Samba Member
Posted: Thu Oct 22, 2009 9:17 am Post subject: |
about pic 1 - I've fit several PUMA shrouds and never seen that problem, not sure what to say about that, but it appears you have solved it with some selective hammer hits
about pic 6 - those openings are for the hot air from the oil cooler to exit the engine compartment. Do NOT seal those off. When you use the PUMA shroud, it has the round outlet, use the matching firewall with the round opening. there is a sealing "donut" to mate the 2 up. _________________ Volkaholic |
